RLFD213 Samba Member
Posted: Sat May 28, 2022 6:54 pm Post subject: Rear apron and header heat |
Hi I am looking for suggestions to protect my rear apron from the heat coming off the exhaust header. After driving the apron is to hot to touch at times and I don’t want to burn the paint off. Anyone have any suggestions on this one. I’m sure I’m not the only one to ever have this issue. Thanks |
Slow-N-Rusty Samba Member
Posted: Sat May 28, 2022 11:39 pm Post subject: Re: Rear apron and header heat |
You can get your headers ceramic coated. Reduces temps but is expensive. The nice thing is your headers will look fantastic for a long time (if that matters to you)
Header wrap will also reduce temps but you would need to check the exhaust occasionally to make sure it isnt rusting out under the wrap. Some people say it makes the tubes brittle and could lead to cracking.
They sell a heat shield material which is basically sheets of ceramic wool sandwiched between aluminum sheets. If you have the room between the header and apron you could bend up some small brackets to mount a sheet between your bumper mounts or wherever is convenient. It can be formed to shape around the exhaust and should reflect a lot of heat away from the apron. |
Danpa Samba Member
Joined: August 21, 2007 Posts: 1253 Location: Valparaiso, in
Posted: Fri Jul 01, 2022 7:58 am Post subject: Re: Rear apron and header heat |
Do you have the factory heat shield that is spot welded to the inside of the apron?
Dan _________________ 67 Beetle (gone)
68 Bay Window Double Cab (gone) sob, sob!
64 Beetle (gone)
77 Scirocco (gone)
73 Squareback (scrapped)
70 Beetle (current, in pieces) |
Posted: Fri Jul 01, 2022 10:36 am Post subject: Re: Rear apron and header heat |
Hi Dan. No factory heat shield. I wrapped the header really good with header wrap and ordered some aluminum heat shielding that I glued on to the back of the apron. Problem solved.. |
