Door side hinges pulled out
viiking
viiking is offline
PostPosted: Fri Jul 01, 2022 7:24 pm    Post subject: Door side hinges pulled out Reply with quote
I have a really good rust free door from a Typ1 68 which has sustained damage to the door side hinges. The top one has one of the rivet heads come loose from the door body. I assume this isn’t critical as the hinge itself is attached to the support plate inside the door.
Should I give it a small tack weld so that it doesn’t separate any more
The second shows the lower hinge. I had to remove the hinge completely due to other issues. The rivet holes in the door are much bigger than for the head of the original rivet. I am going to replace the rivets with 8mm countersunk screws but the heads will be smaller than the holes.
How do I fix this? Is it a cut and paste a new piece of metal and redrill or should I insert the new bolts and weld the gap closed? Or some other idea?
infiniteLoop
infiniteLoop is offline
PostPosted: Sun Jul 03, 2022 7:53 pm    Post subject: Re: Door side hinges pulled out Reply with quote
What if you put a counter sunk screw through it backwards and welded that in?
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sun Jul 03, 2022 11:40 pm    Post subject: Re: Door side hinges pulled out Reply with quote
On the 54, I welded in new steel, then dimpled the metal with a taper head screw. Worked great!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
viiking
viiking is offline
PostPosted: Wed Jul 27, 2022 5:59 pm    Post subject: Re: Door side hinges pulled out Reply with quote
I gave up on trying to repair it. The metal was too thin so I’m currently grafting in a complete inner rear section complete with the hinge. It should work out ok.
However I tried to get some countersunk screws to fit the upper hinge but these remain too “proud” of the frame. I can’t seem to find M8 countersunk screws which have a narrow enough head angle. The standard M8 bottoms out on the dimpled hole before the top of the head becomes flat.
I don’t think I can enlarge the hole any more than it is as the metal will be too thin and the hinge may pull loose bringing me back to where I started with.
Does anyone have a part number or solution to this so the head of the bolt remains flush like the original rivet? I know I could get it machined but no one is interested in doing a few bolts so I was hoping I could buy something ready made.
bomberbob
bomberbob is offline
PostPosted: Thu Jul 28, 2022 6:34 pm    Post subject: Re: Door side hinges pulled out Reply with quote
If you look at the McMaster Carr website, you should be able to find screws that will fit. I think you want to get screws with a different countersink angle. Variables you will need to select are stainless steel versus other alloys, phillips head or torx, screw size and length. With all these variables I can't give you a part number.
1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa
VW_Jimbo is offline
PostPosted: Mon Aug 01, 2022 11:17 am    Post subject: Re: Door side hinges pulled out Reply with quote
Or you can buy rivets. In the classified section there are ads for those rivets. Super easy to install with the door off the car!
Jimbo
viiking
viiking is offline
PostPosted: Mon Aug 01, 2022 6:34 pm    Post subject: Re: Door side hinges pulled out Reply with quote
I'm in Australia so they wouldn't ship under the price of a new kidney. Very Happy
