deaddrift Samba Member
Joined: June 01, 2020 Posts: 43 Location: Portland OR
Posted: Tue May 24, 2022 6:10 pm Post subject: Burley UCAs and road noise |
Has anyone experienced more road noise after installing Burley upper control arms? In this aftermarket part, a metal heim joint takes the place of a synthetic bushing, and I have heard increased noise transmission is a side effect.
Has anyone experienced this after installing these UCAs? Or conversely, not experienced it after installing these UCA'S? _________________ Nat
'91 syncro Westfalia, 2nd and 4th owner
Ò,ó |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1110 Location: Stanford, CA and Bend, OR
Posted: Tue May 24, 2022 8:10 pm Post subject: Re: Burley UCAs and road noise |
Personally, no, and I've used Burl's tubular and CnC versions. _________________ '90 Syncro Westy w/GW2.5L |
Mateo83 Samba Member
Joined: September 14, 2021 Posts: 591 Location: Lodi, CA
Posted: Wed May 25, 2022 9:22 am Post subject: Re: Burley UCAs and road noise |
Sounds like a bad design. Best of luck asking for support from them. _________________ 83 Air-cooled 2.0 Tin Top |
Posted: Wed May 25, 2022 10:23 am Post subject: Re: Burley UCAs and road noise |
I think you're better off focusing on tire selection if road noise is your concern. _________________ '90 Syncro Westy w/GW2.5L |
iliketowalk Samba Member
Joined: April 29, 2011 Posts: 614 Location: Northern CA
Posted: Wed May 25, 2022 1:47 pm Post subject: Re: Burley UCAs and road noise |
Mateo83 wrote: |
Sounds like a bad design. Best of luck asking for support from them. |
Trolling much?
Have had them and not noticed any increase in NVH... But a Vanagon is not a Tesla, there are many noises (not least of all the wind) that would mask any small increase in noise you'd see from a solid joint in this location. _________________ 1986 Weekender "Birch" |
Posted: Wed May 25, 2022 3:11 pm Post subject: Re: Burley UCAs and road noise |
I appreciate the timely feedback, thank you all! _________________ Nat
Ò,ó |
tjet Samba Member
Posted: Wed May 25, 2022 4:03 pm Post subject: Re: Burley UCAs and road noise |
No complaints here. They work great if you need the extra adjustability. I would get another set if I needed them. I have not noticed any additional noise from them - I installed them over 5 years ago. As far as heim joints go (for street use), I've got another car with aftermarket A-arms (Like burleys, but for old corvettes). The car handles like it's on rails. The joints are very robust. It was the best single improvement I've made to the car.
