mukluk Samba Member
Posted: Thu Jan 20, 2022 7:43 pm Post subject: Re: '58/'59 Beetle Discussion |
EVfun wrote: |
mukluk wrote: |
Quote: |
What is this black box under the hood on the DS?
That the fuse block for the headlights. |
I would add the 2 fuses for the high beam headlights. On these older Bugs the low beam headlights are not fused! If its is a US model Bug the front parking lights are not fused either (and those screw terminals on the bulb holders are very close to shorting out against the headlight bucket.) Honestly, some old VW stock wiring practices were kinda scary. |
Good catch, I tend to think of my '60 which has a block with four fuses in that location, one for each high and low beam. _________________ 1960 Ragtop w/Semaphores "Inga" |
Beetlebubs Samba Member
Joined: January 27, 2022 Posts: 1 Location: United Kingdom
Posted: Thu Jan 27, 2022 4:39 am Post subject: Re: '58/'59 Beetle Discussion |
Hi all i am new to this forum, i have a 1958 cabrio which i have owned for 12 years, i require a pair of window regulators can anyone help? |
TXHCBeetle Samba Member
Joined: October 07, 2021 Posts: 170 Location: Boerne, TX
Posted: Thu Jan 27, 2022 6:30 am Post subject: Re: '58/'59 Beetle Discussion |
Beetlebubs wrote: |
Check the classifieds section here on TheSamba.com _________________ In Progress:
1958 Beetle Sedan - L243 Diamond Gray
1967 Beetle Sedan - L456 Ruby Red |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
myvolks1 Samba Member
Joined: February 07, 2011 Posts: 182 Location: Modesto, CA
Posted: Thu Jan 27, 2022 10:12 pm Post subject: Re: '58/'59 Beetle Discussion |
Yes, US models had the coat hook assist straps on both sides?
_________________ 1959 L358 (Garnet Red)
Type-113 De Luxe Sedan
WANTED: DEET EICHEL (Modesto, CA), license plate frames and other Deet Eichel related items.
Wanted: Original VW |
Posted: Thu Jan 27, 2022 10:17 pm Post subject: Re: '58/'59 Beetle Discussion |
How does the speedo's manufactured date compare with the car's manufactured date? Is there a month lag, or do they match? _________________ In Progress:
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Fri Jan 28, 2022 6:02 am Post subject: Re: '58/'59 Beetle Discussion |
I've also wondered the same thing about the speedometer. Admittedly I don't know the correct answer but know my speedometers were pretty close. Certainly the same years. Hopefully someone with more knowledge on the matter will chime in. |
Posted: Fri Jan 28, 2022 10:26 am Post subject: Re: '58/'59 Beetle Discussion |
General rule:
Most parts are usually 1-2 months behind the production date but I'm guessing you want to know specifically for 58-59, which I cannot answer.
This is definitely true for things like the generator/regulator/wheels.
Hopefully some people can check their 58-59 speedos and report back. _________________ How to Post Photos
Bug-nut Samba Member
Joined: December 20, 2015 Posts: 488 Location: Knoxville, TN
Posted: Mon Jan 31, 2022 10:49 pm Post subject: Re: '58/'59 Beetle Discussion |
The speedometer in my April of '59 built beetle has the date 3.59 stamped on the back shell. To my knowledge it is the original speedo. _________________ 1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote: |
A 59 Beetle is just an Oval-Window car with aspirations of modernity. |
Posted: Tue Feb 01, 2022 3:06 am Post subject: Re: '58/'59 Beetle Discussion |
Bug-nut wrote: |
The speedometer in my April of '59 built beetle has the date 3.59 stamped on the back shell. To my knowledge it is the original speedo. |
That sounds like the original to me, thanks for confirming! _________________ In Progress:
Posted: Tue Feb 08, 2022 8:55 am Post subject: Re: '58/'59 Beetle Discussion |
Since learning about the fuse boxes that came equipped from 1956-1960, has anyone been able to accomplish a 12V conversion while leaving the original wiring "look" under the hood? My car is currently 12v, with the incorrect headlight wire routing and missing the original headlight fuse box. _________________ In Progress:
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Tue Feb 08, 2022 8:46 pm Post subject: Re: '58/'59 Beetle Discussion |
TXHCBeetle wrote: |
Bug-nut wrote: |
That sounds like the original to me, thanks for confirming! |
I'll take a look over the weekend on the 59 to check dates. I know from records it's never been replaced.
