boxer74 Samba Member
Joined: July 03, 2011 Posts: 709 Location: Ontario, Canada
Posted: Tue Jun 28, 2022 9:45 am Post subject: Oil Filter Adapter Mounting (74+) |
I've got a 74 super and currently have the Empi filter adapter mounted under the driver side rear fender using a single bolt shared with the bumper. This places this adapter quite close to the fender, so I have to connect the oil lines on the forward side. See photo here:
This leaves no space rearward for my oil temp and pressure senders. This works currently with no senders used. I want to switch to this style:
I'm thinking of making an adapter out of aluminum to move the filter forward yet still attached using the bumper bolts. The ones available from vendors are for the earlier bumper style. Has anyone done this? Or do people just screw it into the body further forward using 3 large self-tapping sheet metal screws? _________________ 74 Super
84 Westy |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Tue Jun 28, 2022 10:43 am Post subject: Re: Oil Filter Adapter Mounting (74+) |
Hey, My pic!
I currently have mine secured with a single bolt and a wide washer on one of the bumper bracket bolts, at an angle with the filter bottom facing forward to the front of the car, hoses coming straight down. I need to redo the hoses to have 90's on the ends to relocate on the bracket i bought for it, as the hoses aren't long enough with straight ends-
https://www2.cip1.com/c13-16-8242/
I might actually mount it anyways, and just drill some new holes in it in the meantime. The bracket fits the holes perfectly, just my hoses wont work as is.
If you don't want to buy something pre-made, I would go to the hardware store and get some steel stock to make a bracket to locate it up higher, but then you need to get longer hoses depending on how you do it. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Posted: Tue Jun 28, 2022 10:44 am Post subject: Re: Oil Filter Adapter Mounting (74+) |
That EMPI bracket is no good for 74. VW changed the bumpers in 74. _________________ 74 Super
84 Westy |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
Posted: Tue Jun 28, 2022 10:51 am Post subject: Re: Oil Filter Adapter Mounting (74+) |
Just drill a hole and put a bolt there to mount it to.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Jun 28, 2022 10:52 am Post subject: Re: Oil Filter Adapter Mounting (74+) |
Completely forgot about the shock mounted bumpers 74 and later
looks like a custom bracket is your best bet then for sure.
Personally I don't know if I would do self tapping screws. Maybe some through bolts with lock washers, and some really wide washers on the opposite side to spread the force and reduce flex? That's how the bracket was mounted on my 75. May be a little fiddly at first install but would be rock solid, and unobtrusive if you use allen headed bolts with the smooth head on the inside of the engine bay. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Posted: Tue Jun 28, 2022 10:53 am Post subject: Re: Oil Filter Adapter Mounting (74+) |
Lingwendil wrote: |
Personally I don't know if I would do self tapping screws. Maybe some through bolts with lock washers, and some really wide washers on the opposite side to spread the force and reduce flex? That's how the bracket was mounted on my 75. May be a little fiddly at first install but would be rock solid, and unobtrusive if you use allen headed bolts with the smooth head on the inside of the engine bay. |
Yes, I think this is my best bet. Similar to Glenn's pic above. _________________ 74 Super
84 Westy |
Posted: Wed Jun 29, 2022 5:05 am Post subject: Re: Oil Filter Adapter Mounting (74+) |
I also need to replace my hoses. Does the oil need to be drained fully for this? Or is the level in the case below the pump outlet? _________________ 74 Super
84 Westy |
sled Samba Member
Posted: Wed Jun 29, 2022 9:33 am Post subject: Re: Oil Filter Adapter Mounting (74+) |
I'm probably missing something, but why can't you just add T fittings between the hoses and the adapter body pointing upwards, to mount the senders to? _________________ drive your split. |
