LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5505 Location: 1st Coast
Posted: Thu Jan 06, 2022 7:03 pm Post subject: Delran Battery Tender Junior 12V 750 mA stopped working |
My Delran Battery Tender Junior 12V 750 mA stopped working on my 12 volt Interstate battery for my 67 Westy. Oddly I have another Battery Tender Junior 12V 750 mA on my small British car also and that has stopped working at the same time or within 3 months of each other.
I have not received a reply from the manufacture and I'm not sure of the age, perhaps 3-5 years old or more on new Interstate batteries. The batteries test at 12.5 volts although the tenders are dead.
Am I using the correct type/size/model battery tender? Should I buy a different brand? Or the same?
Thanks, Linda
https://www.batterystuff.com/battery-chargers/12-v...tnEALw_wcB _________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3435 Location: San Diego
Posted: Thu Jan 06, 2022 8:21 pm Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
Are you sure you have good clean connections? |
Posted: Fri Jan 07, 2022 2:39 am Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
Yes oddly super clean. The terminals look like the day I bought the batteries. I had put a very thin layer of dielectric grease on th terminals when I bought them. I also checked the fuse in the tender and they are good. I also have a Yuasa Smart Shot 900mA Battery Charger Maintainer on my motorcycle battery and that works fine. Perhaps I should just buy 2 more of those? I would have thought the Dellran would have blown the fuse before they stopped functioning.
https://www.countrycat.com/supercede/arctic-cat-46...maintainer
chrisflstf wrote: |
Maui Roadsters
Lind wrote: |
Slip356 Samba Member
Posted: Fri Jan 07, 2022 10:59 am Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
Linda,
I have multiple Deltran battery tenders. One died a few years ago, I contacted them and they sent me a new one. I couldn’t remember how old the dead one was, they didn’t seem to care back then.
Great customer service, hope they treat you as well. I know some of mine are over 10 yrs old and still working great.
Slip |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14253 Location: Casa de Oro, California
Posted: Fri Jan 07, 2022 7:00 pm Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
Those tenders are not meant for a battery the size you are hooking them to in your cars in my opinion.
The problem is they see the larger battery never fill up and keep running on full charge which could burn them out. |
Posted: Sat Jan 08, 2022 8:16 am Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
Linda,
I should have mentioned, all of my tenders are the full size ones, not the junior ones. Also have a double two battery one for my Westy with two batteries, that is at least 10 yrs old and works perfect. Hope you get good customer service from Deltron.
Slip |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Jan 08, 2022 9:57 am Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
I had a Junior burn itself out after several years on an ATV battery- it's "charging" light started flickering.
I also have one of the old 6v BTs that kept my '63 bug on charge for 10 years before it bought the farm.
I'm trying a Schumacher (sp) brand switchable maintainer on my diesel tractor right now and it seems to be great. I may switch to a multi-bank charger and build myself a battery maintenance cart for the fleet in the barn- a one-stop acid shop. _________________
EverettB wrote: |
FU#5 |
Posted: Sun Jan 09, 2022 8:02 am Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
Very interesting BarryL so my battery never received a full charge? What unit are you using for your batteries for the 12 volt system?
BarryL wrote: |
Slip356 are you using the Deltran Tender Plus? I wanted to buy it but they have never replied to my emails (2) or returned my phone calls leaving me to think they are not worthy of 2 more units. I have searched for reviews and trust Consumer Reports but I couldn't find their reviews on battery tenders.
Most searches for reviews on battery tenders are sales related.
Slip356 wrote: |
Linda,
Slip |
Maui Roadsters
Lind wrote: |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Sun Jan 09, 2022 10:08 am Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
I have two Diehard battery "maintainers" and two Schumacher battery "maintainers" and all seem to be working great. I like that the Diehard and Schumacher units detect either 6 or 12 volt systems and then automatically switch to charge/maintain 6 or 12 volt batteries. Reasonable too at about $26 each. I also have a couple of HF mini size very basic feature and very cheap (at $6 each) trickle chargers but I don't really trust 'em. They might work fine but I'm not currently using those. I own four VWs that are 6 volt, and four that are 12 volt. I also have a nearly 20 year old normal 10 amp and 6V / 12 V Schumacher battery charger for quicker charging (not maintaining).
