heyskull Samba Member
Joined: August 07, 2022 Posts: 170 Location: Cumbria, England
Posted: Sun Aug 07, 2022 8:40 am Post subject: My first post and I am already asking for help. |
I have recently purchased a 1972 Westfalia.
Back in 2000 according to the paperwork the engine was changed from 1600 to type 4 1700.
This has had the original awful Solex carbs replaced with a pair of lot simpler Solex 34mm carb kit.
This has also had a 009 distributor allowing it to run without the vacuum advance.
It starts good from cold but when warm you have to give it some gas to fire up.
Also it stutters when pulling away and the smell of fuel outside is quiet strong (no leaks).
I have had the plugs removed and they are all black.
I believe this is a sign that it is overfuelling.
I am thinking checking the ignition timing and balance the carbs would be a good place to start?
I'm trying to find a base setting for these carbs and what jets should be fitted for a 1700?
Thanks
SC |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Sun Aug 07, 2022 9:21 am Post subject: Re: My first post and I am already asking for help. |
Wrong carburettors, wrong distributor.
The carburettors you now have are wrong.
The original carburettors working properly and set up with their original SVDA for a bus would get rid of 99 % of your issues.
Unfortunately you have been fed prime BS. _________________ Ancient vehicles and vessels
SGKent Samba Member
Posted: Sun Aug 07, 2022 9:36 am Post subject: Re: My first post and I am already asking for help. |
start by making sure the chokes are opening properly. Let's start there. If they fail to fully open then the mixture will be terribly rich. |
Posted: Sun Aug 07, 2022 9:39 am Post subject: Re: My first post and I am already asking for help. |
What is your fuel pressure? Too much fuel pressure can cause severe overfueling. |
Posted: Sun Aug 07, 2022 9:46 am Post subject: Re: My first post and I am already asking for help. |
These are the same as Heritage Parts Cantre supply for this engine:-
https://www.heritagepartscentre.com/uk/ac1293286-s...ype-4.html
But the owner has fitted an electric fuel pump as you can hear this tick on switching the ignition on.
Wildthings This maybe causing the overfueling issue?
Thanks
SC |
SGKent Samba Member
Posted: Sun Aug 07, 2022 9:53 am Post subject: Re: My first post and I am already asking for help. |
check to make sure the chokes are opening. If you don't start there you are really wasting your time asking for help. The choke power wires may have come off or broken in which case the chokes will stay closed. That will cause the engine to run right when cold and awful when warm. If the chokes are opening then the engine is jetted too rich. |
Posted: Sun Aug 07, 2022 10:46 am Post subject: Re: My first post and I am already asking for help. |
SGKent wrote: |
The chokes working was the very first check I did.
Started on VWs at the age of 12 and I'm 57 now.
First time working on a bay window in over 25 years, but our last bay had this engine except it was automatic.
SC |
Posted: Sun Aug 07, 2022 11:56 am Post subject: Re: My first post and I am already asking for help. |
heyskull wrote: |
Thanks
SC |
Too much fuel pressure will overcome the floats in the carbs allowing the fuel level to be too high especially at idle. |
SGKent Samba Member
Posted: Sun Aug 07, 2022 2:31 pm Post subject: Re: My first post and I am already asking for help. |
Wildthings wrote: |
heyskull wrote: |
Thanks
SC |
if the chokes work than one of five exist
1) fuel pressure too high;
2) floats set too high or they are worn out/ leaking, or sinking
3) Jetted way too rich.
4) really dirty air filter
5) on some occasions the ignition condenser can fail and cause all sorts of spark problems that mirrors a rich fuel problem because the spark is weak and intermittent. Sometimes a condenser can work fine at one temperature and not at others. |
nemobuscaptain Samba Member
