djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
DuncanS Samba Member
Posted: Wed Jan 05, 2022 10:56 am Post subject: Re: Hall Effect sensor tester |
I've gotta few that I wonder about too from way back when. But what's getting alarming is apparently there is a teenager who comes in the middle of the night to work in my shop as all sorts of stuff is disappearing. A great pair of long handle pliers, 1940 sharp tin snips, metric allen wrenches to name a few. I know getting older and memory can be an issue, but what the .... is happening? Pliers, for instance. Figured I put them in the wrong drawer. Nope, went through every one. Pulled them out and dumped them out onto the table saw and sorted through. Threw out some odd pieces of paper with measurements and dirty band-aids, but no pliers or anything else AWOL either. At least I haven't found my bag of coffee in the dryer yet, but I suppose that will happen too.
Guess you're not supposed to admit to old age failings. A little late for that on this forum, as by now all of you have figured out my Mad Hatter proclivities anyway. Here is one of the latest.
When I cut the roof out last summer, I knew I wanted to eliminate the C pillar cross member. However it was going to take some time and put the DD out of circulation for a while so now I'm doing the exploring and getting ready for the first warm month to slap in an angle iron. After a bunch of consideration, this seems like a decent solution and maybe the simplest to install. I know there are lighter weight possibilities as I don't want to add any more weight aloft than necessary, but ........ At 4 lbs per foot it will add up to about 65 pounds total, deducting for the missing cross member.. For ease of the install, I can live with that. And here's how it would fit.
I cut out the roof where the deformation ribs were as I had to have a flat where the canvas goes over the roof. The photo was taken at one of the cutouts.
I'll shut up and go away now as I ddn't want to hijack the thread. But I can relate to Dave's missing tools and equipment.
Duncan |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5919 Location: Bemidji, MN
Posted: Sun Jan 30, 2022 5:37 pm Post subject: Re: Hall Effect sensor tester |
i've a new form factor for these testers and created an information page along with an updated schematic, parts list, downloadable instruction sheet, and video on my website.
https://www.thefixitworkshop.com/home/devices
_________________ -dan
www.thefixitworkshop.com |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8523 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Jan 30, 2022 5:54 pm Post subject: Re: Hall Effect sensor tester |
Looks good! I'll take the second one from the top...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sun Jan 30, 2022 6:17 pm Post subject: Re: Hall Effect sensor tester |
| dhaavers wrote: |
- Dave |
PM'd. 3 left! _________________ -dan
bobhill8  Samba Member
Posted: Sun Jan 30, 2022 8:02 pm Post subject: Re: Hall Effect sensor tester |
I just ordered one. I spent quite a while chasing a problem last year before finally ID'ing problems with the Hall. This would have saved me a LOT of time. Thanks Dan. _________________ 1986 Westy
1971 Squareback |
Posted: Wed Apr 13, 2022 10:55 am Post subject: Re: Hall Effect sensor tester |
i've made another batch of 8 that i'll offer up first here on the Samba list and then i'll bring them to the Facebook 'VW T3 Vanagon WBX Waterboxer Wasserboxer Engines' group. unfortunately, the distributor end plug is now $15 per piece so i've had to raise my price from the last batch to cover purchasing that plug. if you look at my website, there's lots of info on how to make your own including detailed a detailed parts list, which is the route i suggest to save paying me to make you one! there's also ordering info there if you just don't want to sit down with a soldering iron. if someone can find me an inexpensive source for the plug i'll drop the price back down!
1988M5 Samba Member
Joined: January 23, 2016 Posts: 852 Location: Tucson, AZ
jlrftype7 Samba Member
Posted: Wed Apr 13, 2022 1:00 pm Post subject: Re: Hall Effect sensor tester |
| DanHoug wrote: |
email sent Dan....  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Vana Guy Samba Member
Posted: Thu Apr 14, 2022 7:50 am Post subject: Re: Hall Effect sensor tester |
Dan, add a plug for jumpers to connect to the vehicle 12volt system, for on-the-road testing. A 9 volt battery may be dead when needed!
Wait, I got it...
