malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Sat Jul 02, 2022 2:16 pm Post subject: DELUXE with a weak clutch return |
Tell me what is up here. I am ready to mount the engine, but I am giving everything a final test.
My helper is stepping on the clutch pedal and RELEASING it. When I say RELEASE, they remove their foot. The pedal slowly returns to the up position at the speed you are seeing the TO lever move. Very weak.
Tranz has been rebuilt, so it is "NEW". It has been about a year since I got it back. Should I maybe lube the ends of the TO lever? Does it look like I need a new spring? I should ask my rebuilder if that was new?
Will this slow return be corrected once the clutch assembly, flywheel and engine are attached??
_________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing)
SGKent Samba Member
Posted: Sat Jul 02, 2022 2:23 pm Post subject: Re: DELUXE with a weak clutch return |
only the last 1/2" to 3/4" of pedal play at the top is controlled by the TO arm spring. If you go much past that with the engine out the pedal will fall to the floor. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Jul 02, 2022 2:25 pm Post subject: Re: DELUXE with a weak clutch return |
SGKent wrote: |
only the last 1/2" to 3/4" of pedal play at the top is controlled by the TO arm spring. If you go much past that with the engine out the pedal will fall to the floor. |
regardless of where I RELEASE the pedal it does not SPRING back as I would suspect.
Am I over thinking this? _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Starbucket Samba Member
Posted: Sat Jul 02, 2022 2:42 pm Post subject: Re: DELUXE with a weak clutch return |
Remember your pressure plate is a giant spring that will push it back, just make sure the last part of the TO arm travel springs back to remove the TO bearing from clutch pressure plate. |
Joined: January 01, 2007 Posts: 16865 Location: sticksville, ct.
Posted: Sat Jul 02, 2022 3:34 pm Post subject: Re: DELUXE with a weak clutch return |
malcolm2 wrote: |
Am I over thinking this? |
yes
the p/p throws the clutch pedal back. the TOB always kisses the p/p a bit _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
Posted: Sat Jul 02, 2022 8:13 pm Post subject: Re: DELUXE with a weak clutch return |
TO bearing should snap back smartly when pedal is released.
The lever spring is a strong thing if it is not sick, there should be no question about it's ability to slam the bearing back. If it's not a broken return spring, I suspect your shaft bearings in the trans body are either horribly gummed up or else the locating screw is located improperly and is binding up the shaft. _________________ '67 bug: seized by the authorities
Posted: Sat Jul 02, 2022 9:09 pm Post subject: Re: DELUXE with a weak clutch return |
kreemoweet wrote: |
The lever spring is a strong thing if it is not sick |
all true but he has the cable and pedal attached
just a bare arm and a TOB installed, yes i agree it should snap back with authority _________________
Jake Raby wrote: |
Brian wrote: |
timvw7476 Samba Member
Posted: Sun Jul 03, 2022 12:18 am Post subject: Re: DELUXE with a weak clutch return |
there's something amiss there chief. The TO bearing is riding proud on the guide. You need to lose that lugnut spacer you have on the cable. Reason being, I assume you are mounting a new clutch disc, & maybe even pressure plate. The new disc does change the point of engagement versus the olde tired worn-down friction disc. So get the lugnut out of there, & re-check. You should be further in the housing at that point. AT least I hope for that. Also check/set the Bowden Tube 'sag', as per the Bentley Book, the sag at the rear torsion helps the cable live on very long happy life. Enjoy. : )
EDIT: the sag gets tuned via washers, stacked at the nipple exit of the clutch cable, they force the Bowden Tube to 'sag' near the mounting tang at the torsion. Once that's done, you 'tune' the clutch play via the wing nut at the cable end. All your new clutch parts throw the old adjustment out of whack. New friction = New adjustment. |
Posted: Sun Jul 03, 2022 6:58 am Post subject: Re: DELUXE with a weak clutch return |
Everything is new or replaced here.
I believe this bus was last registered in the 90’s.
The bug nut spacer is not new. It was there when i bought it. All it does is save a few turns of the wing nut and if needed, will give a bit mote length to tighten.
I wondered about the resting place of the TO bearing. At this point it seems high as you said. But any lower and the pedal will not fully rise.
