Hammerhead69 Samba Member
Posted: Sun Aug 07, 2022 8:05 am Post subject: Shift Coupler Chatter |
I replaced the shift rod bushing & also installed a new shift coupler on our ‘71 Beetle but I’m still getting a (kinda noisy) chatter from the coupler area. What could it be? When I first removed the panel to get to the coupler there was a lot of foam padding crammed around the coupler. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun Aug 07, 2022 8:35 am Post subject: Re: Shift Coupler Chatter |
The foam was a Band-Aid to deaden the coupler (perceived) noise. When really the noise was caused by the worn shift rod bushing.
When I change the coupling, I use the stock cage and install the new plastic bits in it.
Make sure that the coupling grub screw is tight and safety wired in place.
Check your trans mounts, nosecone, and bellhousing cradle.
Look for the rubber bits separated from the metal plates. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Aug 07, 2022 8:44 am Post subject: Re: Shift Coupler Chatter |
Thanks. Everything I’ve replaced so far are the shift rod bushing, shift coupler (aftermarket poly), & the mounts at the bell housing cradle. The only thing I didn’t replace was the mount at the nose cone. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Sun Aug 07, 2022 10:21 am Post subject: Re: Shift Coupler Chatter |
Hammerhead69 wrote: |
shift coupler (aftermarket poly) |
Was it red in color? _________________ www.vwnos.com [email protected]
Michael Ambrozik Samba Member
Joined: October 17, 2020 Posts: 631 Location: San Jose, CA
heimlich VWNOS.com
Posted: Sun Aug 07, 2022 11:10 am Post subject: Re: Shift Coupler Chatter |
Your right, sorry. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sun Aug 07, 2022 11:53 am Post subject: Re: Shift Coupler Chatter |
67rustavenger wrote: |
When I change the coupling, I use the stock cage and install the new bits in it. |
That's what I did on my 1970 back in 2017. The brand new coupler actually did not fit so I used the old metal cage and the new black rubber/plastic parts.
So much for Chinese-made copies these days - can't even copy dimensions of a simple part......sad....and sad for the USA importers who don't even check this stuff yet put their name on it and sell it.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
heimlich VWNOS.com
Posted: Sun Aug 07, 2022 12:20 pm Post subject: Re: Shift Coupler Chatter |
Cusser wrote: |
sad for the USA importers who don't even check this stuff yet put their name on it and sell it... |
They keep me in business. If it doesn't fit I don't sell it. If it is crappy part I don't sell it. My complaints department is growing cobwebs. _________________ www.vwnos.com [email protected]
Posted: Sun Aug 07, 2022 1:12 pm Post subject: Re: Shift Coupler Chatter |
Yes it’s a red coupler from Jbugs, EMPI brand I think. It feels tight though. |
74 Thing Samba Member
Posted: Sun Aug 07, 2022 11:52 pm Post subject: Re: Shift Coupler Chatter |
If it is rattling it is not tight. Is there up/down plat or side to side play or plat between the screw and the shift rod. Fix the problem.
What shifter are you using? Is the shifter ball rattling in the shift rod cup? Look at that too. |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Mon Aug 08, 2022 8:31 am Post subject: Re: Shift Coupler Chatter |
Is it possible the hole through the shift rod has been egged out and so there’s extra play at the coupler? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Posted: Mon Aug 08, 2022 8:57 am Post subject: Re: Shift Coupler Chatter |
I just checked it again. There’s virtually no loose play at the coupler. Up & down as well as side to side there might be a millimeter of motion. There’s none forward & back. It doesn’t do it constantly while driving just randomly. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Mon Aug 08, 2022 9:17 am Post subject: Re: Shift Coupler Chatter |
If the “randomly” changes when accelerating or deceleration, then it’s probably due to a broken front transmission mount.
If it is a broken front mount, the easiest fix is a padded front strap kit. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
beetlenut Samba Member
Posted: Mon Aug 08, 2022 10:41 am Post subject: Re: Shift Coupler Chatter |
The red poly coupler transmits every little vibration from the transmission right up the shift rod. The original coupler (almost a neoprene-like substance) dampens most of that. After 50 miles of that, I tossed the red poly, and went back to my original coupler, and all was quiet again. Same with poly transmission mounts. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Mon Aug 08, 2022 11:19 am Post subject: Re: Shift Coupler Chatter |
beetlenut wrote: |
The red poly coupler transmits every little vibration from the transmission right up the shift rod. The original coupler (almost a neoprene-like substance) dampens most of that. After 50 miles of that, I tossed the red poly, and went back to my original coupler. |
Ok I think I’ll go back to the original (new one) & give that a try. |
