bcrazy Samba Member
Posted: Sun Aug 07, 2022 3:47 am Post subject: Modifying tri-mil hot dog exhaus to have equal length primaries? |
I have the hot-dog muffler on mye 1600 single port.
Mainly because it it she only cheap "performance" exhaust that exits in the stock peashooter locations.
It seem to be relatively little work to extend the primaries from cylinder 2&4 and cross them over to connect to the muffler on opposite sides, making them much closer in length to 1&3.
Similar to what they do on the CSP customsport
https://www.ahnendorp.com/Beetle-typ-1-engineparts...anguage=en
Would this make any noticeable difference to how the exhaust performs? |
Dauz Samba Member
Posted: Sun Aug 07, 2022 9:22 am Post subject: Re: Modifying tri-mil hot dog exhaus to have equal length primaries? |
Curious as to what your expectations are in taking this on |
bcrazy Samba Member
Posted: Sun Aug 07, 2022 10:48 am Post subject: Re: Modifying tri-mil hot dog exhaus to have equal length primaries? |
Dauz wrote: |
Just to make all primaries the same length
So if I do it must be worth the work, ie make the engine perform notably better, maybe exhaust sound also smoother |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Sun Aug 07, 2022 11:08 am Post subject: Re: Modifying tri-mil hot dog exhaus to have equal length primaries? |
bcrazy wrote: |
Dauz wrote: |
Without a merged collector it won't make a difference. Those hot dog mufflers are garbage for any thing performance oriented, they just sound like a great big fart _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Aug 07, 2022 12:59 pm Post subject: Re: Modifying tri-mil hot dog exhaus to have equal length primaries? |
X2 with mcmscott on this,my same thoughts _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sun Aug 07, 2022 3:33 pm Post subject: Re: Modifying tri-mil hot dog exhaus to have equal length primaries? |
Primary length is not the only problem the hotdog. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2222 Location: HdG, MD & NJ
Posted: Sun Aug 07, 2022 4:42 pm Post subject: Re: Modifying tri-mil hot dog exhaus to have equal length primaries? |
Cut the muffler in half and check out what’s going on inside. I opened an empi, monza type system and left and right exhaust connected to the same pipe. So, the pulses were dead heading right into one another, forced to exit through a bunch of holes drilled in the center. Anything is better than that concept, but nothing is ever as good as 4 into 1. A partition maybe needed. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
sled Samba Member
Posted: Sun Aug 07, 2022 6:50 pm Post subject: Re: Modifying tri-mil hot dog exhaus to have equal length primaries? |
a proper equal length merged system will do almost nothing on a 1600 single port, as the induction is extremely limited as well. Leave the exhaust alone and enjoy it. _________________ drive your split. |
Dauz Samba Member
Posted: Mon Aug 08, 2022 10:50 pm Post subject: Re: Modifying tri-mil hot dog exhaus to have equal length primaries? |
sled wrote: |
a proper equal length merged system will do almost nothing on a 1600 single port, as the induction is extremely limited as well. Leave the exhaust alone and enjoy it. |
Exactly my thoughts. Hence my question.. |
