2type2 Samba Member
Joined: June 02, 2002 Posts: 978 Location: SW Colorado
Posted: Sat Jul 02, 2022 9:44 am Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
Interior mechanics/physics of a distributor? That's not in my current bank of knowledge .... I need to be schooled. _________________ "A life of peace and happiness depends on your own gratefulness" |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3578 Location: viroqua wi.
Posted: Sat Jul 02, 2022 2:36 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
On a vacuum and mechanical or mechanical only distributor you set the timing to the mechanical only all in point. 28-30 degrees BTDC. Assuming you have a pulley with the correct marking for TDC and that your distributor vac line or lines are installed correctly under no load it would be expected to see close to 40 degrees at full in throttle. |
2type2 Samba Member
Posted: Sat Jul 02, 2022 3:35 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
I know. Idle is at 34-35-° mechanical advance at 850 rpm, I am trying to get 30° max at idle, not up to 35° ar idle. I'm not familiar with adjusting. the limiting tabs at the weights. _________________ "A life of peace and happiness depends on your own gratefulness" |
Jason37 Samba Member
Posted: Sat Jul 02, 2022 8:23 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
2type2 wrote: |
I know. Idle is at 34-35-° mechanical advance at 850 rpm, I am trying to get 30° max at idle, not up to 35° ar idle. I'm not familiar with adjusting. the limiting tabs at the weights. |
Wait, 34-35 at idle? Idle should be close to 10-12. What are you reading at 3000rpm? |
Fender38 Samba Member
Joined: April 11, 2015 Posts: 75 Location: Las Vegas, NV
Posted: Sat Jul 02, 2022 11:24 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
Jason37 wrote: |
2type2 wrote: |
Ya, it doesn't sound right. I think they've got things mixed up. Here's what they posted earlier. This makes more sense.
2type2 wrote: |
...timing light shows 7.5 btdc. Running up to 3400rpm w/ vac plugged-- shows advance at 34°. I'ld like that mechanical total advance to be at 30°, not the 34°.
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Sat Jul 02, 2022 11:38 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
I think it works more by the oil splashes on top of the drive gear. The nose of the distributor is resting in a pool of oil which reaches the hole no matter which way it faces. From where it gets pumped up the inside of the distributor by a spiral groove in the shaft inside the distributor.
Also the window is a good place to drop the spring into the engine... _________________ Ancient vehicles and vessels
2type2 Samba Member
Posted: Sun Jul 03, 2022 6:53 am Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
Smh.NOT making shit up dude,thanks. Confused working on 2 engines simultaneously , doing same conversions , leading to my miscommunicating.
PROBLEM IS THIS:
Idle at 850 ,dwell at 50, advance at 7.5 btdc----- strobe shows max mechanical advance going to 35° at 34-3500 rpm--vac plugged-----want it at 30° max. Won't idle well if set at other than 7.5 btdc.
I am seeking instruction on readjusting the distributor stops which control the weights, so my max mechanical advance will be at 30°.Overheating is the problem to eliminate. _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Sun Jul 03, 2022 7:11 am Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
I would reset your dwell to 44 and recheck your timing. |
2type2 Samba Member
Posted: Sun Jul 03, 2022 7:19 am Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
Dwell at 44, why?That's way low. _________________ "A life of peace and happiness depends on your own gratefulness" |
2type2 Samba Member
Posted: Sun Jul 03, 2022 8:02 am Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
While I always appreciate help and insight ,it often escapes me why people offer suggestions without stating the expected outcome or what the results of any approach would/should be. Just a simple -"here's what you're looking to see happen- or not happen" -would go a long way in being able to grasp the whole concept of where the test or adjustment is leading
I learned to drive in a 63 bug and after screwing around with them for over 45 years on and off ownerships of different ones, I still don't claim to know more than enough to just get me in trouble,and hopefully get me home.¹ _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Sun Jul 03, 2022 8:48 am Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
2type2 wrote: |
Dwell at 44, why?That's way low. |
Totally within spec. |
Posted: Sun Jul 03, 2022 9:35 am Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
The outcome of adjusting your dwell is it changes timing. A change of only 0.10 mm (.004 in.) in the point gap will alter ignition timing about 3 degrees. |
Posted: Sun Jul 03, 2022 10:36 am Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
bsairhead wrote: |
It will alter the ignition timing, but it won't change the amount of mechanical advance provided. This could potentially shift the timing 4 deg, providing the desired 30 deg full advance. But this is only acceptable if 2type2 is okay with 3.5 deg advance at idle. If they adjust it back to 7.5 deg at idle, then they're back to 34 deg total advance.
2type2, give the dwell adjustment a shot, it that's something you can live with then call it a day. If not and you want to adjust the total amount of mechanical advance, I'd recommend searching for a video demonstration on YouTube. VW specific of course. |
Posted: Sun Jul 03, 2022 10:58 am Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
What model distributor are you using? |
2type2 Samba Member
Posted: Sun Jul 03, 2022 12:52 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
Dist is a "recommended by" cip1 Chinese clone, svda. What am I "living with" by leaving idle timing at 3.5°? As currently set it idles well, yet it won't idle well at all if off of 7.5 btdc. _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Sun Jul 03, 2022 1:28 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
2type2 wrote: |
Dist is a "recommended by" cip1 Chinese clone, svda. What am I "living with" by leaving idle timing at 3.5°? As currently set it idles well, yet it won't idle well at all if off of 7.5 btdc. |
I think you could figure a way to limit the advance. Take it apart, you have nothing to loose. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Sun Jul 03, 2022 1:29 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
Egads!
Welcome to the Samba..
Remove the distributor,
Strip off the cap, rotor, pull the point plate,
And down in there you will see the advance weight mechanism.
Look carefully and you’ll see two little arms that stick up and limit how far the weights can move.
They are long enough that you can bend them in with needle-nose pliers.
This will limit advance.
Put it back together and check it with your light.
Might take a try or two.
Have fun! _________________ Bus Motor Build
What’s That Noise?!? |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3443 Location: San Diego
Posted: Sun Jul 03, 2022 2:09 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
Maybe idle speed needs adjusted when you have the advance set correctly |
BFB Samba Member
Posted: Sun Jul 03, 2022 2:15 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
“Egads!” Is right! Three pages of discussing setting a dizzy… wtf?
This is one of the easiest things to do, especially on a vw.
Follow what clatter said to limit timing.
Vw doesn’t care where the gear is or which dizzy cap tower is number 1 as long its timed according to #1 cyl.
If your reading 30* advance at idle on an svda then you probably plugged your vacuum can into manifold vacuum.
K.i.s.s. Because it is… _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sun Jul 03, 2022 2:31 pm Post subject: Re: Distributor drive set proper, but can't spin svda way to adjust |
BFB wrote: |
K.i.s.s. Because it is… |
You and Clatter, said the quiet part out loud!
< I've been doing this for the last couple days. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
