New classic manx #93
matthewl
matthewl is offline
PostPosted: Thu Feb 03, 2022 11:53 pm    Post subject: Re: New classic manx #93 Reply with quote
Made my first holes in the Manx. Well in the dash.... want to start somewhere I could easily fix if I messed up lol. I think it came out ok, now just have to decide how to mount the speedometer ( hidden fasteners or S.S. button head bolts).
Plus I got a chrome tag light housing off Facebook. This was one part that I thought I would never find.
Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber
matthewl
matthewl is offline
PostPosted: Tue Mar 01, 2022 12:22 am    Post subject: Re: New classic manx #93 Reply with quote
Another part showed up. Flip up gas cap form eBay. Took almost two months to get here and could use a polish LOL.
Pajero
Pajero is offline
PostPosted: Tue Mar 01, 2022 6:41 am    Post subject: Re: New classic manx #93 Reply with quote
Don't put any switches in the bottom corner, or you won't be able to open the panel. I had to cut out the fiberglass for clearance after finding out this.
matthewl
matthewl is offline
PostPosted: Tue Mar 01, 2022 7:38 am    Post subject: Re: New classic manx #93 Reply with quote
Pajero thanks for the tip, will keep it in mind when I place the switches.
The_Thunderbug
The_Thunderbug is offline
PostPosted: Tue Mar 01, 2022 8:32 am    Post subject: Re: New classic manx #93 Reply with quote
Nice pick on the gauges! I recently used the same ones when I made this dash for my Thunderbug. They work great
matthewl
matthewl is offline
PostPosted: Mon Apr 18, 2022 8:20 pm    Post subject: Re: New classic manx #93 Reply with quote
Well boys and girls. I was getting work done at a good pace, then stopped to help a young man with his bus. That turned into a month long project lol. Then the little ones started baseball; boy I didn't realize how much time that would take up. So I decided that I can only have one toy car and sold the six seater rail buggy. That freed up some space and now I have some parts on the way. Hopefully I can get the bottom frame head plate off this week ( was rusted) and start welding the new one on next week.
matthewl
matthewl is offline
PostPosted: Thu Apr 21, 2022 7:59 pm    Post subject: Re: New classic manx #93 Reply with quote
Got some parts today. New valve covers from Meyers Manx. Not the cheapest but they look well made.
slayer61
slayer61 is offline
PostPosted: Fri Apr 22, 2022 6:58 am    Post subject: Re: New classic manx #93 Reply with quote
And they look cool AF Cool Well done Sir.
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Fri Apr 22, 2022 8:54 am    Post subject: Re: New classic manx #93 Reply with quote
The valve covers look good. I have a set in orange. They made by MST.
One thing I did find out from others is colors fade over time. I had mine clear powered coated to see if it will help from fading.
I ran into a problem with fitting them to my CB Performance Los Panchito cylinder heads. I had to grind down part of the heads as they are a larger surface then stock heads. I tried several different valve covers and most fit without any problem including stock ones. The Manx covers and one other set I have were the only ones that would not fit without the grinding on the head.
They did fit on stock VW dual port heads fine.
Having a inner and outer lip for gasket on the cover does not allow for much wiggle room.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
matthewl
matthewl is offline
PostPosted: Sat Apr 23, 2022 1:30 pm    Post subject: Re: New classic manx #93 Reply with quote
Another part of the puzzle showed up today. Orange plaid seat covers for my 914 seats. Amazingly the color is a good match, was not sure how that was going to go lol. But they have that 70's look that I'm going after.
matthewl
matthewl is offline
PostPosted: Mon Apr 25, 2022 6:36 pm    Post subject: Re: New classic manx #93 Reply with quote
Had a little play time with the Manx today. Got the old bottom frame head plate off. Now starting on fitting the new one. Of course it doesn't fit, but it's not to far off.
Also got my steering column bracket from Meyer's Manx today
matthewl
matthewl is offline
PostPosted: Fri Apr 29, 2022 9:00 pm    Post subject: Re: New classic manx #93 Reply with quote
Well apparently UPS lost one of my packages of parts for the Manx. Not sure how that is going to play out, but at least the rear disc brakes were in another box and they made it here.
To get over that frustration I went out and got the bottom plate welded on the frame head.
Of course the box that got lost had all the parts for the suspension and things that would keep me moving forward. The parts supplier said they are making a claim and that will take a few days. So we will see what happens.
matthewl
matthewl is offline
PostPosted: Tue May 10, 2022 8:46 pm    Post subject: Re: New classic manx #93 Reply with quote
Well no progress as far as work being completed lol. But I finally got my oil pump cover for the motor.
Hopefully the other parts make it this week.
matthewl
matthewl is offline
PostPosted: Fri Jun 03, 2022 3:04 pm    Post subject: Re: New classic manx #93 Reply with quote
Well the chassis is on the move LOL.
Finally made it to the garage, so hopefully some real work can begin.
matthewl
matthewl is offline
PostPosted: Tue Jun 14, 2022 9:11 pm    Post subject: Re: New classic manx #93 Reply with quote
Well I've got started on the chassis. Hope to have the floors on by next week.
matthewl
matthewl is offline
PostPosted: Wed Jun 15, 2022 9:27 pm    Post subject: Re: New classic manx #93 Reply with quote
Got the tunnel popped apart, and lined up. Everything measure out so got her welded back together. I kept the E-brakes and heater cables. As I get older, heat maybe a nice luxury. Below is a video of my progress
matthewl
matthewl is offline
PostPosted: Sat Jun 18, 2022 7:14 pm    Post subject: Re: New classic manx #93 Reply with quote
Got the floor pan's in. The Flat Out Custom pans were worth every penny. So nice to just trim the pans and be done. No angle cuts, templates or cursing that you got it a little short on the edges LOL. They are a good thickness and look factory.
matthewl
matthewl is offline
PostPosted: Sat Jun 25, 2022 7:58 pm    Post subject: Re: New classic manx #93 Reply with quote
Raptor Liner the floor pan's and I got to say I really like this stuff. I used the spray gun and a gas compressor but you apparently can roll it on also. Took about 3 bottles to do it.
A video of applying the liner
matthewl
matthewl is offline
PostPosted: Sat Jul 02, 2022 11:09 pm    Post subject: Re: New classic manx #93 Reply with quote
Another big leap in the build. Had to drill holes in new body to mount her down.
Had to clearance some of the body by the Napoleon's hat. But other than that it went on easy. Here's a video of the progress
matthewl
matthewl is offline
PostPosted: Thu Jul 07, 2022 7:55 pm    Post subject: Re: New classic manx #93 Reply with quote
Well I got the dash fiberglass on. Forgot to take pictures but I did video some of it.
[/vimeo]
Page 5 of 9
