ThingBeast Samba Member
Posted: Fri Aug 12, 2022 12:33 pm Post subject: Screw size for points |
I'm in search for the size and type of screw that holds the points down inside the distributor. I thinks it's a flat head. Also, the type and size of the screw that holds the condenser in place. Any help is appreciated! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76936 Location: Sneaking up behind you
Posted: Fri Aug 12, 2022 1:18 pm Post subject: Re: Screw size for points |
M4 x 5mm long x 0.7mm pitch _________________ Glenn
Member #1009
#BlueSquare |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2506 Location: Santa Cruz, CA
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6612 Location: Houston, Texas
Posted: Sun Aug 14, 2022 1:27 pm Post subject: Re: Screw size for points |
They are all the same thread and pitch. The lengths are what is different. When you put the screw in the points you will want to check that you can fully turn the shaft 360 degrees. That will check if there is any interference. You can put any length screw in any of the holes as long as it is long enough and doesn't interfere. _________________ www.vwnos.com [email protected]
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Glenn Mr. 010
Posted: Sun Aug 14, 2022 3:22 pm Post subject: Re: Screw size for points |
They are _________________ Glenn
Member #1009
#BlueSquare |
heimlich VWNOS.com
Posted: Sun Aug 14, 2022 5:11 pm Post subject: Re: Screw size for points |
I sell stainless ones in a set to cover the whole unit. If someone needs one or two used ones I have a bunch that I could throw into a package for you. You just pay the shipping. _________________ www.vwnos.com [email protected]
