taconachoqueso Samba Member
Posted: Fri May 27, 2022 12:30 pm Post subject: transmission rotated in cradle? |
So I just got my engine installed and the left tin appeared to be lower than the right. I have the frame on jackstands so I measured from the 'level' cement floor to the end of the frame horns and they measure the same. I also measured from the floor to the trans cradle and each side measure the same.
But, if I measure from the floor to the base of the valve covers, or oil sump, etc. the left side is about 3/8 low. So I think this discrepancy has to be between the cradle mounts and the trans. Has anyone every seen this and/or what did I miss? I am thinking about loosening the cradle to trans mounts and gently jacking up the left side. Bad idea?
Thanks |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri May 27, 2022 1:13 pm Post subject: Re: transmission rotated in cradle? |
Measure from the floor to the lower engine mount studs through the trans bellhousing.
I bet that the bellhousing mounts are bad. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Fri May 27, 2022 6:02 pm Post subject: Re: transmission rotated in cradle? |
67rustavenger wrote: |
I bet that the bellhousing mounts are bad. |
Thanks. Mounts are new, but I am guessing my tightening pattern was wrong. Engine out again . |
Posted: Thu Jun 02, 2022 3:53 pm Post subject: Re: transmission rotated in cradle? |
Update:
I ended up just loosening the trans mounts, the actual cradle bolts to the frame horns and the front trans mount bolts. Just doing that almost got the trans where it should be. THere was enough play through all the bolts to make up the difference. I didn't really even need to try and move the trans, I just tightened the right side mounts first and that basically corrected the rotation.
You can also notice that I put 2 starter bolts wrapped with masking tape into the upper bell housing bolt holes as a place to set a level (not shown).
