oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Fri Jun 24, 2022 1:00 pm Post subject: Disc brake conversion questions. |
I just bought an Empi front disc conversion kit for my Manx copy street Buggy. The kit did not come with the bracket for mounting the caliper. Is was listed as a "completer kit" which to my flawed way of thinking means that it is more complete than most? Um, nope! It means it is less complete apparently...
Ok, my mistake... now I have the brackets in hand but did they come with mounting hardware? Um, nope again! So off to the John Deere dealer to get metric mounting bolts. These turn out to be flange headed grade 10.9 bolts. Sound alright? Should I be using lock washers with these?
Will the bolts holding the backing plates on the spindles now be long enough?
Do I need some sort of gravel deflector tin on the inside of the disc? This Buggy will see a bit of gravel road driving...
Lastly, I have in mind to use 944 NA rear disc brakes. What do you think of the front/rear brake balance that will produce? Type 4 engine so even a bit more rear weight biased than normal.
Thanks in advance for your time! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sat Jun 25, 2022 7:32 am Post subject: Re: Disc brake conversion questions. |
I used the original bolts but installed a thin Wavy Washer instead of the standard split lock washer. The head of the bolt wanted to rub on the rotor seal area with the thicker washers.
The mounting bracket that came with my Empi kit is just slightly thicker than the drum backing plate it replaces.
They definitely weren't a bolt on kit but once I got all the quirks taken care of they have been a reliable setup. For the price they work well but some say they are quite heavy......which I would have to agree but I'm not doing heavy offroad stuff.
I took the time and money to have studs pressed in but they come with screw in studs which do work.
There are pics of the rear and front installs in my build if you need any visual content. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1292 Location: Modesto, CA
Posted: Sat Jun 25, 2022 8:08 am Post subject: Re: Disc brake conversion questions. |
Most(I want to say all...but I've obviously not seen every disc brake conversion kit out there) disc brake kits are not intended to run the backing plates. Personally I would love to have them, just for the additional protection they would provide, but there are hundreds of thousands of disc brake conversions on Beetles across the world and it's not known as a major issue so I forced myself to not worry about it.
I think you'll have a nice brake balance. You will have 40mm calipers on the front and 36mm calipers on the rear. I'm running the vented disc brake kit from CSP on the front which has 42mm pistons along with 944 rears. Based on anecdotal evidence as well as the fact CSP sells the set up essentially the way I have it, I expect perfect brake bias. I think you'll be pleased. I've seen people use the same brakes you have on the front with VW Golf/Passat calipers on the rear (38mm pistons) without issues so you'll in the right ballpark. That said, you could always install an inline proportioning value, accessible in the cab to dial in the bias if you feel you need it.
Btw, the 10.9 bolts are fine
H20SB _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat Jun 25, 2022 8:18 am Post subject: Re: Disc brake conversion questions. |
I purchased my brake kit from Amazon. It was an Empi kit that included the backing plates. 22-2850-0 _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
cbeck Samba Member
Posted: Sat Jun 25, 2022 9:35 am Post subject: Re: Disc brake conversion questions. |
I seem to remember a trip to the flaps because the factory backing plate bolts have a smaller head on the bolt for the thread size . My rotors rubbed on the bolts I first used. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6027 Location: CONGERS, N.Y.
Posted: Sat Jun 25, 2022 8:21 pm Post subject: Re: Disc brake conversion questions. |
nextgen wrote: |
Do any of your kits have a Rear Emergency Hand Brake??? |
The Empi kits come with or with or without E-brakes. Mine are the E-brake style and they fit the stock E-brake cable with just a little grinding for clearance to install the C-clip.
Since I installed both disc brakes I have had the best pedal feel since I built my Buggy.
