LarryMart Samba Member
Posted: Sat Jul 02, 2022 4:12 pm Post subject: unknown wire engine bay |
I have an unattached red wire coming from some where in the front of the engine compartment to the area of the left tail light. It is not attached and idk what it is to. The van has A/C which is not running (belt off - idk] might it have something to do with that?
Sorry for the mysteries. I can not get a hold of the PO this week and I had hoped to figure some things out this weekend.
Happy 4th or 1st,
Thanks
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Sat Jul 02, 2022 4:59 pm Post subject: Re: unknown wire engine bay |
the joys of PO wiring (and my own after i forget what i did).
looks like a pretty heavy gauge wire. to be safe, i would at least cover the end of it. sometime later have a look to see what it is connected to. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32433 Location: Reading Pennsylvania
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1477 Location: Victoria,B.C.Canada
Posted: Sun Jul 03, 2022 4:46 am Post subject: Re: unknown wire engine bay |
My 88 Wolfsburg has a large red running from the alt to up inside that DS pillar for the AC. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7733 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Jul 03, 2022 9:05 am Post subject: Re: unknown wire engine bay |
Today’s a great day to get on your back under the van and see where the other end of
that wire goes ahead of the firewall. Judging by the color and gauge, it could benefit
from a grommet there at the sheet metal to prevent unintended fireworks…
<shrug>
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
DuncanS Samba Member
Joined: October 17, 2013 Posts: 4580 Location: New Hampshire
Posted: Sun Jul 03, 2022 11:42 am Post subject: Re: unknown wire engine bay |
Holy moly--The other end must not be connected, otherwise you would have burned up long ago. Agree with the grommet. Looks like at some point, someone might have had a small inverter/aux battery--charging wire? in front of the DS taillight. Definitely check it out both with a volt meter key off and key on. And do crawl under and find out what it was attached to. If nothing, just remove it, but it sure is scary looking like it is.
Duncan |
Posted: Mon Jul 04, 2022 2:22 am Post subject: Re: unknown wire engine bay |
Definitely tape it off or if reasonable remove it. POs love to add stuff and then remove it when they sell the rig, leaving behind the all too often unfused wiring they added just waiting to burn up your new purchase. |
