Cool option for rear calipers
CrazyTestPilot
CrazyTestPilot is offline
PostPosted: Tue Aug 09, 2022 8:46 am    Post subject: Cool option for rear calipers Reply with quote
I wanted a multi piston fixed caliper for my rear buggy wheels but my budget wouldn't allow anything new. In my search for calipers at the junk yard I came across the bulletproof Volvo 240 front caliper. 4 pistons, fixed and not super heavy. What really makes them special though is that they are actually dual system calipers meaning each caliper has two fluid connections each actuating two pistons and are completely separate systems within one caliper. Now I can plumb my foot brake and cutting brakes separately making a backup in case something fails plus easier to bleed and customize the feel for each. Or drill it and have a single system 4 piston caliper for about $20 each Required a little welding to fit them but well worth it. They work great
stevebaz
stevebaz is offline
PostPosted: Tue Aug 09, 2022 12:28 pm    Post subject: Re: Cool option for rear calipers Reply with quote
I assume your not using wide 5 wheels?
CrazyTestPilot
PostPosted: Wed Aug 10, 2022 12:05 am    Post subject: Re: Cool option for rear calipers Reply with quote
Yes I am. Why?
stevebaz
stevebaz is offline
PostPosted: Wed Aug 10, 2022 12:22 pm    Post subject: Re: Cool option for rear calipers Reply with quote
I didnt think volvo rotors were wide 5 bolt pattern. I didn't know any other brands used wide 5.
Daddy o's 67
Daddy o's 67 is offline
PostPosted: Wed Aug 10, 2022 6:16 pm    Post subject: Re: Cool option for rear calipers Reply with quote
So did you modify a stamped EMPI brake caliper bracket to work with these calipers? My thought is that the second line could also double as a parking brake system.
Please share photos when you can. Thanks for your junkyard research.
oprn
oprn is offline
PostPosted: Thu Aug 11, 2022 6:10 am    Post subject: Re: Cool option for rear calipers Reply with quote
He isn’t using the Volvo rotors. Just the callipers.
We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
CrazyTestPilot
PostPosted: Sat Aug 13, 2022 8:04 pm    Post subject: Re: Cool option for rear calipers Reply with quote
oprn is correct I'm not using the Volvo rotors, just the calipers. I have the porsche rear end with vented rotors. I was suprised at how close the Volvo calipers were to just bolting right in. I did have to chop off one of the bolt "ears" off the caliper and relocate it but it was a simple process. The heavy casting allows you to confidently weld it back on with no fear of failure. I took some pix but sadly they came out so badly they weren't worth uploading. Sorry. You can actually buy these calipers online for as low as around $50-$60 a piece I think. Also there is a great video on youtube explaining how to drill them out to make it a single system 4 piston caliper like regular 4 piston calipers. I like having the foot brake and the cutting brakes as three separate systems since It's easy to bleed and if you have a problem somewhere it only affects that specific area instead of the whole system.
BFB
BFB is offline
PostPosted: Sat Sep 03, 2022 8:43 am    Post subject: Re: Cool option for rear calipers Reply with quote
How about those pics?
Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1
CrazyTestPilot
PostPosted: Thu Mar 23, 2023 5:57 pm    Post subject: Re: Cool option for rear calipers Reply with quote
Ok, here's a caliper and my homemade cutting brake made with two wilwood 1" bore brake masters. I can now have basically zero deadzone in the handle between left and right braking. Just what I was after. The calipers still need to be ground clean but it aint gonna break.
oprn
oprn is offline
PostPosted: Fri Mar 24, 2023 5:38 am    Post subject: Re: Cool option for rear calipers Reply with quote
I like it!
rayjay
rayjay is offline
PostPosted: Fri Mar 24, 2023 8:49 am    Post subject: Re: Cool option for rear calipers Reply with quote
It will be interesting to see the wear pattern on the pads after a lot of use. It might be possible to cut the pads in half so you have 4 individual pads to match the 4 pistons.
CrazyTestPilot
PostPosted: Sun Mar 26, 2023 4:42 am    Post subject: Re: Cool option for rear calipers Reply with quote
I was wondering about that myself. I'm guessing more break pad surface area is best so I'll leave it the way Volvo designed it. It only took one washer to perfectly center the caliper over the rotor which was lucky.
