EarlyLoaf Samba Member
Joined: October 26, 2021 Posts: 34 Location: Southern Oregon
Posted: Sun Apr 03, 2022 6:30 pm Post subject: Seeking advice: Bay Bus suspension and undercarriage |
Hey all, looking for suggestions on cleaning up/paining the suspension and underneath on my 68 bus. What’s the best way to get rid of the dirt, oil, grime, rust, etc? Does it come down to some good old fashioned manual labor? I’ve started with purple power, and a wire brush lol. I’ll probably bead blast and paint the bearing housings and brake backings since they’re out anyway. I was thinking about using POR15. Let me know what you all think!
_________________ "No description available for special paint jobs"
Check out my project!
https://www.thesamba.com/vw/forum/viewtopic.php?t=766509&highlight= |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Apr 04, 2022 8:50 am Post subject: Re: Seeking advice: Bay Bus suspension and undercarriage |
www.MasterSeriesct.com silver & black is better than POR15. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
bomberbob Samba Member
Posted: Mon Apr 04, 2022 12:52 pm Post subject: Re: Seeking advice: Bay Bus suspension and undercarriage |
I have used several quarts of the master series silver, and I like it. Inside and outside doors, I put that stuff on everything.
I have started experimenting with another brand of a similar material, it might be a close match. KBS coating Rust seal, and their frame coating kit. I am using the KBS material on the Jetta that is now consuming all of my spare time. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1963 Location: Manitowoc, WI
Posted: Mon Apr 04, 2022 5:44 pm Post subject: Re: Seeking advice: Bay Bus suspension and undercarriage |
Ceckert64 wrote: |
Maybe a high pressure power washer? |
That's what I'm thinking. On my project post, someone recommend soak it with Super Clean and then hit it with the pressure washer. Only problem is it's immobile in the garage haha. I'll probably build a curtain and a trough-like system with plastic and hope for the best! _________________ "No description available for special paint jobs"
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Thu May 19, 2022 12:51 pm Post subject: Re: Seeking advice: Bay Bus suspension and undercarriage |
OP, have you blasted the bearing housings yet? I was wondering how you protected the insides of the housings during the blasting process. Just curious because I am considering doing the same since my Bus needs new spring bushings and it’s all coming off anyway. Thanks and good luck. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
Posted: Fri May 20, 2022 9:47 am Post subject: Re: Seeking advice: Bay Bus suspension and undercarriage |
oscarsnapkin wrote: |
OP, have you blasted the bearing housings yet? I was wondering how you protected the insides of the housings during the blasting process. Just curious because I am considering doing the same since my Bus needs new spring bushings and it’s all coming off anyway. Thanks and good luck. |
Yes, I blasted them! I stuffed rags into the holes and was just really careful around the area. worked great! _________________ "No description available for special paint jobs"
c21darrel Samba Member
Posted: Mon May 30, 2022 11:58 am Post subject: Re: Seeking advice: Bay Bus suspension and undercarriage |
My bad, I forgot another thing I did was I put the old seals in the housing along with the rags to protect the inside before blasting! _________________ "No description available for special paint jobs"