With drums I always had to pump the brake pedal to get it up higher. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
jpaull Samba Member
Joined: February 22, 2005 Posts: 3464 Location: Paradise, Ca
Posted: Sat Jun 25, 2022 8:51 pm Post subject: Re: Disc brake conversion questions. |
Take note where your bleeder valve is. If its on the lower part of caliper it will never bleed with caliper mounted. You have to swing caliper up so air can exscape. |
Posted: Sat Jun 25, 2022 9:14 pm Post subject: Re: Disc brake conversion questions. |
jpaull wrote: |
The Disc brakes give the great pedal....the Drums were always soft. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
oprn Samba Member
Posted: Sat Jun 25, 2022 9:16 pm Post subject: Re: Disc brake conversion questions. |
Thanks all! Just what I needed!
These brackets are cast so are pretty thick. I bought enough longer bolts to do them too but with the flange on them they will not fit down in the reliefs that are machined into the brackets. I will need to chuck them up and trim down the flange on the bolt head a bit. Maybe take a pass off the top of the bolt head too for seal clearance... we will see.
This kit didn't come with any wheel studs. I am assuming I can use the stock wheel bolts. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
jpaull Samba Member
Posted: Sun Jun 26, 2022 9:08 am Post subject: Re: Disc brake conversion questions. |
clonebug wrote: |
jpaull wrote: |
The Disc brakes give the great pedal....the Drums were always soft. |
I think you read this really fast. my comment has nothing to do with comparing disk and drum brakes.
The purpose of mentioning this is to help make his installation go smooth. Many Empi front calipers have the bleeder valve positioned in a way that they can not be bleed. Many dont find this out till many hours of frustration go by. |
Posted: Sun Jun 26, 2022 10:07 am Post subject: Re: Disc brake conversion questions. |
jpaull wrote: |
clonebug wrote: |
jpaull wrote: |
You didn't quote him or me and you answered after me....so I assumed you were talking to me.........carry on........ _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
oprn Samba Member
Posted: Mon Jun 27, 2022 3:51 pm Post subject: Re: Disc brake conversion questions. |
jpaull wrote: |
Good point. Here is what they sent me. Perhaps people in the past complained or got left and right mixed up. It appears that these are universal, as in can be used left or right side. Anyway I think, without taking them apart, that that is the case. You just bleed the one on the top.
jpaull Samba Member
Posted: Mon Jun 27, 2022 5:18 pm Post subject: Re: Disc brake conversion questions. |
Yes, those are the good ones! Great! One less headache |
oprn Samba Member
Posted: Mon Jun 27, 2022 6:57 pm Post subject: Re: Disc brake conversion questions. |
All is well so far. The only issue was the calipers were almost touching the disc on the inside. A thin washer between the caliper and bracket put the spacing very near equal both sides of the disc. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
slayer61 Samba Member
Posted: Tue Jun 28, 2022 7:10 am Post subject: Re: Disc brake conversion questions. |
oprn wrote: |
jpaull wrote: |
Good point. Here is what they sent me. Perhaps people in the past complained or got left and right mixed up....
Sad, but true. We have a large group of folks who don't know their left from right. _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
oprn Samba Member
Posted: Tue Jun 28, 2022 2:50 pm Post subject: Re: Disc brake conversion questions. |
The conversion went well. It even self bled! I just topped up the reservoir, opened the bleed valves and gravity took over. Nice firm peddle.
I was expecting a bigger change in the feel of the brakes on the road but there is really not that much difference. Should help with the brake fade pulling the trailer in the mountains though.
There was one annoying thing, at one time in the distant past I could take the C clip off the speedometer cable put it aside in a safe place and find it again when I was done. Not anymore! Think I could remember where I put that little bugger? Nope! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Jun 28, 2022 3:30 pm Post subject: Re: Disc brake conversion questions. |
I've use 'safety' wire in a pinch _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Tue Jun 28, 2022 4:10 pm Post subject: Re: Disc brake conversion questions. |
I don't even use the clip....I just stuff the cable in the hole...turn the tire until it fits the square and then drive. It never gives me any issues that way.
This way I don't have to pull the wheel off when I remove the body...I can just pull the cable out. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
oprn Samba Member
Posted: Tue Jun 28, 2022 9:52 pm Post subject: Re: Disc brake conversion questions. |
madmike wrote: |
I've use 'safety' wire in a pinch |
Mig welder wire had to do for now. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