I will read-up and adjust the Bowden tube today. Thanks for the help so far. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
mikewire Samba Member
Joined: March 22, 2010 Posts: 805 Location: San Antonio, TX
Posted: Sun Jul 03, 2022 8:08 am Post subject: Re: DELUXE with a weak clutch return |
Yeah...don't expect the little clutch linkage spring to do much by itself, the pressure plate does that job. As others have said, the clutch pedal won't return properly without everything, including the PP installed.
I second removing the spacer nut on the clutch cable. Right now it is causing your clutch arm and TB to ride too proud. Also note, when you get everything back together you'll need just a bit of slack in your clutch pedal before it engages the TB, if you leave the nut there I don't think it will allow enough slack.
That Bowden tube sag is also important to the function, you need just enough, and I think mine I stacked 3 spacers and that was just right.
IIRC the clutch info you need for proper adjustment is all in the Bentley. _________________ -Mike
@countdowngarage
@bigskyeuro
1972 VW Kombi 9 Passenger Deluxe w/ 2.0L F.I. VWAC swap
1965 VW Beetle Deluxe Bahama Blue |
Posted: Sun Jul 03, 2022 9:21 am Post subject: Re: DELUXE with a weak clutch return |
kreemoweet wrote: |
The lever spring is a strong thing if it is not sick, there should be no question about it's ability to slam the bearing back. If it's not a broken return spring, I suspect your shaft bearings in the trans body are either horribly gummed up or else the locating screw is located improperly and is binding up the shaft. |
your comment about the shaft bearings..... the engine is not installed as the video showed. there are no spinning shafts in the video.
I am thinking the same about your Locating Screw comment. What is that? and would it be tranz operational.... cause in the video the tranz in not operating. The TO bearing is all that is moving.
Please provide more info, not sure what your suggested parts do here. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Sun Jul 03, 2022 11:12 am Post subject: Re: DELUXE with a weak clutch return |
Take that nut out, its also flexing the cable to make it break.
The wing nut has points that rest in notches in the lever, acting as pivots so the cable is not flexed. .
As others say, put washers as spacers between the Bowden tube outer and the bracket on the side of the gearbox, to get the correct curve for the Bowden tube.
The washer stack also sets the adjustment range for the wing nut.
The outer of the curved Bowden tube is a spring which comes into play as the release bearing starts to press on and move the fingers on the clutch pressure plate. The Bowden tube outer shortens slightly as the load comes onto the inner of the cable, makes the clutch biting point more progressive over a longer pedal movement. _________________ Ancient vehicles and vessels
Posted: Sun Jul 03, 2022 11:29 am Post subject: Re: DELUXE with a weak clutch return |
malcolm2 wrote: |
I am thinking the same about your Locating Screw comment. What is that? |
I should have said "bushings" instead of bearings, the ones for the T/O bearing shaft. I've seen numerous scored-up T/O bearing shafts, and
mashed bushings, because the locating bolt was tightened down when the bushings were out of proper position.
Also, I confess I made my remarks before I watched the video. It actually doesn't look all that bad, just a little on the sluggish side.
My clutch pedal always returns fully upright just from the tension of the T/O bearing return spring, and right smartly too.
I can pull the pedal fully upright with the cable by hand, using less force than the spring exerts. There's quite a few places forward
of the spring where excess friction on the cable and pedal shaft can occur. _________________ '67 bug: seized by the authorities
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Wed Jul 06, 2022 10:02 am Post subject: Re: DELUXE with a weak clutch return |
If you are this far in repairs take the pedal cluster apart for a good clean and lubrication. No one ever PM's those items. |
Posted: Wed Jul 06, 2022 6:45 pm Post subject: Re: DELUXE with a weak clutch return |
ToolBox wrote: |
Might have to check it, but I pulled and cleaned everything but the wires in this baby. Got some new fangled linkage for the accelerator too.
I still need to check the bowden tube as suggested earlier. I got side tracked on some electrical gremlins.
Thanks _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Thu Jul 07, 2022 9:48 am Post subject: Re: DELUXE with a weak clutch return |
malcolm2 wrote: |
ToolBox wrote: |
Thanks |
The clutch and brake pedals ride on bushings no one except Skillz takes apart, cleans and lubes. On my 59 the bushing was seized to the shaft and was rotating in the frame. Cleaned it all up, replaced the bushings, lubed and reassembled and it was all good. |
