blackdog1999 Samba Member
Joined: October 17, 2004 Posts: 1203 Location: Rancho Cordova, CA 95670
Posted: Tue Dec 26, 2017 3:39 pm Post subject: Stahlwille Tool General Thread |
Hazet tools has a couple of threads dedicated to just them. I thought I would start one for Stahlwille as I have recently acquired a very cool tool made by them.
Here is a Stahlwille 1415 clutch cable adjusting ratchet. There is a combination 10mm/14mm socket that is permanently mounted to the ratchet. It is hollow all the way through the socket & ratchet head so the cable can pass through as you tighten the nuts. The ratchet is only about 11cm / 4 1/4" long.
Has anyone seen this tool before or own one?
_________________ Home of the one true split Bus Motorhome |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Tue Dec 26, 2017 5:26 pm Post subject: Re: Stahlwille Tool General Thread |
Interesting.
If the socket part turns them both at the same time (looks like it does), I'm not sure how it would be helpful other than to run the nuts onto the threaded part of the cable and set the cable/pedal freeplay. The smaller nut (sometimes it has an 11mm head) is a locknut for the larger nut, so you'd have to tighten them with two wrenches after the freeplay is set.
Pretty cool. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Tue Dec 26, 2017 5:47 pm Post subject: Re: Stahlwille Tool General Thread |
Yes, I believe you would unlock & lock the nuts after you adjust them. I am guessing it was not a very popular tool as the wing nuts are much better & faster to work with. Any mechanic would want to install a wing nut to save on install time/money.
For the vintage guy it is super cool though. _________________ Home of the one true split Bus Motorhome |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Tue Dec 26, 2017 5:50 pm Post subject: Re: Stahlwille Tool General Thread |
I recall 11mm & 14mm wrenches required, even the KD tool kit with two ratcheting tools were 11mm & 14mm. No offense but but I do not see how that tool would work on the clutch cable, besides the 10mm sizing, the small nut needs loosened while the 14mm is held, one of the reasons I tossed that system and put wing nuts on.
Edit - Here is one of the KD Tools #50 for sale on ebay
https://www.ebay.com/itm/Vintage-NOS-Unused-Sealed....l4275.c10 |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Thu Dec 28, 2017 2:44 am Post subject: Re: Stahlwille Tool General Thread |
_________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Posted: Thu Dec 28, 2017 7:24 am Post subject: Re: Stahlwille Tool General Thread |
Google translation is Nut Long Screw Coupling Adjustable, so where is a German speaker when you need one?
Where the earlies 10mm x 14mm, the early sixty bugs/buses I worked on had 11mm. |
Posted: Thu Dec 28, 2017 8:54 am Post subject: Re: Stahlwille Tool General Thread |
Thanks for posting the catalogue page. That is very cool. _________________ Home of the one true split Bus Motorhome |
Posted: Thu Dec 28, 2017 11:22 am Post subject: Re: Stahlwille Tool General Thread |
Here is another very cool Stahwille tool. It is also in the above catalogue page. Tool #1024.
This is magnetic & attaches to the top 17mm bolt by the top of the transmission so one person can install the upper bolts/nuts.
Both have different stampings.
Martyn.griffiths Samba Member
Posted: Sun Dec 31, 2017 6:01 pm Post subject: Re: Stahlwille Tool General Thread |
Came across these at a local tip a few weeks ago. Wanted to find out a bit more and came across this thread, solves a few questions. Thanks.
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sat Feb 09, 2019 12:26 am Post subject: Re: Stahlwille Tool General Thread |
I have one of the 1024 tools... but, it has about 3.5’ of dash chain attached to it... with a little bell on the end.
Anybody know what would be a useful reason to attach the chain/bell?... where the chain:bell would be routed to?
Chain/bell makes me think the wrench might be left there... for continuous use/leave in place.
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Sat Feb 09, 2019 12:39 am Post subject: Re: Stahlwille Tool General Thread |
easy e wrote: |
Never seen that before but has to be so that it does not get forgotten & left stuck to the bolt behind the motor. 😁
I bet whoever did that to your tool had already lost one that way. 😂 _________________ Home of the one true split Bus Motorhome |
easy e Samba Member
Posted: Sat Feb 09, 2019 12:50 am Post subject: Re: Stahlwille Tool General Thread |
Thank you Corey. Sounds very reasonable. I bought it from Cambria Brad... after he lost his ability to speak. He was trying to explain it to me... emphasizing the importance of the bell. I wasn’t quite picking up what he was laying down.
He was selling the last of his stuff. Kitty was there helping... but I just didn’t want to ask him to write it down. I nodded as if I knew what he was trying to convey.
It was a hard day, I could tell his time was short.
It sucks to bargain with a dying man, no longer able to live his passion.
Happy to have been able to bullshit with him though and do a little of the inevitable haggle we all love. _________________ aka: Evan
velvetgreen Samba Member
Posted: Sat Mar 02, 2019 7:25 pm Post subject: Re: Stahlwille Tool General Thread |
I have those same tools in both 10/14 and 11/14. Never seen another set- they are very small (about 2.5") for obvious cramped areas
Posted: Sat Mar 02, 2019 7:26 pm Post subject: Re: Stahlwille Tool General Thread |
TK6A5 Samba Member
Posted: Fri Aug 05, 2022 11:05 pm Post subject: Re: Stahlwille Tool General Thread |
Reviving this thread. I am looking for the spark plug socket shown in the ad. Would anybody know of one? |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1276 Location: australia
Posted: Sat Aug 13, 2022 9:44 pm Post subject: Re: Stahlwille Tool General Thread |
a few more vw specific tools, another engine mount bolt tool + a roughly era correct torque wrench.
at one stage i had a VW style Stahlwille 77mm ring compressor too.
i ended up with my engine mount bolt tool as the mechanic i got it from had two. he left his first one on a car (not a regular customer) after a while bought the one i now have and 6-8 years later the car he left the first one on came back in... to his pleasant surprise his origination tool was still on the bolt under the car. 😁 |
TK6A5 Samba Member
Posted: Wed Mar 13, 2024 8:48 am Post subject: Re: Stahlwille Tool General Thread |
TK6A5 wrote: |
Bump, would love to find the sparkplug tool |
