Beetsme Samba Member
Joined: December 02, 2020 Posts: 64 Location: WASHINGTON
Posted: Wed Jan 26, 2022 9:20 am Post subject: Hand crank start rope |
I can't look at this without picturing skinning my knuckles on the decklid. But probably works? |
Bonesberg55 Samba Member
Posted: Wed Jan 26, 2022 9:27 am Post subject: Re: Hand crank start rope |
Beetsme wrote: |
I remember this ad. It was in the old Warshawsky and J.C. Whitney catalogs when they actually sold real parts. I remember rebuilding my 1200 engine for next to nothing back then. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Wed Jan 26, 2022 7:33 pm Post subject: Re: Hand crank start rope |
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Wed Jan 26, 2022 7:39 pm Post subject: Re: Hand crank start rope |
You better have Popeye arms with a 9.5:1CR engine. _________________ Glenn
Member #1009
#BlueSquare |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Thu Jan 27, 2022 4:50 am Post subject: Re: Hand crank start rope |
My mother used to use her purse strap when her Bug would not start in the 60s so my Dad bought her this. He built Saturn V , space shuttle , LEM, and Concorde. In many ways, she is still more impressive.
You had to drill a hole in the generator pulley for the pin. It worked well on a 1200/ 40 HP _________________ .ssS! |
Joe 20 Samba Member
Posted: Thu Jan 27, 2022 8:26 pm Post subject: Re: Hand crank start rope |
I'll stick to my nut/crank. Works great. _________________ "Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Feb 13, 2022 7:43 pm Post subject: Re: Hand crank start rope |
If my starter acts up I park on a 'Hill' if no hills around like at a gas station, I seek some 'youngins' to push _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Mon Feb 14, 2022 7:01 am Post subject: Re: Hand crank start rope |
madmike wrote: |
I seek some 'youngins' to push |
Why? Do you not have a wife?
Just kidding!
I have push started our Bay Bus many times, several Beetles, our Jetta TDI once and even our 944! That my friends is one of the many advantages of driving a stick! Bad starter? Poor battery? Left the lights on?
Meh!! A wee shove and away we go! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Mon Feb 14, 2022 2:48 pm Post subject: Re: Hand crank start rope |
Merv, My 'Old lady' is,,,,,,,,,,,,,,old ,she pushed buggys,bus, bugs,in her younger days _________________ 'Black Ice'Drag Buggy 'Turbo'
Zundfolge1432 Samba Member
Posted: Tue Feb 15, 2022 9:12 am Post subject: Re: Hand crank start rope |
This bus needed a push.
sb001 Samba Member
Posted: Wed Feb 16, 2022 8:20 am Post subject: Re: Hand crank start rope |
Just once, I would like to see someone push start an autostick. Friend of mine and I tried it once on a downhill slope, but never got it to work. It apparently can be done similar to the 4 speed, but you have to really get going. Haynes manual is not very clear on how exactly this works, just says "use Low gear." So I guess you shove it from neutral into Low to pop the clutch? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
oprn Samba Member
Posted: Wed Feb 16, 2022 9:10 am Post subject: Re: Hand crank start rope |
Would that work without the engine running to supply oil to the torque converter! Or is there enough oil in the converter to get some sort of limited coupling? _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
sb001 Samba Member
Posted: Wed Feb 16, 2022 9:37 am Post subject: Re: Hand crank start rope |
oprn wrote: |
Would that work without the engine running to supply oil to the torque converter! Or is there enough oil in the converter to get some sort of limited coupling? |
The torque converter retains quite a bit of ATF fluid, but I have no idea what would be required... all I know is what I read in the Haynes manual, so a friend and I decided to try it, but never got it to work. The Haynes manual is not really clear on the exact procedure, just says it can be done.
I think I'd try the pull rope trick before the clutch pop on an autostick. _________________ I'm the humblest guy on this board.
1600 SP engine
mukluk Samba Member
Posted: Wed Feb 16, 2022 3:32 pm Post subject: Re: Hand crank start rope |
For what it's worth, I never have push started an Autostick, but I did get one started by towing it. Yes, the torque converter will spin the engine up just fine without the engine running first. This particular car had its transaxle physically stuck in top gear so the starter wouldn't work (neutral safety switch wasn't bypassed), and it fired up once we got it going around 20mph. _________________ 1960 Ragtop w/Semaphores "Inga" |
