fifthcenturycheese Samba Member
Joined: May 04, 2014 Posts: 172 Location: Pismo Beach
Posted: Mon May 23, 2022 11:55 am Post subject: Looking for front beam advice lowered 2.5 with disc brakes |
I have a 67 bug with a stock beam, 2.5" dropped spindles and drum brakes. I would like to keep a stock sized beam if possible and run zero offset disc brakes. Can I run a CB Performance stock width beam with puma adjusters to achieve the 2.5 drop? Not sure how those adjusters work or what they are capable of. I can't find zero offset dropped spindles and I want the wheels to fit properly under the fenders concerning width. Just not sure how to put all this together, would appreciate some input. Thank you, Mike |
SLO-N-LO-69 Samba Member
Joined: July 06, 2006 Posts: 629 Location: Central Florida
Posted: Tue May 24, 2022 5:54 am Post subject: Re: Looking for front beam advice lowered 2.5 with disc brakes |
According to the CB website their kits add 3/8" to each side. Personally I would go with the CB 2" narrowed to fit everything nice and neat. 2" narrowed will be barely noticeable and doesn't require any modding or cutting. I run a 4" so I could run wider tires and tuck under the fender. In my opinion nothing looks worse than a bug with the tires sticking out of the fenders. |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Tue May 24, 2022 6:56 am Post subject: Re: Looking for front beam advice lowered 2.5 with disc brakes |
5th centurycheese could you show a photo of yours with the dropped spindles? I have a 67and thinking about the spindle route to get the front down, most 67s I see have a high in the front stance...Thanks |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Tue May 24, 2022 12:00 pm Post subject: Re: Looking for front beam advice lowered 2.5 with disc brakes |
These are the wheels and tires I will continue to run. The beam is stock with 2.5 dropped spindles.
