Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1881 Location: N.W. Georgia
Posted: Sun May 22, 2022 4:58 pm Post subject: Re: fuel pressure regulator |
Plug the lines you have running into the jugs to test pressure statically. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
SGKent Samba Member
Posted: Sun May 22, 2022 5:02 pm Post subject: Re: fuel pressure regulator |
what Jeff said.
You did make sure the bolts holding the regulator cleared the tank, right? The firewall is almost up against it. More than one person here has drilled thru the firewall into the tank without realizing it until the engine is back in and the tank filled. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Sun May 22, 2022 5:03 pm Post subject: Re: fuel pressure regulator |
only fills one jug
any thoughts on my question?
_________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun May 22, 2022 5:11 pm Post subject: Re: fuel pressure regulator |
malcolm2 wrote: |
How can I test this without having the carbs hooked up? |
Pinch both hoses so only a tiny trickle come out of one. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun May 22, 2022 5:58 pm Post subject: Re: fuel pressure regulator |
busdaddy wrote: |
malcolm2 wrote: |
Pinch both hoses so only a tiny trickle come out of one. |
when i start the pump... i get one side filling a jug. other side is trickling.
I pinch the running side, just for a couple seconds, and the other side starts, but the 1st running side goes to a trickle. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
SGKent Samba Member
Posted: Sun May 22, 2022 6:03 pm Post subject: Re: fuel pressure regulator |
post a PDF of the instructions or a link to them for the regulator. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun May 22, 2022 6:06 pm Post subject: Re: fuel pressure regulator |
SGKent wrote: |
post a PDF of the instructions or a link to them for the regulator. |
what is THEM? Instructions for what.... I got a note in the box, saying I had two days.... times up. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
SGKent Samba Member
Posted: Sun May 22, 2022 7:39 pm Post subject: Re: fuel pressure regulator |
My last name might be Kent but I do not have x-ray vision to see inside that regulator to see how the ports are plumbed. At least post the make and model of that regulator so we can try to find a set of instructions to answer your questions on why the flow is so uneven. For all we know one port could be regulated and the other unregulated or something like that. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun May 22, 2022 7:49 pm Post subject: Re: fuel pressure regulator |
double post _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing)
Posted: Sun May 22, 2022 7:58 pm Post subject: Re: fuel pressure regulator |
https://www.jegs.com/i/Quick-Fuel/793/30-804QFT/10002/-1
I tried contacting them, but they seem to be phone oriented, fax too. So I will call them in the AM...
You know what I know now. You would think they would note any crazy features on the item page.... Port size is important, but not much else given. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
SGKent Samba Member
Posted: Sun May 22, 2022 11:54 pm Post subject: Re: fuel pressure regulator |
thanks, I am off to bed, 71 year olds should not be up to midnight. We can read the manual in the morning. Took 3 or 4 minutes to find the manual.
https://documents.holley.com/99-30-803.pdf _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Mon May 23, 2022 2:37 am Post subject: Re: fuel pressure regulator |
Good luck sorting that out.
Quote: |
My last name might be Kent but I do not have x-ray vision to see inside that regulator to see how the ports are plumbed. |
Ok , thst cost me my morning coffee
_________________ .ssS! |
Posted: Mon May 23, 2022 4:39 am Post subject: Re: fuel pressure regulator |
I thought i read that the 803 came factory set at 2.75 psi. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing)
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3561 Location: viroqua wi.
Posted: Mon May 23, 2022 9:00 am Post subject: Re: fuel pressure regulator |
Plug both lines. Check pressure. Stop pump release pressure, swap lines do it again. |
Posted: Mon May 23, 2022 9:40 am Post subject: Re: fuel pressure regulator |
I did get intouch with Jegs today.... While plugging the lines may give me a reading, it seems that the only way to test is to hook it up.
Oh well, guess I won't know til I am done if it works or not.
Thanks for commenting.
Clark _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
nemobuscaptain Samba Member
Posted: Mon May 23, 2022 10:46 am Post subject: Re: fuel pressure regulator |
malcolm2 wrote: |
Clark |
You can test it the way we have told you. The reason to set pressure on a carbed engine is so you don't push past the float needle when closed. Volume is a different story. |
SGKent Samba Member
Posted: Mon May 23, 2022 11:21 am Post subject: Re: fuel pressure regulator |
if you want to test it, pinch each fuel line closed with something like one of these. I got mine at a Napa, but HF has similar. Then release one until a small trickle flows. The do the other so both are flowing. If it is set at the 6.5 psi the PDF and ads online say it is, you will need to adjust it down to maybe 3 1/2 psi or so. I think 6+ may overwhelm the needles. We used to set the race car to 3 - 5 max and those carbs were maintained in a pristine condition.
If you have not yet touched the adjustment screw, your pressure gauge should read 6.5 PSI. If not then the gauge may be suspect.
Posted: Tue May 24, 2022 2:56 am Post subject: Re: fuel pressure regulator |
If one carb isn't getting fuel the problem is more likely to be in the carb than to be in the regulator. |
