cantdrv55 Samba Member
Posted: Mon Aug 15, 2022 12:22 am Post subject: Will older model bumpers fit a '69? |
I can find ads for older bumpers but hardly any for a 1969 so I'm wondering if ones for a '66 will fit. What do you think? |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Mon Aug 15, 2022 5:33 am Post subject: Re: Will older model bumpers fit a '69? |
No, not directly.
But conversion brackets are available
https://www.jbugs.com/product/15-2045.html?utm_con...hJEALw_wcB
However, they look a bit goofy because the brackets give them a droopy appearance. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Aug 15, 2022 7:47 am Post subject: Re: Will older model bumpers fit a '69? |
Thanks for the info! I’ll keep searching for the correct bumpers then. |
nitro_rat Samba Member
Joined: January 15, 2011 Posts: 68 Location: Lufkin, TX
Posted: Mon Aug 15, 2022 8:07 am Post subject: Re: Will older model bumpers fit a '69? |
I just happen to have a Mid America catalog in front of me and the cheap replica bumpers are $99 front/$119 rear. Brackets are $24/each. If you paint the back and keep the chrome waxed they last ok especially if it's not a daily driver.
OG is always best but most of the used ones that I find aren't presentable anyway. There are better grade reproductions for a much higher cost readily available also but none of them are chromed as well or made from as thick a metal as OG. |
Posted: Mon Aug 15, 2022 9:33 am Post subject: Re: Will older model bumpers fit a '69? |
Thanks! I’ll look up mid America |
Posted: Mon Aug 15, 2022 2:18 pm Post subject: Re: Will older model bumpers fit a '69? |
cantdrv55 wrote: |
Look at California Import Parts also. Depending on where you are shipping may make a difference. They are www2.cip1.com or maybe www3? |
Posted: Mon Aug 15, 2022 2:31 pm Post subject: Re: Will older model bumpers fit a '69? |
Thanks again |