Add a plug for powering from 12 volt system, or for plugging into wire harness to test for power to hall sensor. |
Posted: Thu Apr 14, 2022 8:14 am Post subject: Re: Hall Effect sensor tester |
i send these out with a fresh Ray O Vac battery... 5 year shelf life. with the tester unplugged, there is no complete circuit to the battery, meaning zero quiescent current draw.
being self-powered, they are handy for sorting thru distributors in your stash... no add'l power needed!
but i get your point. however, just lick the battery if you think it is dead. get a tingle, it's good. _________________ -dan
bridgetroll13 Samba Member
Joined: December 21, 2006 Posts: 179 Location: St. Georges, Delaware
Posted: Thu Apr 14, 2022 10:17 am Post subject: Re: Hall Effect sensor tester |
okay, this is promising and thank you for the lead!! i've contacted Dave, the site owner, to see if he has stock. if so, i'll immediately drop my price $10 (and refund jlrftype7!!). standby! _________________ -dan
floodwood Samba Member
Joined: October 22, 2017 Posts: 187 Location: Cambridge, MA
Posted: Thu Apr 14, 2022 11:05 am Post subject: Re: Hall Effect sensor tester |
I have an economics question.
This tester is $85, and a new distributor runs about $79.95 at gowesty, and $99.95 at vancafe.
While I understand it is good to have diagnostic tools, would it not make more economic sense to simply purchase a new distributor/hall sensor rather than paying for an expensive tool to test then ultimately pay to fix/overhaul an old aged one? |
Posted: Thu Apr 14, 2022 11:36 am Post subject: Re: Hall Effect sensor tester |
| floodwood wrote: |
that's a great question! i carry this as a troubleshooting tool so that i can definitively and really quickly rule out the distributor as a 'no start' problem. to me, that is much preferable to pulling the distributor at the side of the road, installing a new $80 one, and either carrying a timing light or guessing on the timing to try to start the engine. THAT is the utility... snap it on, test distributor, look elsewhere if good. i hate the crapshoot shotgun parts replacement method of diagnosing.
i've given the parts list and schematic to build your own at far lower cost, which narrows the equation because you don't pay for $9.45 shipping and an hour of my time. i offer this for those that just don't want to build one. for me, that's expensive but for some, it isn't expensive or is worth saving the futzing around building one. but i'll always defend the utility of quickly knowing whether your sensor is good or not! _________________ -dan
Posted: Fri Apr 15, 2022 7:47 am Post subject: Re: Hall Effect sensor tester |
Dave Barton confirmed that he has those distributor plugs for $6 so i'm dropping the price to a more reasonable $75.
thanks to bridgetroll13 for saving y'all $10!! _________________ -dan
Posted: Fri Apr 15, 2022 11:23 am Post subject: Re: Hall Effect sensor tester |
Glad to contribute!
Erik |
Posted: Fri Apr 15, 2022 12:02 pm Post subject: Re: Hall Effect sensor tester |
| floodwood wrote: |
Small problem with that line of thought, the above ^^ units are only for the 2.1 wbx and are stated not to fit a 1.9 wbx. Durn, once again we 1.9'ers are left out in the cold...  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Fri Apr 15, 2022 1:27 pm Post subject: Re: Hall Effect sensor tester |
| jlrftype7 wrote: |
| floodwood wrote: |
Small problem with that line of thought, the above ^^ units are only for the 2.1 wbx and are stated not to fit a 1.9 wbx. Durn, once again we 1.9'ers are left out in the cold...  |
this development is bothering me as i assumed the 1.9 and 2.1 used the same Hall plug and receptacle. i've looked at photos online and it appears the 1.9 dist end is more rounded. standby!! more research being done. _________________ -dan
Posted: Fri Apr 15, 2022 1:51 pm Post subject: Re: Hall Effect sensor tester |
| DanHoug wrote: |
| jlrftype7 wrote: |
| floodwood wrote: |
this development is bothering me as i assumed the 1.9 and 2.1 used the same Hall plug and receptacle. i've looked at photos online and it appears the 1.9 dist end is more rounded. standby!! more research being done. |
I'll let you know when my Tester arrives- At worst, it means changing out the connector for the Distributor if it doesn't fit exactly. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
