Lone Star Guy Samba Member
Posted: Fri Aug 12, 2022 9:23 am Post subject: Another Touch Up Paint Inquiry |
Yes, I know there are dozens of posts about this, but there is almost always a caveat or discovery that leads to more or different questions. I'm looking for Marina Blue L 54 D paint for small chips.
Paintscratch.com doesn't even show the color for 1972 ( https://www.paintscratch.com/cgi-bin/select-color.cgi ) but it does for 1974. It's L 54 D so I assume it's the same. I'll likely go with them.
Anyone familiar with paint2fix.com? They offer a kit. I searched for paint2fix on Samba and found no references.
Touchupdirect.com doesn't appear to have the color.
Edit: Also automotivetouchup.com seems to carry it.
After preparing the chipped spots, from that point, how necessary is it to use the components some kits have (wax, maybe sealant)? Or will just dabbing the paint be sufficient? I don't show my car or anything like that, just want to do my due diligence to keep it nice.
Lastly, I have a OLD bottle of Lackstift touch-up paint that came with the car! Nice memorabilia... that I though would be dry. It's actually still wet in the bottle, but even after digging around in bottle, the brush only comes out black. I'm assuming this is normal after 50 years. _________________ “You either run from things or you face them. It’s all about who you are.” From Brad Thor’s novel, Full Black
“There is very little difference between one man and another; but what little there is, is very important.” Henry James |
jarmchairpilot Samba Member
Joined: March 04, 2013 Posts: 459 Location: GALWAY,IRELAND
Posted: Sat Aug 13, 2022 10:22 am Post subject: Re: Another Touch Up Paint Inquiry |
eBay. |
Posted: Sat Aug 13, 2022 10:26 am Post subject: Re: Another Touch Up Paint Inquiry |
I mixed my own using a blend of rustoleum duck egg blue and a little bit approx.10 per cent of cobalt blue. Not ideal but widely available, it will fade in sunlight very quick without a clear coat or lacquer to protect it. |
Posted: Sat Aug 13, 2022 2:29 pm Post subject: Re: Another Touch Up Paint Inquiry |
Modern paint shops require a RAL code number to mix paint,
I would also love to know what other codes there are for L54D marinablau! |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat Aug 13, 2022 3:58 pm Post subject: Re: Another Touch Up Paint Inquiry |
I have used AutomotiveTouchup on three different cars. Their stuff is always spot on.
The key to dabbing it on is to use thin coats. Two will usually do, but sometimes three. Although, the paint is thick enough to go on as a single coat.
If you have a clear coat, you need to top it off with their clear coat.
I start with a dab of their primer, then a coat or two of paint. Each repair requires that the area be free of ax, dirt, oil, etc. Otherwise, it won't stick.
They also carry spray cans for larger touchups. I just bought some for my 1999 Ford Ranger, but haven't used it yet, due to the hot days here.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 348 Location: Noblesville, IN
Posted: Sat Aug 13, 2022 4:16 pm Post subject: Re: Another Touch Up Paint Inquiry |
+1 https://www.automotivetouchup.com _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
Posted: Sun Aug 14, 2022 5:41 am Post subject: Re: Another Touch Up Paint Inquiry |
Thanks everyone. I'm going to go with the automotivetouchup and see how it goes. _________________ “You either run from things or you face them. It’s all about who you are.” From Brad Thor’s novel, Full Black
jinx758 Samba Member
Posted: Sun Aug 14, 2022 9:10 am Post subject: Re: Another Touch Up Paint Inquiry |
After some trial & error in the past:
I agree with Tim -
clean, prime, dab paint to fill, then polishing compound (by hand) has netted acceptable results. I had to wet sand a couple with 800 then 1200 grit but I have OCD.
Always give ample drying time for all steps.
Good luck ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
VALVES (cold)
POINTS
TIMING
CARB (fully warmed engine)
SCRAPE ALL GROUNDS
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
