CaptLou87 Samba Member
Posted: Sat May 21, 2022 1:19 pm Post subject: Newbie rust repair |
Hi. I apologize for asking but I’m in a bit over my head having never done any body repair before. I had a rusty panel on my Vanagon along the side bumper cap that I attacked using a wire wheel angle grinder. Cutting out the metal was not an option.
I also attacked it from the other side of the seem as well after removing the undercoating. Applied Ospho, sanded and thought I was ready for the next step.
I have Por15 but seems like more people suggest expoxy primer instead.
Picked up a rattle can from napa of one of those 2 chamber DTM epoxy primers
https://www.napaonline.com/en/p/MS_7300
but I have a lot of questions.
Should I use jb weld or some other filler next?
Should I use the por15 or napa expoxy primer first and then jb weld? Or return it and use some other primer?
If expoxy goes first, let it cure completely and then apply filler? Would then need to scuff/sand to apply base coat paint color and clear coat?
I would love some help with the next steps on the easiest way to handle this.
Thanks much. |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sat May 21, 2022 7:42 pm Post subject: Re: Newbie rust repair |
You'll get different answers on this.
In the past people would apply filler direct to metal then paint. But today the go-to method is to epoxy prime the area (to prevent further rusting) then fill.
By protecting the metal first, you don't get the potential of rusting underneath.
On my car I did epoxy first. Then scuffed it up with the recommended grit sandpaper and filled it. Then paint.
Of course you don't have to fill straight away. It can sit for a long time as the epoxy will protect it.
Now wait for the counter views. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sun May 22, 2022 6:29 pm Post subject: Re: Newbie rust repair |
Agree with Viking. Just be 100% certain that ALL the rust is neutralized, before spraying the epoxy primer onto the metal. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Mon May 23, 2022 4:18 am Post subject: Re: Newbie rust repair |
search "all metal" filler. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Mon May 23, 2022 4:26 am Post subject: Re: Newbie rust repair |
viiking wrote: |
Now wait for the counter views. |
Agreed _________________ modok wrote:
bomberbob Samba Member
Posted: Mon May 23, 2022 6:25 am Post subject: Re: Newbie rust repair |
I don't use 2 part pink filler any more. Its porous, and it isn't very strong. I have started using 3M panel adhesive (epoxy) to fill in pits and imperfections. Metal needs to be bare. 24 hour cure, then sand.
Just an option, these epoxies did not exist back when bondo was invented. JB weld may also stick well. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Braukuche Samba Member
Posted: Sun May 29, 2022 11:15 pm Post subject: Re: Newbie rust repair |
I’d use short kitty hair filler. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
