Mckinleyvillian Samba Member
Joined: July 22, 2021 Posts: 506 Location: Macktown, CA
Posted: Sat Aug 13, 2022 7:20 pm Post subject: Re: What did YOU do to your van today? |
Engine had been cutting out on decelerating corners/turns, found a broken wire at idle control, fixed it. Not perfect but only cut out 1x during 9hr of driving. Gonna adjust idle tmrw and I think it might help.
Drove up the coast, went sea level to 2600 ft elevation numerous times on the the sharpest, winding stop and go stretch of 101 that I know of. Calculated MPG and on this trip got 16.9. Very, very satisfied with this 1.9 of unknown mileage and care other than what I've done. _________________ so many roads i know
all i want is one to take me home
85 Vanagon GL 1.9 stick |
indianpeaksjoe Samba Member
Posted: Sat Aug 13, 2022 7:39 pm Post subject: Re: What did YOU do to your van today |
jimf909 wrote: |
That looks great. Which carpet kit is that? Sewfine? Lloyds. Something else?
Do you have a photo of the front over the wheel well and around the heater box?
Thanks.
indianpeaksjoe wrote: |
New carpet! The old one was thread bear between the front seats and just some home depot carpet in the passenger area.
Thanks! It is the Sew Fine kit purchased from Go Westy. I also put in the Sew Fine insulation/padding in the front. I’ll take pics in the morning. But I am really happy with it,, the inside looks so nice now. Also smells much nicer.
It installed in about 4 hours and is the first time I did anything like this. I watched a few videos and people were complaining of overlap and removing/re-gluing. I just dry fit everything first and it all made sense.
The only problem is now I want new door cards to match the new look of the carpet:)
-Joe |
Posted: Sun Aug 14, 2022 3:36 pm Post subject: Re: What did YOU do to your van today? |
jimf909 wrote: |
Thanks.
Here you go,
Posted: Sun Aug 14, 2022 6:00 pm Post subject: Re: What did YOU do to your van today? |
Installed some snap bamboo a while back, which was removed today and reinstalled after vapor barrier. Sanded down kick panel which will be stained, drilled, and secured tmrw.
jimf909 Samba Member
Posted: Sun Aug 14, 2022 8:58 pm Post subject: Re: What did YOU do to your van today? |
Thanks for the overview and the pics. The carpet looks great. Fancy door cards will look good too. And then comes new seat upholstery. (But Vanagons with the full Sewfine treatment sure do look good.)
jimf909 wrote: |
Thanks.
Here you go,
_________________ - Jim
Abscate wrote: |
carls2u Samba Member
Joined: October 17, 2019 Posts: 13 Location: Eugene, Oregon
Posted: Mon Aug 15, 2022 6:31 pm Post subject: Re: What did YOU do to your van today? |
Put the bike racks on the GW swing away rung tower to test out the stability and transport of our bikes for cycle oregon. Very pleased with the rack. Exactly what we needed.
_________________ To see a world in a grain of sand
And a heaven in a wild flower,
Hold infinity in the palm of your hand,
And eternity in an hour.
'86 Westy |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Aug 16, 2022 3:16 pm Post subject: Re: What did YOU do to your van today? |
Damn tasty! !!!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
TomInAlaska Samba Member
Joined: June 02, 2007 Posts: 386 Location: Anchorage, Ak
Kdj Samba Member
Joined: January 28, 2017 Posts: 142 Location: Naptown
Posted: Wed Aug 17, 2022 5:48 pm Post subject: Re: What did YOU do to your van today? |
dhaavers wrote: |
Damn tasty! !!!
- Dave |
Really like the marker light protection. Going to add it to my list of idea's to copy |
BCE56 Samba Member
Posted: Fri Aug 19, 2022 3:24 pm Post subject: Re: What did YOU do to your van today? |
Took advantage of cooler weather today and installed the passenger seat cover. This one went on easier due to experience with driver's side.
Maybe better to do the back before the bottom, to allow a bit more clearance to unite the Velcro at the bottom of the back cover.
Bottom cover goes on pretty easy. Extend the fore & aft straps and they can be fastened by reaching under the seat, then cinched securely.
The transverse strap was a puzzler- I couldn't figure a way to attach it beneath the seat. I fastened it around the back instead.
On to the next fiasco!
