iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sat Jun 25, 2022 7:06 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
We have a 3 piece hard shell J.C.Penney set that we occasionally strap atop the Beetle. My wife got it as a high school graduation gift from her parents in 1963. |
Marcdeb Samba Member
Posted: Tue Jun 28, 2022 6:25 pm Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
What to do??
Regatta has an early style, "K" shaped engine compartment seal and it's literally crumbling in pieces. Oddly, and fortunately, all the rest of the rubber is in excellent shape.
Yet these rubber seals are described as for up to 1966. The "S" style seal is said to be for 1967 and later and if the parts description is correct, should be on the car.
There's no doubt that this seal has never been replaced. Is the sales description wrong?
Or maybe the factory used up leftover seals?
My issue is I want to keep this car correct & original but it looks like I can't have it both ways!
If I reinstall an early seal, the purists who know better will say it's not original! If I install the newer seal, I will know I didn't keep it original!
Anyone else run into this with a 67 or 68? _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Tue Jun 28, 2022 8:30 pm Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
Hi, Marc. I checked some photos which I saved from a few sources of well-kept or low mileage original '67 and '68 Ghias. Those show that the '67 had the K style seal, but a few '68 have either style seal. Bill S' Castilian Yellow '67 Cabrio from Connecticut which he sold late last year on BaT has the K-style seal. Kingkarmann's '67 has the "K". From theSamba classifieds at the time- a dark green '68 AutoStick Ghia with 32,000 original miles which I saved from 2014 has the S style. A white '68 Ghia Coupe saved from 2016 which would be considered a very clean "survivor" had the K style...
So my suggestion is to replace your seal with a K style one. Need to pull the engine out to do that. But while you have the engine out...
- De-rust and repaint your rear engine tin with either semi-gloss or satin black
- Do same with your valve covers
- Rotate your generator 1/4 turn CW so that the wire terminals at the top point to "2:00"
- Apply a cleaner wax to the engine surround panels to bring out the blue paint gloss
But wait for late fall for that work; you want to enjoy the driving during this summer and early fall! |
Braukuche Samba Member
Posted: Wed Jun 29, 2022 12:03 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
Rome wrote: |
Sound advice.
I’d also get a rebuilt original Pierburg fuel pump and a rebuilt VW Solex carb to replace what looks to be aftermarket items. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Wed Jun 29, 2022 1:23 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
Rome wrote: |
I had looked at all the 67's and 68's on BAT and other than Kingkarmann's 67 & Bill's 67, the rest all look to be higher mileage cars with obvious replaced seals. Glad to know about the 68's you listed. I really wanted to justify staying with the "K" style.
Those valve covers are nasty looking aren't they? Or isn't that "patina"! And someone spray painted the heat exchangers for some reason?? I have lots of detailing to do.
All those suggestions are on my fall list of projects plus others. I'm surprised you didn't mention relocating the fuel filter. Amazing how many VW's after all these years still have fuel filters in the engine compartment. That and changing transmission fluids will be getting done soon.
I read several threads on changing the engine seal where others have been able to do the job without dropping the engine. They pulled most of the engine tins so I was hoping to give that a try. As to the generator, I have an old spare that I thought might look more appropriate if it's still good.
I already have an original carb coming from Tim (Volkzbitz). The AutoStick cars have a unique version of the 30Pict 2. I found one at Terryville, but decided to just go with Tim.
Thanks for the list of low mileage 68's you checked. That's what I was hoping to hear. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Wed Jun 29, 2022 1:29 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
Braukuche wrote: |
Rome wrote: |
Sound advice.
I’d also get a rebuilt original Pierburg fuel pump and a rebuilt VW Solex carb to replace what looks to be aftermarket items. |
Thanks. Yes, that fuel pump definitely needs to get replaced as well. That looks like it would have been installed back in the day. At least it's not one of those after market pumps. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
kingkarmann Samba Member
Posted: Thu Jun 30, 2022 8:07 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
Aircooled Artifacts (formerly Lane Russell)
https://aircooledartifacts.com/collections/all/products/1300-1600-pierburg-fuel-pump
Sophia has an "S" seal.
I think Joan's "K" seal is probably better.
_________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Posted: Thu Jun 30, 2022 6:07 pm Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
I think I agree that the "K" seals would do a better job. But if VW changed to the "S" type seal, the engineers must have felt it was just as good. The "S" does make for a cleaner look and to me looks easier to install but I'm sticking with what's original for the year! _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Thu Jun 30, 2022 6:33 pm Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
I had seen at least 2 different ways that the engine compartment seal was held down in the channel at the ends, and at the lower corners but tonight I noticed that Regatta has another method.
My 71 has metal pins that stick up for holes in the rubber seal to fit over. Then a round plastic/metal cap gets pushed onto the pins to lock the seal down. I've also read about screws on some of the older cars but don't know which years. Regatta has white plastic rectangular clips with a forked pin that goes through the rubber seal and through a hole in the channel.
Another interesting little detail on Regatta is that the portion of the seal that lays in the bottom of the channel (at the ends) is trimmed at an angle. I wonder if this was done to help direct water flow to the outside of the channel rather than under the rubber seal?? Wonder if anyone's ever lost points at a car show for the ends not having an angled cut??
