Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Jan 26, 2022 5:13 pm Post subject: Wiring lesson |
So, I installed a new German speedometer cable on my 1974 Super Beetle, and when done, I started up the engine—and a comedy of errors.
Turned the key and this loud whirring noise started from the back, the front, all around! My Alpine radio/CD whatever came on, so I turned that off. Apparently, the speakers weren’t on a proper station, and I was getting a lot of weird noise from the speakers. Then, when I tried to turn the radio back on, it had no power.
WTH?
Then, I still had a loud whirring noise in the front, and noticed that my electric washer pump switch was on. I must have turned on the switch when reinstalling all the switches in the faceplate (which had to be removed to get to the back of the speedometer).
Before I could turn off the switch, the little motor pump died. Actually, it blew the 8 amp inline fuse I had installed with the pump system.
I replaced the fuse, and the radio suddenly worked again. After taking apart the fuse box cover(s), I found the guys who had installed my radio had tapped into the ignition-on wiring to my electric washer pump.
I tried the pump again after re-fusing. The fuse popped immediately. Okayyyyy.
The speedometer works well, though. No jumping around anymore! And the radio works, too. Looks like I’ll be getting a new washer pump, though. It whirred itself to death, I guess.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
MACJELLY58 Samba Member
Joined: September 26, 2014 Posts: 400 Location: HONOLULU, HAWAII
Posted: Thu Jan 27, 2022 12:05 am Post subject: Re: Wiring lesson |
WOW!!
Sounds like Demonic possession
You gotta love these little cars. Life would be so boring without them. I mean, what else would you have done with an entire afternoon.
Good job tracking that down, Tim. |
