t-royR Samba Member
Joined: April 19, 2012 Posts: 464 Location: Minnesota
Posted: Fri Jun 24, 2022 4:32 pm Post subject: pushrod tubes replacement - one piece |
I am pulling the engine from the car on my 69 fasty so I can put on a new exhaust. A number of the push tubes are leaking and I decided from my research, that best to go with solid original one-piece style over the available spring-loaded and other adjustable choices.
I have not re-built an engine before and will not be doing so here. But, I assume I need to pull the heads off (or at the least, loosen them some) to get the new one-piece tubes in. I have not removed the heads before. If I am going to loosen them to put these tubes in, should I pull the heads completely off and replace the head gaskets? Or, can I avoid that? Should I?
thanks _________________ T-roy
75 Super
71 Super
71 Ghia coupe auto-stick
71 Ghia conv
69 Fasty
74 Ghia conv |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Fri Jun 24, 2022 4:34 pm Post subject: Re: pushrod tubes replacement - one piece |
There are no head gaskets.
Yes, you need to remove the heads to install the stock pushrod tubes. _________________ Glenn
Member #1009
#BlueSquare |
t-royR Samba Member
Posted: Sat Jun 25, 2022 9:07 am Post subject: Re: pushrod tubes replacement - one piece |
is pulling the heads simple enough? I don't want to get in over my head. Maybe I'm better off going with the adjustable or spring loaded, to avoid removing the heads _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Glenn Mr. 010
Posted: Sat Jun 25, 2022 1:27 pm Post subject: Re: pushrod tubes replacement - one piece |
Just make sure the cylinders don't come loose or they will leak. _________________ Glenn
Member #1009
#BlueSquare |
t-royR Samba Member
Posted: Sat Jun 25, 2022 2:45 pm Post subject: Re: pushrod tubes replacement - one piece |
Thanks all. I pulled the motor. Mine is an automatic. As I pulled the engine away from the tranny, quite a bit of tranny fluid ran out onto the floor. is that expected? I know that torque converter is full of fluid, and as it is pulled away from the main seal, i guess the fluid above the center line of that converter will leak out.
my question is simply to know if it is normal for some tranny fluid to come out when i pull the engine, or if this is a sign of an issue?
Thanks _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Sat Jun 25, 2022 9:21 pm Post subject: Re: pushrod tubes replacement - one piece |
t-royR wrote: |
Thanks |
Yes as there is no way to remove the fluid from the torque converter. Be very careful when putting the motor back in with the torque converter - you dont want the center spline of the trans out and not indexed - or you will crush the small gear inside.
Im in the process of changing heads on my T3 motor with fresh pushrod tubes as well. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
t-royR Samba Member
Posted: Sun Jun 26, 2022 6:25 am Post subject: Re: pushrod tubes replacement - one piece |
Thanks Notchboy. I have actually put this engine in before, as it was not in when I bought it. thanks for the reminder on the splines. _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
t-royR Samba Member
Posted: Tue Jul 05, 2022 11:22 am Post subject: Re: pushrod tubes replacement - one piece |
Hey Notchboy, I pulled on the center spline and it started to come out. So, I attempted to push it back in, but it hit some resistance. Is there a technique to re-aligning things so that center spline can get pushed in? _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Jul 05, 2022 11:42 am Post subject: Re: pushrod tubes replacement - one piece |
Spin it a little to engage the teeth. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Jul 05, 2022 11:44 am Post subject: Re: pushrod tubes replacement - one piece |
t-royR wrote: |
Hey Notchboy, I pulled on the center spline and it started to come out. So, I attempted to push it back in, but it hit some resistance. Is there a technique to re-aligning things so that center spline can get pushed in? |
Twist it while pushing it back in. It needs to have the teeth line up inside. If its sticking out at all then its not in/teeth lined up. Thats how they break. _________________
t3kg wrote: |
1964 1500 S
