FunkyOldPatina Samba Member
Joined: October 13, 2012 Posts: 200 Location: Sunny UK!
Posted: Thu May 19, 2022 1:35 am Post subject: "Hella 11" rubber seal for split bus? |
Hi all,
Been trying to work out what this is for?
It's not quite round, it's 9cm x 9.5cm.
Any help gratefully received.
Tizian Samba Member
Joined: February 18, 2015 Posts: 383 Location: Hamburg, Germany
Posted: Thu May 19, 2022 3:37 am Post subject: Re: "Hella 11" rubber seal for split bus? |
Ghia turnsignal gasket? _________________ 02/24/2022
The saddest day in recent history. My thoughts are with all those people suffering from the aggression of only one individual. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Thu May 19, 2022 10:09 am Post subject: Re: "Hella 11" rubber seal for split bus? |
Looks too round for front turn signal. Those would have a grommet built into them if memory serves correctly. Might be for the rear side fender reflectors for 1968-69 Ghia. The "11" is most likely the mold number, as in the 11th of 12 or more molds to be used during production. Having a number meant it was easy to ID which mold was too worn or damaged and needed repair or replacement when seals were inspected. _________________ In Stereo, Where Available! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Thu May 19, 2022 12:00 pm Post subject: Re: "Hella 11" rubber seal for split bus? |
I'm going with a seal for the back of a horn. The 2 largers holes are for the mounting, the 2 smaller holes for the wire connections and the hole in the center for tone adjustment. _________________ Never argue with an Idiot. They'll only bring you down to their level and beat you with experience. |
Posted: Fri May 20, 2022 12:29 am Post subject: Re: "Hella 11" rubber seal for split bus? |
Hi all, thanks for your thoughts.
I will post it up in the Ghia section and see if I have any luck there.
It's one of those parts that looks so familiar but when you really start looking at it isn't
Every day is a learning day! |
Tizian Samba Member
Posted: Fri May 20, 2022 4:02 am Post subject: Re: "Hella 11" rubber seal for split bus? |
59-63 Ghia turn signal _________________ 02/24/2022
Posted: Fri May 20, 2022 6:02 am Post subject: Re: "Hella 11" rubber seal for split bus? |
^ That's great, thank you very much for ID'ing for me! |
