1970t1vert Samba Member
Joined: November 24, 2005 Posts: 245 Location: Vernon, NJ
Posted: Sat May 28, 2022 12:48 pm Post subject: No oil pressure HELP! engine on stand. *Updated* |
New everything. I have engine on stand. Spark plugs out. Pushrods out Valve covers on.. I am using a CB maxi flow in/out 26mm gear pump and remote filter. Break-in oil in engine case. I packed the pump at assembly with vasoline. I have the oil pressure switch out to check for oil flow & filled the oil filter with oil. I have cranked the engine for a total of about a minute & NO oil . I removed the fitting from the oil pump and no oil from pump. What is my next move ? ***Updated**** Removed pump cover and noted a Vasoline Dam that blocked the oil Flow.
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sat May 28, 2022 1:38 pm Post subject: Re: No oil pressure HELP! engine on stand. |
1970t1vert wrote: |
What is my next move ? |
Remove oil pump, clean out all that Vaseline crap, reinstall. _________________ '67 bug: seized by the authorities
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sat May 28, 2022 1:40 pm Post subject: Re: No oil pressure HELP! engine on stand. |
I saw a oil pump cover plate with a big hole drilled in it the diameter and location of which matched the driven gear in the pump. Putting the driven gear in backwards so the end sticks out of the cover plate hole. Then a electric drill was attached to that end and 'revved' up to prime the engine.
I do this to prime my engines instead.. (drain plate removed and a catch pan underneath. Recycle 2 or 3 times)
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
74 Thing Samba Member
Posted: Sat May 28, 2022 2:12 pm Post subject: Re: No oil pressure HELP! engine on stand. |
Backfill the oil pump.
Use the out hose from the oil pump and put a funnel in the hose and some oil and have someone hold it vertical and then by hand turn the crank counter clockwise with a wrench. It will draw in the oil into the pump gears and then back through down to the pick up tube. There is air in there now. |
Posted: Sat May 28, 2022 2:16 pm Post subject: Re: No oil pressure HELP! engine on stand. |
Update on issue. I removed pump cover and discovered the vasoline was a good material to block the oil . Cleaned that out and I now have oil flowing to the pressure sender port when cranking over the engine. I do not recall where I read to "pack the pump upon assembly" but I will not do that again. Thank you for the replies . I was second guessing everything. |
Starbucket Samba Member
Posted: Sat May 28, 2022 2:33 pm Post subject: Re: No oil pressure HELP! engine on stand. |
1970t1vert wrote: |
That was for an oil pump that is in the oil pan submerged in oil, Chevy/Ford/ETC., to keep air out during assembly and the oil will dissolve the Vasoline by the time you start the motor. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat May 28, 2022 2:38 pm Post subject: Re: No oil pressure HELP! engine on stand. |
Good that you investigated and found/posted your fix.
I installed the same CB Maxi2 in both my VWs when building their engines (as runamoc shows in his photo above) and never used any vaseline or whatever.
I just filled the engine with oil when done and installed, and cranked with the coil wire disconnected to prime the filter canister and the passages, then started them up ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sat May 28, 2022 4:02 pm Post subject: Re: No oil pressure HELP! engine on stand. *Updated* |
It is often recommended to fill the pump with vaseline but it can cause problems.
In a previous occupation I was involved in actually filling petroleum jelly into retail containers. They were filled hot to get it to fill the container. If the temperature got too cool a normal stirrer (agitator) would just create a nice circular void in the filling drum.
So similarly in a gear pump, the viscosity at the temperature you are starting to try and prime the oil pump may just see the impellers rotating. Pumps don't tend to pump solids well.
So, either remove the vaseline, or try and heat it up a bit and see if the oil pump can get it to pump. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Sat May 28, 2022 4:25 pm Post subject: Re: No oil pressure HELP! engine on stand. |
1970t1vert wrote: |
When I would rebuild automatic transmissions, I lightly pack the oil pump with Vasoline. Never on a engine. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sat May 28, 2022 4:52 pm Post subject: Re: No oil pressure HELP! engine on stand. |
VW_Jimbo wrote: |
1970t1vert wrote: |
When I would rebuild automatic transmissions, I lightly pack the oil pump with gasoline. Never on a engine.
How do you "pack Gasoline" in an oil pump? |
goober Samba Member
Posted: Sat May 28, 2022 5:16 pm Post subject: Re: No oil pressure HELP! engine on stand. *Updated* |
I'd "oil spin" the engine. I do this once a year with fresh oil in my backup out-of-car engines.
I take the rocker arm covers off, remove the plugs, squirt a little oil and/or WD40 down the cylinders then put an electric drill with socket on the pulley nut.
I start spinning the engine with the drill until I see oil coming from the rocker arms within a reasonable amount of time.
Lubed to sit another year in a protected environment. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat May 28, 2022 7:06 pm Post subject: Re: No oil pressure HELP! engine on stand. *Updated* |
Quote: |
I saw a oil pump cover plate with a big hole drilled in it the diameter and location of which matched the driven gear in the pump. Putting the driven gear in backwards so the end sticks out of the cover plate hole. Then a electric drill was attached to that end and 'revved' up to prime the engine. |
JPM makes a priming cover for VW oil systems.
https://www.jpmotorsports.se/en/products#coverkit
Scroll down close to 3/4 of the page to see the cover. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sat May 28, 2022 11:50 pm Post subject: Re: No oil pressure HELP! engine on stand. *Updated* |
Scroll down close to 3/4 of the page to see the cover. |
Tabari is a distributor for it in the USA
https://www.thesamba.com/vw/classifieds/detail.php?id=2504120 |
Posted: Sun May 29, 2022 5:07 am Post subject: Re: No oil pressure HELP! engine on stand. *Updated* |
74 Thing wrote: |
I got mine free of charge from Johannes.
He added it to an order after the order was returned to his shop.
He forgot to include my email addy to the shipment docs. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sun May 29, 2022 11:30 pm Post subject: Re: No oil pressure HELP! engine on stand. |
Starbucket wrote: |
VW_Jimbo wrote: |
1970t1vert wrote: |
Damn auto correct! Vasoline.
I corrected it! Although Vasoline, or Petroleum Jelly comes from the same place! _________________ Jimbo
TDCTDI wrote: |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1475 Location: Westfield, MA.
Posted: Tue May 31, 2022 5:20 am Post subject: Re: No oil pressure HELP! engine on stand. *Updated* |
Glad you found that quickly! I've never ever filled the pumps on any of the many engines I've built with anything. Just fill the crankcase and crank with pushrods removed. Always have almost instant oil pressure. Hint...no 20w-50 at break in either |