The speedo ink stamp is 11/58. Both the chassis and engine number fall into Dec 58 production numbers. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Thu Feb 10, 2022 9:52 pm Post subject: Re: '58/'59 Beetle Discussion |
I converted my current Oct 58 back in the 80s and I used the original wiring harness and the original fuse boxes so not sure why yours were changed as they don't need to be changed. Nothing needs to be changed in regards to wiring or fuse boxes to convert it to 12-volt.
The 1960 has a different fuse box on the side.
TXHCBeetle wrote: |
Since learning about the fuse boxes that came equipped from 1956-1960, has anyone been able to accomplish a 12V conversion while leaving the original wiring "look" under the hood? My car is currently 12v, with the incorrect headlight wire routing and missing the original headlight fuse box. |
Posted: Fri Feb 11, 2022 7:59 am Post subject: Re: '58/'59 Beetle Discussion |
my59 wrote: |
TXHCBeetle wrote: |
Bug-nut wrote: |
The speedo ink stamp is 11/58. Both the chassis and engine number fall into Dec 58 production numbers. |
About a one month lag, looks like I need to find a 2/58 speedo! _________________ In Progress:
Posted: Fri Feb 11, 2022 8:22 am Post subject: Re: '58/'59 Beetle Discussion |
myvolks1 wrote: |
The 1960 has a different fuse box on the side. |
Did you simply replace the fuses in the fender-well fuse box with 12V fuses?
My car seems to have been built from a couple of cars, the only original 58 parts that remain are the body, fuel tank, doors, and glass. The conduit fenders are not present so the routing of the aftermarket harness was designed to accommodate the post-conduit headlighting. _________________ In Progress:
janerick3 Samba Member
Posted: Fri Feb 11, 2022 4:26 pm Post subject: Re: '58/'59 Beetle Discussion |
If you have white 8A fuses in the fuse box, leave them. If they are red (16A), orange or blue (both 25A) fuses, replace them with 8A. Make sure all the connections are shiny copper-on-copper or copper-on-aluminum. If you go with higher-wattage headlights, you should be OK with 8A on a 12-volt system. _________________ Thanks,
Jan K. |
bwaz Samba Member
Posted: Wed Feb 16, 2022 2:50 pm Post subject: |
my59 wrote: |
I need to replace the conical filter in my fuel pump.
Looking thru the classified, so go.
Look at some suppliers, no go.
The last one came with a fuel pump rebuild kit that was $$$. I'm trying to avoid buying a whole kit for just this part
Any suggestions?? |
I never saw a reply to this question about a cone type filter in the fuel pump. Anyone ever find a source?
my59 Samba Member
Posted: Wed Feb 16, 2022 7:33 pm Post subject: |
bwaz wrote: |
my59 wrote: |
Any suggestions?? |
I ended up getting a parts pump at a swap meet, after checking to see if filter was good, and the hex shaped in/out valves were there..... _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
jbannon Samba Member
Posted: Wed Feb 16, 2022 10:25 pm Post subject: Re: '58/'59 Beetle Discussion |
TXHCBeetle wrote: |
How does the speedo's manufactured date compare with the car's manufactured date? Is there a month lag, or do they match? |
The speedo in my beetle was built sometime in September 1958 according to the stamp on the metal case. The car left the factory on 30 October 1958 and was delivered to the dealership in Salzburg, Austria on 02 November 1958.
Hope this helps. |
Posted: Thu Feb 17, 2022 9:17 pm Post subject: Re: '58/'59 Beetle Discussion |
You don't have to change the fuses when converting it to 12-volt.
TXHCBeetle wrote: |
myvolks1 wrote: |
My car seems to have been built from a couple of cars, the only original 58 parts that remain are the body, fuel tank, doors, and glass. The conduit fenders are not present so the routing of the aftermarket harness was designed to accommodate the post-conduit headlighting. |
