JeffL Samba Member
Posted: Thu Jun 23, 2022 2:41 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
VeloMikey wrote: |
JeffL wrote: |
56 one piece bumpers back from the chrome shop with the closed back guards. He did a nice job. Nice to have the original bumpers.
The front bumper had 4 holes for license plates. I had them closed up.
Who did your chroming? Those look great! |
I am just just East of Scranton Pa and took them over to Asbury Park in NJ. Super Chrome. Met me early on Saturday to drop off and pick up. They do a lot of work for a Tucker restorer that owns the patents and can make new Tuckers _________________ http://karmannghias.org/
https://karmannghias.org/GAlken/index.html |
JeffL Samba Member
Posted: Thu Jun 23, 2022 2:46 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
Here she is about 30 years ago when I towed her home with 65k on the odometer
Even had original hub caps with body colored painted logo
And no that's not a picture of a Polaroid photo.....
JeffL Samba Member
JeffL Samba Member
Posted: Thu Jul 07, 2022 4:22 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
Working on the fuel pressure and air in the line to the carb
Here all fuel line fittings are not the same. I bought some online and they are too thin. The wider brass came with a new fuel line kit. All are for 6mm lines but provide a different thickness to compress.
JeffL Samba Member
JeffL Samba Member
Posted: Sat Jul 09, 2022 10:33 am Post subject: Re: 56 Ghia build with Webasto and Judson |
I had a problem with a valve in the judson fuel pump. The air was just poor pressure, no leak. After all of this restoration work the clear fuel line fire testing helped to show the problem and checking the pressure was the right path!
Stock fuel press was about 2.2 psi and the Judson almost 6 psi.
I wasted my time with the hi Rez pressure gauge as the 6 psi pegged it.
I did put a thicker washer on the needle valve to not have too high of a fuel bowl level. Not sure with triple the pressure how to know if that worked. I always get some bleed back. Maybe I will pinch the line to the fuel tank and see if it
https://www.thesamba.com/vw/forum/viewtopic.php?p=9890205#9890205
STOCK FUEL PUMP
JUDSON SPRING IN THE PUMP ONE THIN GASKET
Update. After looking online I saw that 70s bugs had 2.8 psi fuel pressure so I went to Summit racing. I think I will try some spacers to get down to about 4 psi which doubles the factory 1.85 psi
Further Update: I measured 2 additional fuel pump gaskets and they were slightly over 1mm thick. I put these on, 3 pump side spacers now, and dropped the fuel pressure to 4.2 psi. I'm going to use that for now.
Right before shutting the engine off, I used a small pair of Vice grips on the fuel supply. The pressure dropped to 3.6 psi and it held for almost 5 min. I'll check later but it seems the needle valve is holding here.
4.2 PSI is where we will run her
[/b] _________________ http://karmannghias.org/
JeffL Samba Member
Posted: Wed Jul 13, 2022 7:19 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
One more try. 3 - 0.5 mm gaskets and on thin one
Pressure down to about 3.75 psi which is about twice the stock value of 1.85 p
I don't want to stress the needle valve or have excess fuel
JeffL Samba Member
Posted: Sun Jul 24, 2022 12:38 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
All chassis bolts in and ready for the body once I put down the pan seal and cut all of the bolt holes in the rubber seal
Here I had to take off the seat adjusters because they were pitted. The plater did an excellent job.
Each was held on with 4 rivets. I used some stainless screws and double nutted them. Came out extra nice.
I then put the spring bases back on the frames I had power coated ( in 1995....)
Ghias had screw on ivory buttons from the Beetle 113 881 206 up to vin 1 649 252
The floor pans are original to this 56 Ghia. You can see pitting on the inside which we neutralized and painted. After all those years in NYC they survived.
Braukuche Samba Member
Posted: Sun Jul 24, 2022 3:40 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
Looks nice. I like the pitting, verifies it’s original!
Who built your split case trans? Getting parts for those is a PITA! _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
JeffL Samba Member
Posted: Sun Jul 24, 2022 6:28 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
Braukuche wrote: |
Who built your split case trans? Getting parts for those is a PITA! |
Well its the one thing I chose not to rebuild as the Ghia only had 65,000 on it. It was a one owner. _________________ http://karmannghias.org/
Posted: Sun Jul 24, 2022 6:33 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
JeffL wrote: |
Braukuche wrote: |
Well its the one thing I chose not to rebuild as the Ghia only had 65,000 on it. It was a one owner. |
Let’s all say a prayer then, cross our fingers and rub a rabbits foot it works well. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
JeffL Samba Member
Posted: Sun Jul 24, 2022 6:44 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
The seats are a lot of work
Cleaned all the pivot parts them positioned the backs on.
The 56 Ghias have the triangle on the back of the pivot. The seats cracked in front of the pivot, my drivers was broken
I had a 57 where this triangle support was moved ahead.
Due to this my seat was racked a little and I had to do some "fitting"
Need to get some new rubber buffers, about 24.6 mm in diameter. I'll check other posts maybe this has been sourced already.
Posted: Sun Jul 24, 2022 7:58 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
JeffL wrote: |
I got mine at Ace Hardware, generic rubber plugs. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
JeffL Samba Member
Posted: Thu Aug 04, 2022 6:09 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
Well after 20 plus years the engine stand has served its purpose
The pressure plate and flywheel had some surface rust so we had to change these and polish things up a little before the attachment of the engine.
Getting ready to fire the engine up on the pan and drive it around. Let's see how the gearbox works.
Posted: Thu Aug 04, 2022 8:02 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
Let’s see some video of that! _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
JeffL Samba Member
Posted: Wed Aug 10, 2022 5:46 pm Post subject: Re: 56 Ghia build with Webasto and Judson |
Love it.
Engine sounds good. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
JeffL Samba Member
JeffL Samba Member
Posted: Fri Aug 19, 2022 7:16 am Post subject: Re: 56 Ghia build with Webasto and Judson |
Timing looks good. The paint shop liked the progress on the chassis so they have progressed to finishing the painting. Might be on track to pick up the body in a few weeks. We will trailer over the chassis across PA, about 300 miles, and go to the shop and let the body back down on the chassis.
Throughout the past 30 years we located several nos panels including the nose, front fenders, and rockers.
Soon I will need a sunroof expert!
