Bluerodent Samba Member
Posted: Sat May 21, 2022 9:52 am Post subject: 1965 front wheel cylinder seals |
I have a leaky front wheel cylinder on my 1965 Square. While I am in there, it's probably worthwhile to rebuild both cylinders, and maybe even the left and right sides. The problem, of course, it getting new seals. However, I see that 22.2mm seals are readily available for certain Fiat and Mercedes models. In the pictures, the seals look the same/similar to the VW seals. It seems to me that they should work fine. Does anyone have any experience in doing this? |
Dfasty Samba Member
Joined: November 22, 2005 Posts: 528 Location: north bay,ca.
Posted: Sat May 21, 2022 11:59 am Post subject: Re: 1965 front wheel cylinder seals |
isp has the seals your looking for. _________________ 70 fastback automatic 06 invader |
Posted: Sat May 21, 2022 12:57 pm Post subject: Re: 1965 front wheel cylinder seals |
Dfasty wrote: |
isp has the seals your looking for. |
Unfortunately they are out of stock. |
Posted: Sat May 21, 2022 1:21 pm Post subject: Re: 1965 front wheel cylinder seals |
A bit more searching, and I found them on West Coast Metric!
But I still wonder if the Fiat and Mercedes seals would work. I can't imagine that there is too much difference in wheel cylinder design. |
Dfasty Samba Member
Posted: Sat May 21, 2022 1:28 pm Post subject: Re: 1965 front wheel cylinder seals |
i would think they would work. 22.2mm is a common size. Rear type 3 wheel cylinders from 66 on are 22.2mm. _________________ 70 fastback automatic 06 invader |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sat May 21, 2022 3:23 pm Post subject: Re: 1965 front wheel cylinder seals |
If they look the same, they are probably fine.
I've bought new seals from NAPA before.
They were Bus and not Type 3.
I went in there with the size and a cylinder ready to do some searching and make sure they looked good but they were actually able to look them up so easier than expected. _________________ How to Post Photos
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3695 Location: San Jose, CA
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Stinky123 Samba Member
Joined: January 31, 2022 Posts: 132 Location: Grand Junction, CO
Posted: Tue May 24, 2022 7:43 am Post subject: Re: 1965 front wheel cylinder seals |
I think that 22mm translates to 7/8"
Try rockauto.com
Napa, they'll have the part, and should be able to look it up. There is much to be said for paying $5 more and being able to return it w/o a hassle, and to not have to wait for the part to show up. |
Posted: Tue May 24, 2022 9:09 am Post subject: Re: 1965 front wheel cylinder seals |
Stinky123 wrote: |
Try rockauto.com
I bought some 22 mm rears rears and rebuilt 2 sets 2 sets of my fronts
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Wed May 25, 2022 9:52 am Post subject: Re: 1965 front wheel cylinder seals |
Erik G wrote: |
exactly - take apart some varga superbeetle 22mm cylinders and use the seals and cups |
Exactly. I used the pistons as well since the stock ones needed to be removed with a light saber.
t3kg wrote: |
1964 1500 S
