1994 Eurovan head gasket failed
Forum Index -> Eurovan Share: Facebook Twitter
gkid
gkid is offline
PostPosted: Sat May 14, 2022 2:05 pm    Post subject: 1994 Eurovan head gasket failed Reply with quote
Just bought a 1994 Eurovan 2.5L 5 speed camper van that needs a head gasket, going to attempt to do the job myself. Just checking to see if there are any tips out there, no manual as yes but have a timing belt book/manual to start. The van has 321,500 km
Abscate
Abscate is offline
PostPosted: Sun May 15, 2022 1:09 am    Post subject: Re: 1994 Eurovan head gasket failed Reply with quote
Haynes manual would be a good friend here
.ssS!
subdewd
subdewd is offline
PostPosted: Sun May 15, 2022 5:10 am    Post subject: Re: 1994 Eurovan head gasket failed Reply with quote
Pretty straightforward
gkid
gkid is offline
PostPosted: Sat May 21, 2022 3:29 pm    Post subject: Re: 1994 Eurovan head gasket failed Reply with quote
Can any one help with cylinder head torque procedure, all I can find is 30 lb/ft first stage, 40 lb/ft second stage then 90 deg then another 90 deg, this is a 94 with a 2.5L AAF engine, is this correct
BatesEV
BatesEV is offline
PostPosted: Sat May 21, 2022 7:41 pm    Post subject: Re: 1994 Eurovan head gasket failed Reply with quote
On the just-T4 downloads. It has a Hanes manual and it says 40nm, 60nm, +90, +90
gkid
gkid is offline
PostPosted: Sun May 22, 2022 7:50 am    Post subject: Re: 1994 Eurovan head gasket failed Reply with quote
Thank you for you help
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
