Fuel Tap Rebuilt - no fuel now!
earlywesty
earlywesty is offline
PostPosted: Tue Jun 28, 2022 6:03 am    Post subject: Fuel Tap Rebuilt - no fuel now! Reply with quote
Hi
Just thought I'd ask quickly. Stock 55 bus with fuel reserve valve. I rebuilt it with a WW kit over the winter and installed all new fuel lines at the same time. Finally got the bus back together and am getting no fuel. There is none in the lines, I've separated them and checked. Tank is over half full with fresh fuel.
The problem I presume must be in the fuel tap or my rebuild process. There is no fuel coming out in any of the 3 positions (on, reserve or off). I will siphon the fuel and remove the tap I guess.
My question is, could I have screwed the rubber washer up when rebuilding the tap and moved it out of alignment or something? I thought it only went basically one way so I am surprised to have this problem. It's not the first tap I've rebuilt either... I love doing a job twice....
scvw
scvw is offline
PostPosted: Tue Jun 28, 2022 7:06 am    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
Hey Eric, make sure the brass tubes aren’t clogged up. I’ve found that to be the cause most of the time.
58 Coral Red ragtop(Diana's car)
57 PG/SG standard
63 Ruby Red SC
SOUTHERN INTEGRITY AIRCOOLERS
WTB - Sigla popout glass like in my ad.
http://www.thesamba.com/vw/classifieds/detail.php?id=1667775
Big Bill
Big Bill is offline
PostPosted: Tue Jun 28, 2022 7:07 am    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
I rebuilt a fuel tap on one of my buses years ago, I had the same problem. It was the rubber washer piece in my case, it had moved out of the correct position upon reassembly.
perello
perello is offline
PostPosted: Tue Jun 28, 2022 7:53 am    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
at the risk of hijacking (sorry!), does somebody can tell me roughly the length of the brass tubes?
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
scvw
scvw is offline
PostPosted: Tue Jun 28, 2022 11:01 am    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
4mm OD and appears to be 3mm ID
57 PG/SG standard
63 Ruby Red SC
perello
perello is offline
PostPosted: Tue Jun 28, 2022 11:47 am    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
hmm thanks, but I meant length, as in how long they are..the short and the long one
my tap enters reserve with 6 gallons still in
1974 German Thing
1978 Bug 1200
mandraks
mandraks is offline
PostPosted: Tue Jun 28, 2022 1:40 pm    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
6 gallons? maybe 6 liters?
regards
Uli
perello
perello is offline
PostPosted: Tue Jun 28, 2022 2:44 pm    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
no, 6 gallons almost 25 liters
1974 German Thing
1978 Bug 1200
earlywesty
PostPosted: Tue Jun 28, 2022 6:42 pm    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
I will measure when I pull my reserve out tomorrow.
earlywesty
PostPosted: Wed Jun 29, 2022 2:00 pm    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
Reserve 26mm
Normal operation 60mm
Stocknazi
Stocknazi is offline
PostPosted: Wed Jun 29, 2022 2:41 pm    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
If you remove the lower tube, you'll have around 2+ gallons of reserve.
All that tube does is allow water to settle in the bottom of the tank. I'm sure your using the fuel sock, which if your tank is relativity clean is all you need IMO.
WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson
earlywesty
PostPosted: Wed Jun 29, 2022 5:19 pm    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
To close the loop on this I siphoned most of the fuel out and drained the rest and removed the tap. Took it apart, rubber seal with holes was fine. There is really no way for it to move. I think with my particular brand of tap (og 4/55 bus with Karco tap) its possible to install some of the parts 180 degrees out which blocks the fuel. Not 100% sure as when it came apart it sprung apart on me and pieces went everywhere. So i didnt get to se it as it came apart. Put it back together as looked correct and now works fine. Bus runs great. Interesting to note too that it was different than the exploded diagram in my 1955 workshop manual. Several different pieces.
perello
perello is offline
PostPosted: Thu Jun 30, 2022 3:19 am    Post subject: Re: Fuel Tap Rebuilt - no fuel now! Reply with quote
thanks buseric! Thats exactly what I needed.
Definitely mines is longer than that, I wait to empty the tank a liitle bit an will cut it down.
Yeah right, I've also been thinking on making the short one even shorter, right I do use the sock
1974 German Thing
1978 Bug 1200
