Mr67 Samba Member
Posted: Wed Aug 10, 2022 6:50 pm Post subject: Anyone know what this hole in the rear wheel well is for? |
I don't recall removing anything when I disassembled the car. But it seems as though it should at least have a plug?
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Wed Aug 10, 2022 10:26 pm Post subject: Re: Anyone know what this hole in the rear wheel well is for? |
I have the same holes in my '68.
I think it is just an open hole. It might have been a hole for an assembly jig (maybe for the rear apron). There will be corresponding one on the opposite side. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
daven Samba Member
Joined: January 13, 2009 Posts: 351 Location: Dayton OH
Posted: Thu Aug 11, 2022 3:52 am Post subject: Re: Anyone know what this hole in the rear wheel well is for? |
No year is identified but could be sway bar mounting holes? |
Posted: Thu Aug 11, 2022 3:57 am Post subject: Re: Anyone know what this hole in the rear wheel well is for? |
Not a sway bar location. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
splitjunkie Samba Member
Posted: Thu Aug 11, 2022 7:38 am Post subject: Re: Anyone know what this hole in the rear wheel well is for? |
It is for the Z bar which was an camber compensator type of sway bar. They were introduced in '67 for the US market. The US '67 and '68 non autostick cars would have had them. They may have used them in different markets but they were definitely present for the US market. The Z bar was no longer needed once they introduced the IRS rear suspension in '69.
Since they still made swing axle cars for other markets and to keep the part backwards compatible, they kept the mounting hole and studs intact. _________________ Chris
KTPhil Samba Member
Posted: Thu Aug 11, 2022 8:13 am Post subject: Re: Anyone know what this hole in the rear wheel well is for? |
splitjunkie wrote: |
Since they still made swing axle cars for other markets and to keep the part backwards compatible, they kept the mounting hole and studs intact. |
No, that is the hole further forward, not the one circled. |
mukluk Samba Member
Posted: Thu Aug 11, 2022 8:39 am Post subject: Re: Anyone know what this hole in the rear wheel well is for? |
That's the location of the tail light wiring harness holes on earlier cars. The harness hole location shown used in the picture didn't exist until roughly 1964. _________________ 1960 Ragtop w/Semaphores "Inga" |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1049 Location: Germany
Posted: Thu Aug 11, 2022 1:15 pm Post subject: Re: Anyone know what this hole in the rear wheel well is for? |
mukluk wrote: |
That's the location of the tail light wiring harness holes on earlier cars. The harness hole location shown used in the picture didn't exist until roughly 1964. |
I had two untouched '61, one from october 1960, the other one from may 1961. The 1960 had only one hole in total, the one where the harness was conducted through. The 1961 has both holes as shown in the pic, the harness for the (still) egg style taillight is conducted through the new hole.
I still wonder if I should close the second hole with a rubber grommet. |
Mr67 Samba Member
Posted: Tue Nov 08, 2022 11:41 am Post subject: Re: Anyone know what this hole in the rear wheel well is for? |
Found my answer. When going back through the photos I noticed what appears to be a clip kn that hole. And indeed, I had two clips left over in my stash after reassembling the car. They're there to hold the black wire for the reverse lights before it gets fished through the bumper bracket slot. In the picture you can make out the clip buried under the undercoating. Yep, that's the same car in my first post.
