slayer61 Samba Member
Posted: Fri Jul 08, 2022 1:59 pm Post subject: Re: slayer61 finally has a Dune buggy! |
2276 W125 with 1.25 rockers 44 Webber clones, the usual stuff and 4.12 R&P, why? _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
y2kbaja Samba Member
Joined: March 07, 2016 Posts: 93 Location: Sacramento
Posted: Wed Jul 13, 2022 2:06 pm Post subject: Re: slayer61 finally has a Dune buggy! |
slayer61 wrote: |
So I scored a cooler, fan and AN hose & fittings at the Bug-o-rama over Memorial Day, along with some other items. The newish cooler will be used in conjunction with an OEM doghouse cooler. Looking at mounting it under the "back seat". I found some scrap angle iron in the shop, and knocked together the first rev. of my cooler mount. It's fairly "industrial" looking, but I believe it will hold a cooler. The angle will be welded to the torsion tube and the cooler "floated" on rubber isolators. Waddya think Sambanistas?
I approve this cooler mount (but I could be wrong too, lol).
Posted: Wed Jul 13, 2022 3:26 pm Post subject: Re: slayer61 finally has a Dune buggy! |
Excellent! _________________
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Fri Jul 15, 2022 10:56 am Post subject: Re: slayer61 finally has a Dune buggy! |
7/15/22
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Mon Jul 18, 2022 7:18 am Post subject: Re: slayer61 finally has a Dune buggy! |
Closer yet
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Fri Jul 22, 2022 11:48 am Post subject: Re: slayer61 finally has a Dune buggy! |
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Fri Jul 22, 2022 1:09 pm Post subject: Re: slayer61 finally has a Dune buggy! |
The last pic from the motor shop is very nice. They're waiting on me now, to provide an exhaust before cam break-in begins
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Thu Aug 04, 2022 9:03 am Post subject: Re: slayer61 finally has a Dune buggy! |
Aand, it's in!
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Wed Aug 10, 2022 7:14 am Post subject: Re: slayer61 finally has a Dune buggy! |
So a couple of days ago I stopped by my local (old school) VW shop for a few items I was still missing...(Thanks a bunch Jim!)
Jim was able to provide me with a couple of missing OEM type items including:
A (neused and tested good) Bosch starter
The shifter coupling cover
And the front tunnel cover
Purists may piss-off that I chose to use NON-OEM hardware...!
OEM braided jumper from trans mount to trans. It has a small hole on the top & a large hole on the bottom and is EXACTLY the right length!
Also, because the EMPI clutch cable shortening is a complete POS and only serves to eat the cable, the hardware store & a collection of honyock fittings were sourced to make the connection
The oil cooler was mounted for the last time...
Including the temp switch
The fan and the temp switch are fitted with plugs that are the opposite of each other, preventing the fan power from being plugged into the temp switch & vice versa... but they DO plug into each other!
A second set of caster bushes were added for "high speed" stability, along with the necessary longer bottom bolts
At the end of the day, I dropped the body back on and... TA DA! the cooler fan hits the body and was promptly removed, leaving an un-fanned oil cooler
Be safe guys. _________________
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Thu Aug 11, 2022 2:18 pm Post subject: Re: slayer61 finally has a Dune buggy! |
"At the end of the day, I dropped the body back on and... TA DA! the cooler fan hits the body and was promptly removed, leaving an un-fanned oil cooler Embarassed"
By how much? Could you take the spacers/isolators out below the cooler? On my class 9 car the oil cooler is behind our head (directly in the wind), with the fan on the temp drops nearly 20*. My buggy doesn't have a temp gauge so not sure what the temps are currently with the oil cooler in the same place as yours. |
Posted: Thu Aug 11, 2022 3:14 pm Post subject: Re: slayer61 finally has a Dune buggy! |
I suppose I "could" remove the rubber biscuits, but, I'd rather have them there and no fan, than solid mounted with a fan.
I have a stock new cooler in the dog house. I will get gauges set up and drive it as-is for now. If I think it should be cooler, I will plumb in the aux cooler. If that still needs "assistance" I will probably notch the glass & fab up a "box" to go over the fan.
It only hits by 1/2" I expect, but a hit is as good as a mile.
