Name This Part (engines, body, misc.)
Page: Previous  1, 2, 3, 4, 5, 6, 7
16CVs
16CVs is offline
PostPosted: Sat May 28, 2016 7:04 am    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
The flat 3 connector is for cruise control.
Stacy
Samba member # 14980
Paulbeard
Paulbeard is offline
PostPosted: Sat May 28, 2016 8:07 am    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
That rats nest looks so familiar. I even have the same yellow connectors hanging loose. What do those go to?
Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
Git 'r DONE!
— dhaavers
Brunswicken
Brunswicken is offline
PostPosted: Sat May 28, 2016 8:10 am    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
Thanks for the info. 61Scout, I'll test that blue/grey wire for voltage.
Brunswicken
PostPosted: Sat May 28, 2016 8:13 am    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
T3 Pilot gave me some info via PM. Need to check the engine compartment (control box, might be there)
Brunswicken
PostPosted: Sun Jul 17, 2016 7:31 am    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
looking for your help again. This time it looks like I have a leak in my k14 turbo setup (1.9 TD AAZ ). Seems to be coming from this hose. Don't know what this part is or what part number could be used to replace this one. Anyone know what part this is?
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Jul 17, 2016 8:13 am    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
Brunswicken wrote:
looking for your help again. This time it looks like I have a leak in my turbo setup...
Not having any idea what engine you have may make it hard for someone to help.
That said, if you remove the hose and go to a friendly auto parts store when they are not very busy they may help you peruse their selection of hoses for something close. Sometimes a section of a longer molded hose can be cut down to meet the requirements.
Mellow Yellow 74
Mellow Yellow 74 is offline
PostPosted: Sun Jul 17, 2016 5:05 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon)
Alan Brase
Alan Brase is offline
PostPosted: Sun Jul 17, 2016 5:15 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
Mellow Yellow 74 wrote:
Actually, I think he edited that in later, so Ahwahnee's statement made more sense in real time. I think that is the breather hose that goes to the separator on top of the valve cover.
Al
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
Brunswicken
PostPosted: Sun Jul 17, 2016 7:09 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
Yes I edited my original post. Thanks for the info guys. Got the hose of the van and will bring it to the autocrats store tomorrow.
Alan Brase
PostPosted: Sun Jul 17, 2016 7:30 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
AAZ's are kinda thick on the ground in Canada, having never been imported int the US, tho. It may be the same part as a Jetta or Golf.
Al
Al Brase
Vanagons:
TheArmand
TheArmand is offline
PostPosted: Sun Aug 21, 2016 12:20 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
While cleaning my engine grounds yesterday I found this lone yellow connector underneath the coil. Anyone know what it's for? The closest thing I can find suitable to connect to was the yellow connectors that lay on top of the a/c compressor, but those yellow connectors are already connected. I'm having some serious problems with the engine refusing to idle & dying on cold starts, only cold starts. Wondering if this has anything to do with it, or something else perhaps. 1988 passenger Vanagon GL, 2.1 WBX. Thanks in advance!
Gnarlodious Premium Member
Gnarlodious is offline
PostPosted: Sat Sep 11, 2021 10:09 am    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
Sliding door spacer shim? While up on a ladder cleaning out crud I found this shim thing in the the upper sliding door support for the slider, it was laying down loose in the channel. I have never even looked up there in the 20 years I owned this van, so it could have been there that long:
Does it look familiar? How would such a thing even get up there randomly?
Alan Brase
PostPosted: Sat Sep 11, 2021 9:59 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
I'll have to ferret out my VW factory tools book (or the air-cooled 2.0 liter part of the Bentley) and look at pictures, but I believe it is the the hub removal tool for the cooling air fan hub ant the rear of the air cooled engine. You just insert this C between the hub and the backmost part of the crankcase, position the fan attachment bolts in the right position then draw them down evenly and the hub should pull off the tapered nose of the crankshaft.
CORRECTION: If this is indeed 11mm between the flats, That is not what is pictured here.
Al Brase
Vanagons:
xflyer
xflyer is offline
PostPosted: Thu Jul 21, 2022 4:36 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
This is probably covered elsewhere; There were some questions about the starter solenoid/relay.
The problem is that the stock starter solenoid takes about 10-15 amps, or more, for the initial pull in. Probably 8 to hold while cranking. As others have mentioned, electricity travels from the battery to the fuse/relay panel, to the ignition switch, and back to the starter solenoid. Over time those wires and connections have more resistance than new. And the starter may need a little more current when its old and hot. Eventually when you try to crank the engine nothing happens. If you put a voltmeter on the 50 terminal of the starter solenoid you will see something below 9 volts. Often not enough to actuate the solenoid.
So relay to the rescue. I like the Bosch WR 1 kit. Ready to install. The relay needs about 1/2 an amp to close its contacts. Then it will connect the big cable from the battery at the solenoid direct to the 50 terminal. Unless the battery is very low or the starter is needing replacement, it will crank..
Many different companies made similar kits, usually called a "starter booster".
Someone got the idea to use the "Ford" remote solenoid : https://www.rockauto.com/en/moreinfo.php?pk=42859&cc=1133299&pt=4188&jsn=457
Which would often work. I found that the "Ford" solenoid needed near as much electricity as the Bosch solenoid on the starter. Replaced many of the "Ford" ones with the Bosch type.
Having the WR1 relay reduces the need to crawl under and tap the solenoid. Or wait till everything cools off. Or push start.
https://www.busdepot.com/wr1
1989 Campmobile, 1984 7 passenger beater Vanagon
Both with cool A/C
LordHuron95
LordHuron95 is offline
PostPosted: Tue Jul 26, 2022 1:13 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
That looks very similar to the connector that goes to my oil pressure sensor in my 1980 AC.
bobhill8 Premium Member
bobhill8 is offline
PostPosted: Tue Jul 26, 2022 1:40 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
Hey The Armand - what color is the wire? It looks like it might be gray with white?
1986 Westy
1971 Squareback
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Jul 26, 2022 2:06 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
Armands question was from some years ago.
That wire is found on the 88/89 version Digifant harness.
It was intended for the emissions system OBD fault code light on the dash that California was trying to require but didn't until years later.
If you look in the 88 Owners Manual it is explained and shown on the instrument cluster but afaik no vans came with it.
There is a matching wire inside the engine compartment wiring box and that wire would have been plugged in there.
Mark
xflyer
xflyer is offline
PostPosted: Tue Jul 26, 2022 2:25 pm    Post subject: Re: Name This Part (engines, body, misc.) Reply with quote
CRAZYVWVANMAN is correct. If you are curious look at page 97.123 of the Bentley. There is, on current track 20 the "ECS-MAL IND LT AND SWITCH". Or as most call it the "CHECK ENGINE LIGHT". My 89 has an extra sticker on the emission label, on the back of the license plate door, "OBD_EXEMPT".
Both with cool A/C
Page 7 of 7
