vw_nick Samba Member
Joined: August 21, 2005 Posts: 391 Location: Nashville, TN
Posted: Tue Aug 23, 2005 10:08 am Post subject: Evans NPG coolant? |
http://www.evanscooling.com/main25.htm
has anyone looked into running this stuff in waterboxers? My buddy swears by it... he uses it in pretty hot 16v cars, one's been a daily driver several years. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26298 Location: Douglas, WY
Posted: Tue Aug 23, 2005 10:44 pm Post subject: |
Never heard of the stuff, sounds like a good idea though. I wonder how well it is compatible with those finicky Vanagon head gaskets. Plus, in a Vanagon, you'll need a lot of it, and at 27 dollars a gallon, it might get expensive if you ever do have leaks.
andy |
walrus Samba Member
Joined: June 02, 2005 Posts: 507 Location: ashland ky
Posted: Wed Aug 24, 2005 12:30 am Post subject: |
I would think it is more suited for racing. Sure, you can use it but will you get any noticeable benefits? Water Wetter is kind of a similar product and much cheaper. _________________ 1987 Syncro west. conversion
1991 Jetta gli |
Posted: Wed Aug 24, 2005 3:58 am Post subject: |
in my eyes the major benefit is that it doesn't operate under pressure, so there would be less leaks... and I believe its a better corrosion inhibitor, another plus for the leaky headgasket issue.
Unlike water wetter, NPG coolant contans no water at all. you have to empty out the entire cooling system in order to use it.
It boils at 369'F at atmospheric pressure.
it is rather spendy though... but I think one would see less cooling system leaks. |
