Shamu63 Samba Member
Posted: Thu Aug 23, 2007 9:07 pm Post subject: My overheat solved.... |
A couple weeks back I posted about my engine overheating and all the fixes I tried at home. After doing all I could think of and taking all the advice I was given from this forum I wound up taking my 181 into R&S performance in Orlando (Thanks Scooter).
Scooter fixed a number of things which were contributing to the overheat problem; wrong size tins, bad heat seal around the engine pan, bad exhaust install, Bad heat exchangers for heater, timing, etc...
I'm happy to say, my temps stick around 280 through 3rd gear, in 4th it slowly creeps into the 320's 330's and we're working on that, possibly larger jets. But after 15 miles the max temp hit 338 and didn't seem to want to go higher, so it's hot but not destructive.
Anyway, I just wanted to say thanks to all of you who posted on my original thread. If you're going to be in Orlando send me a Message and maybe we can hang out for a beer or something.
Shamu |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Thu Aug 23, 2007 10:25 pm Post subject: |
Congrats! Glad you got it solved. |
bciesq Samba Member
Joined: April 13, 2005 Posts: 495 Location: Orlando, FL
Posted: Fri Aug 24, 2007 3:55 am Post subject: |
Scooter is a good guy. Glad you're back on the road. _________________ '73 Thing -- making 45 mph exciting again. |
volkybus Samba Member
Joined: November 03, 2013 Posts: 481 Location: CASTLETON VT USA
Posted: Sun Jun 26, 2022 8:25 pm Post subject: Re: My overheat solved.... |
280°f seems too hot for me..Is that a normal running temp then upto 300+ I thought it was supposed to be around 180-220. Mine runs at 240-260 so I thought it was overheating. I checked the thermostat and run my hood open at the T op like a bug..And where do u put the sending unit for the oil temp gauge? Mine is in the pressure relieve hole..Is this right,? Thanks for all your input on this..I'm a bus man at heart but alas they don't make a convertible
..Bill. In Vt |
THINGONER Samba Member
Joined: April 13, 2008 Posts: 674 Location: riverside ca
Posted: Sun Jul 03, 2022 8:28 am Post subject: Re: My overheat solved.... |
I think the O.P. was talking about cylinder head temp not oil temp. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Sun Jul 03, 2022 12:40 pm Post subject: Re: My overheat solved.... |
THINGONER wrote: |
Let's hope so! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Sun Jul 03, 2022 12:44 pm Post subject: Re: My overheat solved.... |
mondshine wrote: |
THINGONER wrote: |
Let's hope so! |
Let's not assume _________________ Glenn
Member #1009
#BlueSquare |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
