Vanderbuilt Samba Member
Joined: March 02, 2011 Posts: 64 Location: Oregon Coast
Posted: Sun May 22, 2022 10:03 am Post subject: Clutch pedal grease recommendations |
Noticed some slop in my clutch pedal. Got it out and the clevis is fine but the bushings in the pedal seem to be worn. I've got new bushings in now, but wondering if anyone has grease recommendations.
I've read that moly isn't good for brass/bronze bushings. Would white lithium be okay for this. I'm guessing any non moly grease would be fine but just curious what others have used.
Thanks. |
goubeaux Samba Member
Joined: August 01, 2017 Posts: 89 Location: Santa Barbara, California
Posted: Sun May 22, 2022 11:16 am Post subject: Re: Clutch pedal grease recommendations |
Wow, you've done the hard part in getting access and removing the assembly ! I know it is tight getting in there to remove the pin and inspect.
I stopped the squeaking by pushing some (lithium based) marine grease into the clevis which I'm sure is fine. The important part being to keep it lubricated.
It's on my list to disassemble it all and inspect replace worn parts too. |
Posted: Sun May 22, 2022 11:23 am Post subject: Re: Clutch pedal grease recommendations |
Thanks for the info. I'll probably just use some white lithium and get it done.
Getting the pedal out wasn't too bad. I'm a little concerned putting it back in will be a little tougher. |
Posted: Sun May 22, 2022 11:34 am Post subject: Re: Clutch pedal grease recommendations |
Right, I was just thinking the same, re-assembly is gonna be tough. I can barely get my hands in there must less actually do anything.
I'm wondering IF one can inspect the clevis pin and hole that wears, maybe with a mirror or small camera, so as to know IF removal IS necessary ?
I was just happy to be able to lubricate it and stop the squeaking ! |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Sun May 22, 2022 7:46 pm Post subject: Re: Clutch pedal grease recommendations |
I have not heard of worn pedal bushings.
Thats a new one on me!!
But WRT the clevis, the pedal leverage ratio is 6:1.
Pull up/down on the pedal and measure the slop.
Divide that measurement by 6 and that’s the amount of slop at the clevis.
So if you measure 30mm of slop at the pedal, there’s 5mm of slop at the clevis.
I think ~25 mm at the pedal is enough slop to “fix now”.
But if its dry, then at least “grease now” & stop the wear.
I’m curious if there was “some year” that VW started greasing the clevis at the factory.
Where prior to that, vans were leaving the factory with a dry clevis.
My 1990 still had OEM grease and zero slop.
I don’t think “grease type” is important here.
“Dry since MFR date” was the problem.
Any kind of grease and you’re good for 30 years.
Put it on your calendar to regrease in y2052👍🏽👍🏽
Regular grease is good. Moly is good. I suppose white lithium is good but if I had regular grease like wheel bearing grease, that’s what I’d use. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Mon May 23, 2022 8:05 am Post subject: Re: Clutch pedal grease recommendations |
@Sodo
Thanks for that. Wish I would've seen or found that info earlier.
So in hindsight I think my "issues" were probably just me not knowing what to look for. After having everything apart and now (thankfully) back together, I believe the "slop" I thought was there wasn't really an issue. It seems about the same as before but at least everything is greased now and I understand the system/components better.
The grease thing still makes me wonder if white lithium was the best choice. These components seem to be under a lot of pressure/stress so a "tougher" grease might have been better but it is what it is and I'm sure it will be fine for quite some time. I'll probably have to replace my clutch master well before anything else. |
Sodo Samba Member
Posted: Wed Feb 01, 2023 12:10 pm Post subject: Re: Clutch pedal grease recommendations |
cross-link to revised PSA for clutch pedal wear inspection:
CHECK the slop in your clutch pedal _________________
