dublife13 Samba Member
Joined: March 08, 2021 Posts: 84 Location: washington
Posted: Sun May 15, 2022 2:14 pm Post subject: Looking for a lower height shift lever, not a short throw kit. |
I would like to lower the physical height of my shift level between 2/3". Is there a company out there that offers short length levers?
Basically I want to run a CarPlay head unit and my current shifter just hits the bottom of the screen. Maybe the shifter is out of alignment and shouldn't throw that far? I dont know its a new to me Vanagon. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6357 Location: Honolulu,Hawaii and France
Posted: Sun May 15, 2022 2:23 pm Post subject: Re: Looking for a lower height shift lever, not a short throw kit. |
You can adjust the depth of the shifter splines under the van to cheat a bit. Get them out more. Or cut you shifter and reweld the threaded portion lower. YOu might be even able to rethread it once cut... _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Sun May 15, 2022 2:27 pm Post subject: Re: Looking for a lower height shift lever, not a short throw kit. |
Thanks for the thoughts. I was thinking about cutting and glueing a knob on till I get a better solution. Im guessing my linkage is a bit out and my shift lever is also bent and should be replaced soonish. |
Posted: Mon May 16, 2022 10:26 am Post subject: Re: Looking for a lower height shift lever, not a short throw kit. |
Just heat it up and put a bit more of a backwards bend it it. |
