Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Thu May 12, 2022 11:06 am Post subject: Re: Sudden really bad misfire - I'm running out of ideas now! |
for the carb linkage - did you look at the "look listen do it better" docs here? there are specific measurements for the linkage that will greatly help |
veedweeb Samba Member
Joined: May 23, 2018 Posts: 150 Location: Greater Manchester UK
Posted: Thu May 12, 2022 11:11 am Post subject: Re: Sudden really bad misfire - I'm running out of ideas now! |
Erik G wrote: |
I've used that in the past on my other cars, but this one has a pair of Weber ICTs and the linkage is completely different to stock. _________________ 1963 Turbo WBX Bug
2000 Sedan Clasico Mexican Bug
1972 Type 3 Squareback |
vwfye Samba Member
Posted: Thu May 12, 2022 11:15 am Post subject: Re: Sudden really bad misfire - I'm running out of ideas now! |
Principle is still the same. Tune each carb without crossbar, then balance. _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu May 12, 2022 3:25 pm Post subject: Re: Sudden really bad misfire - I'm running out of ideas now! |
There's a small ground strap inside the distributor that grounds the moving top plate that the points ride on to the body of the distributor. If this little bastard is open somewhere it can cause ALL sorts of issues. Move it around, don't just look at it. It can make contact and then break contact as the breaker plate moves under the influence of vacuum. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Fri May 13, 2022 12:53 am Post subject: Re: Sudden really bad misfire - I'm running out of ideas now! |
vwfye wrote: |
Principle is still the same. Tune each carb without crossbar, then balance. |
That's what I did the other night and it starts and idles perfectly and the carbs are really well belanaced, both at idle and at higher RPMs too.
But now I've bought a pair of correct manifolds (I made another thread about the engine height and I discuss the manifolds there) and they put the carbs in a slightly different location which means I'm going to have adjust the linkage all over again! _________________ 1963 Turbo WBX Bug
Posted: Fri May 13, 2022 12:56 am Post subject: Re: Sudden really bad misfire - I'm running out of ideas now! |
Tram wrote: |
There's a small ground strap inside the distributor that grounds the moving top plate that the points ride on to the body of the distributor. If this little bastard is open somewhere it can cause ALL sorts of issues. Move it around, don't just look at it. It can make contact and then break contact as the breaker plate moves under the influence of vacuum. |
Oooh! That sounds like something that's definitely worth checking out. Right from the start I thought it was an ignition problem, but I thought I'd ruled out the entire ignition system.
It starts and idles perfectly, but under any load or throttle at all, it misses really badly. What you're describing would definitely match the symptoms. Thanks _________________ 1963 Turbo WBX Bug
Bobnotch Samba Member
Posted: Fri May 13, 2022 11:24 am Post subject: Re: Sudden really bad misfire - I'm running out of ideas now! |
veedweeb wrote: |
vwfye wrote: |
But now I've bought a pair of correct manifolds (I made another thread about the engine height and I discuss the manifolds there) and they put the carbs in a slightly different location which means I'm going to have adjust the linkage all over again! |
You shouldn't have to. About all you need to do is lengthen the pivots to make up the difference in the cross bar. Then it's back to fine tuning the heim joints to get the correct length and balance. That's all I do when I swap my carbs from one engine to another. It's also what I like about running carbs, they pretty much stay set, once dialed in. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon May 23, 2022 1:04 am Post subject: Re: Sudden really bad misfire - I'm running out of ideas now! |
Okay, so this is still ongoing but I'm making progress.
It's taking a while because I don't need to use the car and it's not really a priority to fix it, plus I've got my '63 Bug that needs attention as well.
Anyway, I swapped the manifolds and sorted out the balance pipe. The linkage needed modifying too because the carbs are now almost 2" further apart.
Whilst I was doing it, I discovered a bad fuel leak from the LH carb accelerator pump so I took the carb off to sort that. It definitely wasn't leaking before - I would have noticed because I'm absolutely paranoid about fuel leaks.
When I had the carb apart I took the top off to check it over and found a bit of debris blocking the jet so I cleaned that and checked the others in both carbs.
So it's starting to look like that was the issue all along. The trouble is, I now need to go through the carb setup and balancing procedure all over again. No biggie really but I ran out of time this weekend so it'll have to wait for another day. _________________ 1963 Turbo WBX Bug
Posted: Wed Jun 22, 2022 3:16 am Post subject: Re: Sudden really bad misfire - I'm running out of ideas now! |
Fixed it!
Just to recap - the misfire gave all the symptoms of a bad condenser so because the rest of the ignition system was unknown as well, I changed everything: Points, coil, rotor and cap, HT leads, condenser and spark plugs. Then I checked the timing and made sure the valve clearances were all OK.
Next up was a suspected vacuum leak and I didn't like the way the balance pipe was set up, plus I found a vacuum leak on the distributor can on the retard side.
It was at this point that I realised it had stock inlet manifolds with the ICTs on top of them which explains why the air filter was crushed against the underside of the boot floor.
A pair of new manifolds solved a few problems - they're shorter for more air filter clearance, they have a simpler arrangement for the balance tube and they don't have the vacuum take off for the distributor retard. The downside is that they also push the carbs farther apart so I had to rethink the throttle linkage. Luckily the plates that mount on the carbs can be fitted in 2 positions so it was just a case of relocating them.
It was at this point that I discovered some crap blocking a jet in the LHS carb so I stripped them both and cleaned them out.
Then I put it all back to together and went through the whole set up and balancing procedure from scratch and it's running better than ever now!
The combination of a completely new ignition system, along with zero vacuum leaks and properly balanced carbs has done the trick. It will now pull away from standstill in 3rd gear with no problems. It couldn't even do it in 1st before!
Thanks for the input, everyone. I got there in the end! _________________ 1963 Turbo WBX Bug
Posted: Wed Jun 22, 2022 12:20 pm Post subject: Re: Sudden really bad misfire - I'm running out of ideas now! |
Congrats with sticking with it until all of the little fixes came together and fixed it. Good work. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