The old covers are available for free to anybody who can use them. Decent shape, though somewhat sun-faded, the complete set less one seat bottom.
Come and get 'em!
Don't be shy, we can yakk about Vanagons. _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
Posted: Mon Aug 22, 2022 11:24 am Post subject: Re: What did YOU do to your van today? |
interior work time!
cleaned up, sprayed, and installed a center console/lock box my buddy fabricated from scrapped metal. not bad for his first attempt
dad gave me my grandfather's jig saw and I used it for the first time to cut door cards/interior paneling. the plan is to cover with blue corduroy fabric at some point. they're a little janky but seem to line up good enough
cleaned up and used tung oil to coat an old redwood plank I salvaged for the kick panel
elizer Samba Member
Joined: May 02, 2016 Posts: 1465 Location: Northern Virginia
Posted: Mon Aug 22, 2022 12:21 pm Post subject: Re: What did YOU do to your van today? |
Had these wet okole rear seat and mattress cover that I finally put on. They fit tight. I didn't fuss with the adjustments too much, but one could make it look better. They are easy to remove for cleaning.
I ordered the covers for my front eurovan seats, but I decided on sheepskin from covercraft instead. So those will be going up for sale when I eventually find the 4th armrest cover.
I will post pictures of the sheepskin cover when I get them on.
_________________ 91 syncro westy fas tdi |
jlrftype7 Samba Member
Posted: Wed Aug 24, 2022 1:58 pm Post subject: Re: What did YOU do to your van today? |
Washed it and changed the Oil and Filter. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
elizer Samba Member
Posted: Thu Aug 25, 2022 5:22 am Post subject: Re: What did YOU do to your van today? |
swapped out 1 side of my lift truts with a liftsupportdepot strut. It holds up my full width gary lee rack and spare tire. _________________ 91 syncro westy fas tdi |
Bleyseng Samba Member
Posted: Thu Aug 25, 2022 7:59 am Post subject: Re: What did YOU do to your van today? |
Installed a set of Manispeed injectors. Yep, it runs better with them. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Thu Aug 25, 2022 2:30 pm Post subject: Re: What did YOU do to your van today? |
After camping with my new Dometic CFX55IM for most of this year (and not using the stock fridge once), I felt it was now appropriate to remove the stock unit and open up the space for storage. I purchased the GW block off plate for blocking off the stock flue vent on the side of the van, and pieced together the rest of the required parts from leftover scrap wood and hardware I had around the garage. I did have to purchase some L brackets to remount the fridge door frame trim though. All together about $20 spent to complete it.
_________________ 1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark |
Kdj Samba Member
Posted: Thu Aug 25, 2022 3:53 pm Post subject: Re: What did YOU do to your van today? |
Finished cutting down rotors into hubs for my brake conversion.
And was going to install my smuggler tool tray too, but didn’t think about
Thé body contour in the far back corner. So it doesn’t quite fit.
I’ll have to adjust a dimension!
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
do.dah Samba Member
Joined: August 27, 2015 Posts: 447 Location: Washington
Posted: Fri Aug 26, 2022 5:46 pm Post subject: Re: What did YOU do to your van today? |
djkeev wrote: |
Bleyseng wrote: |
Installed a set of Manispeed injectors. Yep, it runs better with them. |
See, here's the question.
Does it run better because of the Manispeed injectors?
Or
Does it run better because the old malfunctioning injectors have simply been replaced with properly functioning injectors?
No one has a definitive answer to this question.
Case in point........ Mine runs better with cleaned and serviced OE injectors.
I've yet to hear of anyone installing Manispeeds, driving for awhile, removing them and putting in serviced OE injectors and posting an objective report.
This would best be done as a blind test.
Dave |
I had had my injectors serviced for the 1st time around the 300k mark. They weren't very bad according to the pre-service evaluation, and they were very good after service.
I got the manispeed injectors anyhow, at least so I have a known good spare set of injectors.
With the manispeeds installed, I seem to start up a little quicker, idle a little smoother, seem to have increased my mpg slightly, and feel that the roll on acceleration is a bit snappier.
None of these observations are night and day differences, with the likely exception of my mpg increase.
I feel that the new injectors were worth the $'s. |
82westyrabbit Samba Member
Posted: Sat Aug 27, 2022 3:14 am Post subject: Re: What did YOU do to your van today? |
That’s excellent input thank you. John |