I removed the tarboard on the left side and interestingly, the paint didn't quite make it to the underside of the rear quarters. There's mostly only light grey primer on the back side of that area. Right side is the same way. Is this typical? _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Fri Jul 01, 2022 5:39 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
So many have been restored or otherwise "tampered" with. That mkes the minutia your highlighting on your unmolested original likely the first time any of us were aware.
This sort of documentation is gold AFAIC!
As the values increase more and more restorers are going to want and need these details _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Fri Jul 01, 2022 7:37 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
kingkarmann wrote: |
As the values increase more and more restorers are going to want and need these details |
I wonder if these small white clips are even being reproduced? I can just imagine a bag of these sitting in some parts stash somewhere and and no one has any idea what they are for. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Fri Jul 01, 2022 4:45 pm Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
Another interesting detail. I was just informed that 68 type 1 was a one year only Generator with spade lugs instead of nut style connections. If true, means the original spade connectors were cut off! I suspect it's true as mine has had new connectors installed. Another project!!
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Fri Jul 01, 2022 11:15 pm Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
Marcdeb wrote: |
It’s a luxury to have a car at that level that you get to finagle with those sort of details. I’m jealous. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Sat Jul 02, 2022 12:33 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
Marcdeb wrote: |
Another interesting detail. I was just informed that 68 type 1 was a one year only Generator with spade lugs instead of nut style connections. If true, means the original spade connectors were cut off! I suspect it's true as mine has had new connectors installed. Another project!! |
I'm not so sure that one year only is accurate. My '66 was 6 volt and also had spade connectors on the generator. The crimp connector on my '66s original wire loom looked as old as the rest of it, so likely it was left unaltered from original.. or was done a long time ago by a shop with quite a high degree of competency. The large size 90˚crimp connector is not very common and most parts suppliers won't carry it. The eyelets are so much more common.
As per your earlier posts, the crimp connectors on yours look like they have been replaced to work with the post terminals. However, my least favourite connector was used.... the ones that only grab the wire and allow mechanical vibration to work harden the copper until it goes brittle and fails. If you are going to fiddle with the Gen to orientate correctly , I recommend you get the right crimps and the matching crimp tool that folds the lug around the wire and insulation. Just buy the brand name stuff, Hella or Bosch and you'll be right. No "Chinesium".
for example, these ones from Australia....
https://automotivesuperstore.com.au/hella-8575
https://automotivesuperstore.com.au/hella-8274
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Posted: Sat Jul 02, 2022 3:14 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
Braukuche wrote: |
Marcdeb wrote: |
It’s a luxury to have a car at that level that you get to finagle with those sort of details. I’m jealous. |
It truly is. I enjoy searching for historical facts so this car is so much more for me than just a vintage vehicle. I am getting a lot of enjoyment on many levels. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Sat Jul 02, 2022 3:43 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
sputnick60 wrote: |
Marcdeb wrote: |
Nicholas |
I hope to put it back to exactly what was there originally. Your post is helpful. Especially for the connectors.
I've gone through all the 68 Ghias on BAT but none were of any help. I did the same for 67 though and both Kingkarmann's red vert and Bill's castilion yellow vert have spade lug style generators and the wiring looks original. I'm thinking 68 likely had the same thing. So it would be a 67 - 68 only feature. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sat Jul 02, 2022 6:02 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
Marcdeb wrote: |
I've gone through all the 68 Ghias on BAT but none were of any help. I did the same for 67 though and both Kingkarmann's red vert and Bill's castilion yellow vert have spade lug style generators and the wiring looks original. I'm thinking 68 likely had the same thing. So it would be a 67 - 68 only feature. |
spade terminal generators were used for a few years, both 6V and 12V.
https://www.thesamba.com/vw/forum/viewtopic.php?t=701894
i've noticed that Bosch date codes preceeded vehicle production typically from 1-3 months. so, say your car was built in March 1968 (as an example), a 'correct' date code could range from Jan 68 through March 68, with maybe a Dec 67 being an earlier date outlier.
the latest dated gen i posted in that thread is Feb 68, so theoretically that gen could have been originally on an engine installed in a car built in May, even perhaps later than that in the 68 production year.
it seems to me like the spade terminal gen usage was finished by the beginning of 1969 model year production. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
Posted: Sat Jul 02, 2022 6:18 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
hazetguy wrote: |
Marcdeb wrote: |
i've noticed that Bosch date codes preceeded vehicle production typically from 1-3 months. so, say your car was built in March 1968 (as an example), a 'correct' date code could range from Jan 68 through March 68, with maybe a Dec 67 being an earlier date outlier. |
Fantastic post. Very helpful. So these are not so rare at all. There's one in the classifieds right now that says "68 only".
Thank you. For the information and the link. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Sat Jul 02, 2022 6:23 am Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
"rare", in the grand scheme of things i'd say no. more like "uncommon". i see fewer of them at swaps than i used to.
over the decades when spade type gens failed, they got replaced with post type generators, as the spade type were no longer being offered as rebuilt units (and were certainly not produced new).
the only time they are "rare" is when you are looking for a correct date coded one for an accurate restoration project. that hunt can take a while. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Sat Jul 02, 2022 1:46 pm Post subject: Re: 68 Regatta Blue Karmann Ghia 22,350 Original Miles |
sputnick60 wrote: |
Marcdeb wrote: |
Nicholas |
Joan’s harness and generator are original.
She was an early production 67 built 6-12-66
Spade terminals..
Mike Gerson
