Sofia74 Samba Member
Posted: Sat Aug 13, 2022 2:10 pm Post subject: Securing relays in the front trunk |
Replaced the wiring harness in our 1974 KG Coupe. Looking for a practical way to pin down a couple relays - headlight, horn... They are loose right now. Not a show car and not worried about looking stock. Just thought there might be some clever ideas out there to secure them safely. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Sat Aug 13, 2022 2:31 pm Post subject: Re: Securing relays in the front trunk |
use ones that have a mounting tab and just fabricate something to mount them to.
_________________ Glenn
Member #1009
#BlueSquare |
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Sat Aug 13, 2022 10:53 pm Post subject: Re: Securing relays in the front trunk |
By using the somewhat stock location, I made the relay holder into an extra ground for the front lights & turn signals. Never underestimate the importance of grounds
Vlad _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
Craigbro Samba Member
Joined: January 26, 2021 Posts: 186 Location: Louisiana, USA
Posted: Sun Aug 14, 2022 10:07 am Post subject: Re: Securing relays in the front trunk |
I used the same type of relay and used a zip tie to loosely secure it to the front latch tube. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Thu Aug 18, 2022 7:03 am Post subject: Re: Securing relays in the front trunk |
Quote: |
pin down a couple relays |
Not being a big fan of stock brass quick-disconnect ends I did this to keep my 'relays' in the same place and still easy to wire up in my '72. Just used ty-wraps (zip ties) thru the 'holes' for the old brass connectors and strapped them down including the horn relay.
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1203 Location: Philaburbia
Posted: Thu Aug 18, 2022 11:02 am Post subject: Re: Securing relays in the front trunk |
Very sharp setup! |
Posted: Thu Aug 18, 2022 11:21 am Post subject: Re: Securing relays in the front trunk |
any photo of the headlight 'flasher' or turn signal 'controller' wiring? these look like Normally Open cube relays controlling the parking lights. The link goes to that type of relay too _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Posted: Fri Aug 19, 2022 7:38 am Post subject: Re: Securing relays in the front trunk |
runamoc wrote: |
any photo of the headlight 'flasher' or turn signal 'controller' wiring? these look like Normally Open cube relays controlling the parking lights. The link goes to that type of relay too |
I don't have photos of those relays, but mine are stock and attached at their original positions on the nearby upright via the clips spot welded to their tops (e.g., like the clip on this one https://www.jbugs.com/product/111941583.html). |
Posted: Fri Aug 19, 2022 8:07 am Post subject: Re: Securing relays in the front trunk |
Quote: |
mine are stock and attached at their original positions on the nearby upright via the clips |
OP Ghia is a '74. Original position is not with clips on an upright. They look similar to this
VeloMikey Samba Member
Posted: Fri Aug 19, 2022 9:31 am Post subject: Re: Securing relays in the front trunk |
runamoc wrote: |
OP Ghia is a '74. Original position is not with clips on an upright. |
Okay, I'll second your suggestion for the OP to use zip-ties. |
Posted: Sat Aug 20, 2022 3:43 pm Post subject: Re: Securing relays in the front trunk |
OP here: My original 1974 fuse block had uprights where the relays attached. No longer an option. I’ve seen Velcro attachment to the floor of the front trunk and zip ties to the uprights. Good options. I’ll figure it out.
Coincidentally, I took delivery of new horns and they came with a new relay with a tab. That takes care of one relay. |
