AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Sat May 07, 2022 6:51 am Post subject: Jogoswall Fire Extinguisher - Anyone with personal experience? |
Hi, does anyone have any experience with Jogoswall Extinguisher?
Not looking for alternatives, just looking to see if someone has experience with that particular device.
Thanks. |
kingkarmann Samba Member
Posted: Sat May 07, 2022 2:07 pm Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
I hadn't heard of these so I looked them up.
Interesting and compact. I wonder if it Uses Halon?
It's certainly better that no fire protection.
https://www.amazon.com/vdp/0473e8c606a54aa5a98cb9d0e6e19bff?ref=dp_vse_ibvc0 _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Posted: Mon May 09, 2022 6:08 pm Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
Well, I got it today. It is tiny, but so is my engine bay. I still will keep a regular extinguisher in the car and hopefully will never be in a car fire. It is UL listed etc. and has other industry certifications so I am hoping it will work as advertised if the car ever catches fire.
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Mon May 16, 2022 11:48 am Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
I ordered one too. I'm going to put it on the Ghia. It's hard to say how well it will work unless you actually have a fire, and I don't plan on that.
I'll probably order a couple more and put in the bus too. _________________ -Andy-
-1970 Ghia-
-1971 Bus 1776 Microsquirt EFI- |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Tue May 17, 2022 11:10 am Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
I wonder if it would be beneficial to mount high up in the engine compartment. Heat and flames rise. _________________ Jack Staggs
Actual name |
Posted: Tue May 17, 2022 1:42 pm Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
This thing produces gas to choke out the fire. I have it mounted low so that it can fill the engine compartment from the bottom up when it goes off. The air intake grill is on top. Eventually the gas will escape from the top but hopefully after it has choked out the fire as it travels from the bottom to the top. |
Posted: Tue May 17, 2022 7:31 pm Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
My concern is that the extinguisher propels out the side. At least with the BlazeCut, when the flame hits the tube, the propellant shoots downward, where the flame is. If this is mounted above the engine and the flame tickles it, will the propellant just shoot out the side and miss the flame? So lets mount it on the side somewhere, pointing at the engine. Well then does the whole engine compartment need to be engulfed before the Jogoswall reaches 170C ?
I'd love to buy a bunch and test out different locations and scenarios. But I don't have a spare junk ACVW to try this out on. _________________ -Andy-
-1970 Ghia-
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Wed May 18, 2022 11:12 am Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
my worry is that if you are at speed the incoming air and remaining heat will reignite the fire that was initially extinguished. Hard to test that without towing a car on fire... no thanks |
Jacks Samba Member
Posted: Wed May 18, 2022 7:07 pm Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
My guess is that the extinguisher is heat activated. Placing it low could mean that the fire may need to burn longer before the retardant is released. I have seen many burnt engines that have zero damage in lower engine compartment spaces. _________________ Jack Staggs
Actual name |
wagohn Samba Member
Joined: June 24, 2014 Posts: 740 Location: United States
Posted: Sat Jun 04, 2022 6:31 pm Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
AirHead1966 wrote: |
Any update on this? We ordered one. Any worries about the beetles engine heat setting it off ? I see it sets off at 170c.
Thanks! _________________ 1976 VW Transporter, 2.0 FI Engine |
Posted: Sat Jun 04, 2022 7:56 pm Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
I have been driving with this installed. No issues at all with it going off with engine heat. |
wagohn Samba Member
Posted: Sat Jun 04, 2022 8:01 pm Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
Thank you. _________________ 1976 VW Transporter, 2.0 FI Engine |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1477 Location: Westfield, MA.
Posted: Tue Jun 14, 2022 12:23 pm Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
blue72beetle wrote: |
I'd love to buy a bunch and test out different locations and scenarios. But I don't have a spare junk ACVW to try this out on. |
It has nothing to do with the flame, it has to do with the ignition source..oxygen etc. It's why you shoot a fire extinguisher at the base of the fire...not the flame. Saw this several times when on the fire department. It's something that doesn't get taught much anymore..but is super important especially if you have the need for using an extinguisher! |
wagohn Samba Member
Posted: Sun Jun 19, 2022 3:31 pm Post subject: Re: Jogoswall Fire Extinguisher - Anyone with personal experience? |
Installed on our Bay. Mounted it on the spare wheel housing. Let's see if it stays there with a little heat
