leeezrd Samba Member
Posted: Fri Aug 05, 2022 6:41 pm Post subject: Harbor Freight Engine stand - yoke needed? |
I am working on getting my engine mounted to a stand and just purchased a Harbor Freight stand (image below). Can I mount the engine directly to the yoke provided with the stand (see pic) or am I going to need to get a VW specific yoke?
74 Thing Samba Member
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Fri Aug 05, 2022 9:11 pm Post subject: Re: Harbor Freight Engine stand - yoke needed? |
The tiny mounting points would put an awful amount of pressure on a mag case.
I bought the 3 arm yoke from the guy here on Samba and used the HF stand. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Fri Aug 05, 2022 9:26 pm Post subject: Re: Harbor Freight Engine stand - yoke needed? |
Pruneman99 wrote: |
https://www.thesamba.com/vw/classifieds/detail.php?id=606308
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Fri Aug 05, 2022 9:58 pm Post subject: Re: Harbor Freight Engine stand - yoke needed? |
Yeah that's the guy. You linked to his 4 arm. I have the same 3 arm like you Rust.
The 3 arm is very stout. You could hold up a truck with the 4 arm I bet. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Fri Aug 05, 2022 10:07 pm Post subject: Re: Harbor Freight Engine stand - yoke needed? |
I use a Harbor Freight stand and an VW specific, 2 arm, Yoke. Got the Yoke from Pierside Parts. Drilled 4 holes into the pivot sleeve so a pin could hold the Yoke where I wanted it. Works pretty keen!
Here is the link to the Yoke. $60.00
https://www.piersideparts.net/CB6554.html
I also welded a glad nut to the opposite end of the yoke to assemble crankshafts easily. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
Posted: Sat Aug 06, 2022 1:32 am Post subject: Re: Harbor Freight Engine stand - yoke needed? |
VW_Jimbo wrote: |
I also welded a glad nut to the opposite end of the yoke to assemble crankshafts easily. |
Exactly what I did with the yoke from AA. |
ElskanTriumph Samba Member
Joined: March 28, 2020 Posts: 17 Location: New England
Posted: Sat Aug 06, 2022 5:46 am Post subject: Re: Harbor Freight Engine stand - yoke needed? |
I did it without the special yoke. I adapted it somehow (2 x 4s?) and I had no idea what I was doing. It worked out, but....
Buy the VW yoke. Do it right. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
rayjay Samba Member
Joined: March 26, 2008 Posts: 1506 Location: Buford GA
Posted: Sat Aug 06, 2022 8:05 am Post subject: Re: Harbor Freight Engine stand - yoke needed? |
The best setup I have seen use the 2 leg stand from Summit, the 2 or 3 arm head and a hydraulic lift table from HF . Not cheap but the easiest and safest way to transfer the motor around to all its temporary homes. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6609 Location: Houston, Texas
Posted: Sat Aug 06, 2022 11:17 am Post subject: Re: Harbor Freight Engine stand - yoke needed? |
This is the one I have. Buy it from TheSamba advertisers.
If you don't have a need for more than the 2 arm don't buy it. The 2 arm allows more maneuverability. For instance, I can attach my starting adapter and the 2 arm yoke at the same time. _________________ www.vwnos.com [email protected]
rayjay Samba Member
SLO-N-LO-69 Samba Member
Joined: July 06, 2006 Posts: 629 Location: Central Florida
Posted: Mon Aug 08, 2022 5:48 am Post subject: Re: Harbor Freight Engine stand - yoke needed? |
What makes the VW specific mounts better than the stock HF one? It looks like they all use the same mounting holes. Is there some other support I didn't see? Thanks. |
rayjay Samba Member
Posted: Mon Aug 08, 2022 7:49 am Post subject: Re: Harbor Freight Engine stand - yoke needed? |
SLO-N-LO-69 wrote: |
The engine case has a 360* raised ridge that interferes with normal engine stand mounting sleeves |
Sarge11B Samba Member
Joined: November 19, 2017 Posts: 61 Location: Athens, GA
Posted: Mon Aug 08, 2022 7:53 am Post subject: Re: Harbor Freight Engine stand - yoke needed? |
Be careful. These engine stand will fall over if you fart downwind. Joking but not joking. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Mon Aug 08, 2022 8:59 am Post subject: Re: Harbor Freight Engine stand - yoke needed? |
Also, No room for the flywheel with the HF mount. |
rayjay Samba Member
Posted: Mon Aug 08, 2022 10:49 am Post subject: Re: Harbor Freight Engine stand - yoke needed? |
Std engine stands can be made to work