What was it 7th grade shop teacher Mr. Acacia said???
Quote: |
Measure twice & cut once. |
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Mon Aug 15, 2022 7:46 am Post subject: Re: slayer61 finally has a Dune buggy! |
The brown truck showed up at the house over the weekend! He brought my new header
I have bagged on EMPI pretty hard in the past over their amazing lack of quality control. This stainless header is "almost" enough to make me want to take it all back. It's that good. Thick flanges that actually look like they were touched with a file to flatten the mounting surfaces, insides of the head pipes and collector that are just buttery smooth and free from any sharp edges. I was just very pleased with the attention to detail from the fabrication department at EMPI.
But you know it's coming, right.......
BUT
The kit came with 2 #4 cylinder pipes and NO (0) #2 pipes! AAAaaarrrggghh!!!
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Mon Aug 15, 2022 12:35 pm Post subject: Re: slayer61 finally has a Dune buggy! |
That last pic had me wondering how you got the correct #2 pipe so soon, until looking closer at its flange and seeing its cock'd with respect to where studs are. (Hope the fix isn't too much of a hassel.) |
oprn Samba Member
Joined: November 13, 2016 Posts: 12718 Location: Western Canada
Posted: Tue Aug 16, 2022 6:20 am Post subject: Re: slayer61 finally has a Dune buggy! |
I had a stinger like that on my Buggy for a while and I got tired of tripping over it real quick! So did everyone else that tried to walk around or past it! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Tue Aug 16, 2022 6:49 am Post subject: Re: slayer61 finally has a Dune buggy! |
Well guys...
It's boxed back up and shipping back to the vendor today. Seems it's the only one in the world! _________________
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Mon Aug 22, 2022 2:03 pm Post subject: Re: slayer61 finally has a Dune buggy! |
Thanks to a fellow Sambanista, I have a new (to me) 1 5/8" merged header for my buggy project. Over the last few weeks, I have determined that this one might be the last one in the world!
Thanks Anton, very much!
A stinger and other bits & bobs have been sourced from other vendors & I hope to put another big dent in the progress this weekend. _________________
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Fri Aug 26, 2022 8:03 am Post subject: Re: slayer61 finally has a Dune buggy! |
I'm really blessed to work at a facility that allows me to access all the stuff in the maintenance shop at will!
This morning before it got hot, I annealed my copper exhaust gaskets in preparation to install the header this weekend.
I'll be taking delivery of a matching stinger and baffle today. Really looking forward to this! Also on the truck is a set of battery cables, an ignition switch & some other bits & bobs.
Waiting in the garage is another box full of the final components to tie up the fuel system, except the tank OEM speedo and a set of Autometer gauges Monster tach, oil pressure & temp.
I hope to put a big dent in the next steps towards turning my hard earned $$cash$$ into noise! _________________
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Mon Aug 29, 2022 7:34 am Post subject: Re: slayer61 finally has a Dune buggy! |
8/29/22 Update:
My Number 1 helper was over and since he already volunteered to install dash lights and gauges, it made perfect sense that he would install the ignition switch as well. Thanks Theodore!
Also got battery cables installed
And parking brake sorted... was waiting on shortening kit
And FINALLY have the exhaust installed proper!
A productive day was had in the shop _________________
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Tue Sep 06, 2022 7:04 am Post subject: Re: slayer61 finally has a Dune buggy! |
Fuck it's hot lately!
I got to spend some time in the shop this weekend. Managed to get the fuel system complete-ish... from the bottom of the gas tank to the carbs in the back
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
Posted: Mon Sep 19, 2022 7:37 am Post subject: Re: slayer61 finally has a Dune buggy! |
Update 9/18/22
As it's cooling off, I got to spend some time in the garage over the weekend.
My fuel tank is back from the radiator shop. Thanks Randy. Beautiful work as always.
And NOW the fun part begins! Another package was delivered from Speedway Motors! The "Universal Hotrod Wiring Harness" is intended for a front engine car, and needed some modifications prior to being installed. All of the "engine" type circuits were removed from the front harness and installed into the rear harness, and the "gas gauge sender" was moved to the front.
Pretty soon now we'll be making noise! _________________
Cusser wrote: |
Paul
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
CB Magna spark
