EJZero1 Samba Member
Joined: June 12, 2004 Posts: 147 Location: Colorado Springs
Posted: Mon Aug 08, 2022 4:33 pm Post subject: Rant: Why must the “last few steps” take so long?! |
Trying to button up the “last few steps” before I can crank the bus up. The current series of projects has taken a few months, and I (think) I see the light at the end of the tunnel.
Tweaking the cable-mounted throttle return spring on the 28 PICT 1 to get it to work smoothly, and have assembled/disassembled/reassembled no less than half a dozen times. For max clearance, I have disconnected plug wires and pulled the distributor cap. As I’m reassembling the return assembly again, that little tiny clip that secures the throttle cable flips off of the cable. Where does it go? Down into the very bottom of the distributor, of course. I stick my head into the engine compartment as far as I can and shine the flashlight down there. Sure enough, I can barely see the edge of the clip down in the belly of the distributor.
The thought of having to pull the distributor just to shake that little bastard out before I can continue with the “last few steps” is enough to make me consider throwing the flashlight across the garage and calling it quits for the day. I end up doing exactly that, with added expletives for good measure.
Why must these “last few steps” take so friggin long?!
Rant over. Thanks for tuning in. Now back to your projects that are obviously going smoother than mine! _________________ ‘60 Kombi, The “Bob Dowell Van” |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Mon Aug 08, 2022 6:34 pm Post subject: Re: Rant: Why must the “last few steps” take so long?! |
Of course.
Do you have a telescoping cobalt magnet?
Maybe this will help. Found this in my fruit this morning.
Posted: Mon Aug 08, 2022 7:06 pm Post subject: Re: Rant: Why must the “last few steps” take so long?! |
BarryL wrote: |
Of course.
How can a strawberry VW not help?! Thanks, Barry!
I do have a telescoping magnet, but the magnet itself is just big enough that it won’t fit past the upper plate and into the bottom of the distributor. Oh well. It wasn’t even timed yet, so loosen a couple of bolts, shake the clip out, and drop it back in. I was just tired and frustrated enough to make a bigger deal out of it than it was. _________________ ‘60 Kombi, The “Bob Dowell Van” |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Mon Aug 08, 2022 8:22 pm Post subject: Re: Rant: Why must the “last few steps” take so long?! |
"Just one more thing." It can get frustrating.
Keep at it. When you get your first 50 miles on it, you'll feel much better. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 560 Location: I don't recognize it anymore
Posted: Mon Aug 08, 2022 9:04 pm Post subject: Re: Rant: Why must the “last few steps” take so long?! |
Nice strawberries ! Little crap is always longer, get it right "slowly" the first time, less work later. At least your home is not being raided-right? _________________ kaiser kills kids.com |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Mon Aug 08, 2022 11:35 pm Post subject: Re: Rant: Why must the “last few steps” take so long?! |
I was lending a hand to my friend the independent Porsche-BMW shop owner one afternoon and he got so pissed off working under the hood of a BMW he threw a pair of channel lock pliers across the shop while he cussed at the top of his lungs.
I walked over across the shop, picked up the pair of channel locks, looked at them and then looked at him in disbelief.
He says "WHAT!"
I said "DAMNIT MAN! You threw a pair of HAZET pliers! Throw the cheap Harbor Freight stuff!"
We both laughed and got back on the project. _________________ Never argue with an Idiot. They'll only bring you down to their level and beat you with experience. |
Posted: Tue Aug 09, 2022 9:40 am Post subject: Re: Rant: Why must the “last few steps” take so long?! |
Well, for all the frustration it caused, it just took all of 5 minutes to pull the distributor, shake the clip out and reinstall the distributor. As my wife will readily attest to, I’ve been known to make big deals out of nothings!
Now, if I can just get this throttle return operating smoothly, I might just be able to turn the key today! _________________ ‘60 Kombi, The “Bob Dowell Van” |
BarryL Samba Member
Posted: Tue Aug 09, 2022 6:32 pm Post subject: Re: Rant: Why must the “last few steps” take so long?! |
What are the symptoms of the throttle frustrations?
Not sure why it does it but if you stick an 8 penny nail head to the magnet then the nail tip will pick up fairly heavy little objects like that keeper. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76947 Location: Sneaking up behind you
Posted: Tue Aug 09, 2022 6:39 pm Post subject: Re: Rant: Why must the “last few steps” take so long?! |
Building a new engine and installing the 4th piston/cylinder and the very last wire wristpin clip popped off and somehow slipped past the shop rags I used to cover the opening. After spending 30 minutes of turning the engine, using a stick magnet I pulled one of the other cylinders off and found it stuck to the cam lube on one of the lobes.
That was an hour lost in a hot shop, but I wasn't going to stop until it was found.
As a gag I once brought an old one and dropped it on the floor when visiting a friend who was building an engine. He freaked.. until i told him it was me. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Aug 09, 2022 8:04 pm Post subject: Re: Rant: Why must the “last few steps” take so long?! |
BarryL wrote: |
Good magnet tip! Will have to remember that one.
Got the throttle return working smoothly. The issue was that I could feel every coil of the return spring passing over the end of the tube as I applied throttle, sometimes binding. I ended up bending the tube ever so slightly up and towards the carb, and using very fine file to round off the edges of the end of the tube. Pedal feel is nice and firm now, and smooth like butter.
Next time I get an hour or so back in the garage, I’ll be cranking her over! _________________ ‘60 Kombi, The “Bob Dowell Van” |
