mkparker Samba Member
Joined: October 12, 2004 Posts: 332 Location: Sherman, Tx
Posted: Sat Nov 15, 2014 7:35 am Post subject: |
What size tires did you end up with subgraphic? They look fantastic! _________________ Michael
Pit Boy 6163 Spec Trophy Truck |
subgraphic Samba Member
Joined: January 02, 2004 Posts: 141 Location: San Diego, CA
Posted: Tue Nov 18, 2014 8:16 pm Post subject: |
mkparker wrote: |
What size tires did you end up with subgraphic? They look fantastic! |
Thanks!
I ended up taking luckystiff's advice and going with 165/60/15 for the front and 195/65/15 on the back. I'm glad I did, I love the way they look. I have a little bit of room in the rear so I might add a spacer to get closer to the lip, but I didn't want to chance it with a wider tire.
twoodson Samba Member
Posted: Mon Dec 01, 2014 1:52 pm Post subject: |
subgraphic or quickbms - can either of you guys tell me if the wheel is too wide to fit in the spare tire area of the car? My car is a 1970 Type 1 Std. Thanks a bunch! |
Posted: Mon Dec 01, 2014 10:18 pm Post subject: |
twoodson wrote: |
Sorry man, they are bolted on the car and won't be coming off for a while. I didn't try to put it in there before they were installed.
Good luck |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Dec 02, 2014 6:52 am Post subject: |
Usually a 4.5 will fit in the spare tire slot with a low profile tire.
A 5.5 is a squeeze.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sun Dec 07, 2014 7:46 pm Post subject: |
subgraphic: thanks for response
Volkswagnut: thanks for the information
I ordered 5 of them and will pick them up tomorrow so I will find out once i get the home to see what happens. I will see if the wheel itself will fit in the spare tire area and then will probable have to install a 135 or 145 tire on the wheel. Again thanks |
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Mon Dec 08, 2014 5:43 pm Post subject: |
a stock 165r15 fits in the spare area. 165mm =6.5". a 5.5" wide wheel measures 6.5" outside lip to outside lip...... so stick with a tire 165mm wide or LESS and it should fit in the spare spot just fine.........
wanna be a little more sure? put a 145/65/15 on that 5.5" and it will stretch and will surely fit........ _________________ ITMC
Secret Service |
Posted: Mon Dec 08, 2014 6:37 pm Post subject: |
Eh.. a 165/15 on a stock 4 and an aftermarket 4.5 is snug under the hood of an undamaged pre 68 Beetle, and some even have to let air out to make it fit well as its a smigge bigger than the stock 5.60-15 bias tire size.
A 145/15 and 155/15 fit well.
Using a 5.5 wheel makes things snugger, but can be used with the right tire combo.
rastaguam Samba Member
Joined: September 11, 2008 Posts: 45 Location: Port Orchard,WA
Posted: Mon Dec 08, 2014 11:05 pm Post subject: Here's my 1960 DC running 17's. Fit like a glove!!! |
57HotrodVW Samba Member
Joined: March 08, 2004 Posts: 85 Location: Fort Worth, TX
Posted: Sun Sep 24, 2017 8:28 am Post subject: Re: Here's my 1960 DC running 17's. Fit like a glove!!! |
Nice!
Are these the "sand brushed" or "gun metal" finish?
Some of the pics of the CIP wheels I've seen look darker, and some look lighter. I don't want a super light or super dark gray, but a shade in between.
In the pics of your bus here, they look like what I want.
Also, has anyone been able to compare the Speed Master wheels directly to the CIP wheels? I'm interesting I'm knowing about the quality, finish, and weight of one versus the other. _________________ Ellis Engineering
Speedshots Motorsports Photography |
Quickbms Samba Member
Posted: Sun Sep 24, 2017 2:29 pm Post subject: Re: Speedmaster copy = SS Super Speed wheel |
I painted mine for some bling. |
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Mon Jun 24, 2019 10:17 pm Post subject: Re: Speedmaster copy = SS Super Speed wheel |
5x130 powdercoated bronze
_________________ Justin |
vwfye Samba Member
Posted: Fri May 20, 2022 11:26 am Post subject: Re: Speedmaster copy = SS Super Speed wheel |
They come in 4 lug as well .
175/55/15 front and 23.5x8.5 M&H rear
_________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3"
Mike-O-Rama Banned
Joined: August 12, 2019 Posts: 37 Location: Roseville CA
Posted: Sat May 21, 2022 4:42 pm Post subject: Re: Speedmaster copy = SS Super Speed wheel |
Just picked up a set from CIP for my 69
15x5.5 all around
+25 offset , 4.23 inch backspace all around
205/65/15 Rear Tires
175/65/15 Front Tires
2" Narrowed beam with drop spindles and air shocks in the front
EMPI disc brakes front and rear, no wheel spacers needed
https://www2.cip1.com/c32-ss4130-5515-sb/ |
torchwerks Samba Member
Posted: Tue Nov 08, 2022 2:25 pm Post subject: Re: Speedmaster copy = SS Super Speed wheel |
From the CIP site, you only get a head on view.
Can these be widened?
I think they might look pretty good on my buggy, maybe 8 inches wide.
I'd want a 275/60/15 on it. |
bonzai272 Samba Member
Joined: January 20, 2006 Posts: 237 Location: NorCal (East Bay)
Posted: Fri Dec 15, 2023 2:10 pm Post subject: Re: Speedmaster copy = SS Super Speed wheel |
Just put these from CIP1 on my Oval recently. Love them.
_________________ 1955 Beetle |
