Gdv Samba Member
Joined: April 19, 2013 Posts: 20 Location: New Zealand
Posted: Sun Jul 03, 2022 1:30 am Post subject: Movement in rear hub/wheel |
Hi I have a kombi with a straight axle conversion. Have a problem iwith movement in the hand rear hub . Rotate the wheel 180 degrees and there is no movement.. wheel bearing has been replaced with no improvement . |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3438 Location: San Diego
Posted: Sun Jul 03, 2022 4:39 pm Post subject: Re: Movement in rear hub/wheel |
Movement which way or how? Need more info or pic? |
Gdv Samba Member
Posted: Sun Jul 03, 2022 8:36 pm Post subject: Re: Movement in rear hub/wheel |
chrisflstf wrote: |
side to side feels like a stuffed bearing . Spin the wheel approximately 180 degrees and there’s no sideway movement |
Posted: Mon Jul 04, 2022 7:31 am Post subject: Re: Movement in rear hub/wheel |
Bent axle? Not enough info to diagnose |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Mon Jul 04, 2022 8:14 am Post subject: Re: Movement in rear hub/wheel |
Gdv wrote: |
has this ever worked? or did you just put it in? _________________ regards
Uli
Gdv Samba Member
Posted: Mon Jul 04, 2022 11:44 am Post subject: Re: Movement in rear hub/wheel |
mandraks wrote: |
Gdv wrote: |
has this ever worked? or did you just put it in? |
It was a used gearbox and the the play was first picked up when I went for compliance |
Posted: Mon Jul 04, 2022 3:12 pm Post subject: Re: Movement in rear hub/wheel |
Bent drum or bent wheel? Compare parts from one side to the other, or pay a mechanic if you cant. Maybe explain the compliance check and what they found or told you. |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1255 Location: Bay Area, California
Posted: Mon Jul 04, 2022 8:10 pm Post subject: Re: Movement in rear hub/wheel |
Gdv wrote: |
If you have a Bus Boys style straight axle kit, the axle tube where it mounts to the spring plate has three bolts that can come loose over time, and need to be re-torqued every so often. Check here, also another one in front of the axle:
_________________ "OG = Original German" -- TheSamba.com dictionary |
Gdv Samba Member
Posted: Tue Jul 05, 2022 2:24 am Post subject: Re: Movement in rear hub/wheel |
Split 66' wrote: |
Gdv wrote: |
Hi wish it was that simple but I think it’s in the gearbox |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Tue Jul 05, 2022 7:37 am Post subject: Re: Movement in rear hub/wheel |
Might be a long shot, try swapping drums side for side, correctly torqued, to see if it changes. Check for worn splines in the drum too. _________________ Tim |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Tue Jul 05, 2022 6:23 pm Post subject: Re: Movement in rear hub/wheel |
Do you know what the fulcrum plates are? They are inside the sides where the axle goes in. If one or both fulcrum plates are out of location the axle will behave as you describe. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Tue Jul 05, 2022 8:10 pm Post subject: Re: Movement in rear hub/wheel |
It can be a problem trying to diagnose and fix problems with modified buses. Since it sounds like you didn't install the mods, it can be a real research project to figure it out. Unless you get a "blueprint" listing of all the components and their installation details, you're kind of on your own.
I bought an IRS modified lowered bus and was getting in and out drum play even though the axle nuts were torqued down. Turns out it needed spacers between the bearing face and inner drum to get the drums properly tensioned on the splines. The spacers which came installed were too thin. Had to have proper thickness spacers machined, as there's no stock spacer made for mounting Thing drums on an IRS modified bus. Oh, and the Thing drums had to have the snout machined down to match the spline length. Another custom item which I couldn't buy anywhere. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Gdv Samba Member
Posted: Wed Jul 06, 2022 1:16 am Post subject: Re: Movement in rear hub/wheel |
BarryL wrote: |
Yes I’m thinking this is the problem after speaking to a mechanic who come across this problem |