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
BarryL Samba Member
Posted: Sun Jan 09, 2022 6:48 pm Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
LAGrunthaner wrote: |
Very interesting BarryL so my battery never received a full charge? What unit are you using for your batteries for the 12 volt system? |
You need more amps than the one you have. I use this one but there are a multitude of charger/maintainers these days.
Schumacher SP1297 3A 6V/12V Automatic Battery Maintainer |
Posted: Mon Jan 10, 2022 4:10 am Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
That is exactly the information I was looking for and forgot to ask, my amps of 0.75 were too low. Thanks BarryL.
If my local shop doesn't have these or similar 3A maintainers I'll go Amazon and order 2 of these Schumacher-SP1297 models. I try my best to keep local shops in business. Huge difference in price NAPA brand vs Schumacher-SP1297 vs Diehard.
NAPA Brand 3A maintainer @ $24.50
https://www.napaonline.com/en/p/BK_HFMC3A?impressionRank=2
Schumacher-SP1297 3A via Amazon @ $50.00:
https://www.amazon.com/Schumacher-SP1297-Automatic...NrPXRydWU=
DieHard Smart Charger Automatic 12 V 3 amps Battery Charger/Maintainer via ACE Hardware @ $110.00
https://www.acehardware.com/departments/automotive...c-shopping
BarryL wrote: |
Thanks Bill for the direction.
BulliBill wrote: |
Bill |
Maui Roadsters
Lind wrote: |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Jan 10, 2022 11:10 am Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
BarryL wrote: |
BulliBill wrote: |
Bill |
Yep! They have gone up in price over the last couple of years...
I did a quick look at my maintainers down in the garage and the models that I own/use are:
Schumacher SC1319 fully automatic microprocessor controlled 6 volt or 12 volt battery charger and maintainer.
features: 1.5 amp maintainer, voltage detection, float mode, reverse hook-up prevention
bought back in 2018 for $24.98 and currently on Amazon costs $38.20
(NOTE: the above units are also available in 2 amp and 3 amp models for a few more $s...
Diehard 28.71219 smart 6 volt or 12 volt battery charger and maintainer
This has reverse hook-up prevention (a warning light fleshes and the unit will not charge until polarity is corrected). does not have "automatic" switching between 6 or 12 volt. You select either 6 or 12 volt with a switch on the case face.
6 volt charging rate: 4 amps
12 volt charging rate: 2 amps
current cost on Amazon is $48.29 and I think a few years back they cost me around $27.
I like them both, they work great, but I suppose that if I were forced to decide between them, I guess I'd go for the Schumacher maintainers...
Go ahead, talk amongst yourselves!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
BarryL Samba Member
Posted: Mon Jan 10, 2022 6:51 pm Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
...Thanks BarryL.
If my local shop doesn't have these or similar 3A maintainers I'll go Amazon and order 2 of these Schumacher-SP1297 models. |
Oh great...I get the blame.
Sheesh. |
Posted: Tue Jan 11, 2022 6:39 am Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
Yup BarryL, and I ordered 2. The Schumacher-SP1297 model seems to be the winner for me. I ordered them from Lowes. I think I'm going to like this model as it has a display giving me the info I want to see. And if I ever get a 6 volt bus I'll have a charger for it too. One can dream.
BarryL wrote: |
...Thanks BarryL.
Sheesh. |
Maui Roadsters
Lind wrote: |
BarryL Samba Member
Posted: Tue May 17, 2022 6:15 pm Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
You never told if it worked for you. |
Posted: Wed May 18, 2022 3:57 am Post subject: Re: Delran Battery Tender Junior 12V 750 mA stopped working |
Yes BarryL the new chargers worked great, I wish I knew why the other 2 failed. Although I have an idea which I'll share later. Off to school.
Thank you kindly,
Linda
BarryL wrote: |
Maui Roadsters
Lind wrote: |
